Old 10-07-2013, 09:36 PM   #15
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Question is what offset is this wheel even available in? On the red they look way too tucked in...?
I'm just speculating here but seeings how no major vendors here selling them the offsets can't be all that great for our cars fitment wise.
Old 10-07-2013, 10:18 PM   #16
df.dima
Drives: FR-S and Mazda 3 Sky
http://www.enkei.com/size_chart/RSF5.pdf
df.dima is offline   Reply With Quote
Old 10-07-2013, 10:28 PM   #17
OICU812
Just a dude
OICU812's Avatar
Ahh ok I see now just limited widths available probably why not so popular.
Old 10-07-2013, 11:17 PM   #18
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Yeah, you can't do a staggered setup with these.
It would be nice if you could, but it's still a great looking wheel at $180 a piece.
I'm in love with the clean design of these wheels and I also think it's a plus that these wheels are not so popular.
ericmpena is offline   Reply With Quote
Old 10-07-2013, 11:39 PM   #19
OICU812
Just a dude
OICU812's Avatar
Well squared in 18x8 in 40 or 45 offset and 17x7.5" exists in 40 offset but that's about your only squaring options.
Old 10-08-2013, 12:23 AM   #20
ericmpena
ericmpena's Avatar
What's wrong with 18x8 45 offset? Wouldn't that look good? I'm not to knowledgable about how offsets work so that's why I'm asking.
I see 8" is 1 inch wider than the stock wheel. And I think 45 offset is what TireRack chooses when you choose these wheels for a BRZ.
Will the wheels not be flush with the frame??
Old 10-08-2013, 01:21 AM   #21
OICU812
Just a dude
OICU812's Avatar
Stock height likely fine but lowered an inch plus it's gonna be likely pretty tucked in.
Old 10-08-2013, 01:31 AM   #22
ericmpena
ericmpena's Avatar
Wheel spacers would fix this, no?
I have spacers on my stock wheels. 20mm front, 25mm rear. These probably wouldn't work since the RSF5 is 8" wide, correct?
Old 10-08-2013, 02:30 AM   #23
ericmpena
ericmpena's Avatar
Sorry, I'm not understanding this. I used a Wheel Offset Calculator and this is what I got:
For Stock wheel I put: 7" wide, +48 Offset
For New wheel I put: 8" wide, +45 Offset
The Results were:
Inner Clearance: 10mm LESS
Outer Position: EXTEND an extra 16mm.
What does that mean??
Old 10-08-2013, 02:48 AM   #24
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
1" = 25.4mm
Divide 25.4mm by 2 = 12.7mm This is because, if we line up both wheels, the 8" wheel will be wider by 12.7mm on either side over the 7" wheel.
48 offset minus 45 offset = 3mm of offset
12.7mm + 3mm = 15.7mm, which is approximately 16mm, meaning the surface of the new wheel will stick out 16mm more than stock.
16mm = 0.63"
Old 10-08-2013, 02:58 AM   #25
ericmpena
ericmpena's Avatar
Originally Posted by indesign View Post
1" = 25.4mm
16mm = 0.63"
Thanks!
So, as far as Wheel Spacers go, since I'm using a 20mm for the front, instead I'd probably use a 5mm spacer for front?
And for the rear I could take my 25mm spacer and subtract the 16mm, so I'd need a 10mm roughly for the rear?
I'll be going from 20mm front, 25 rear TO 5mm front, 10mm rear? Does that sound about right?
Old 10-08-2013, 03:03 AM   #26
m.box.design
yep, looks like it.
Old 10-08-2013, 03:22 AM   #27
ericmpena
ericmpena's Avatar
yep, looks like it.
Sweet! Next question. Where do you recommend I get 5mm and 10mm spacers for BRZ/FRS? I checked B2 Auto and Eibach and neither site had them.
I remember B2 Auto telling me that the spacers I purchased for the stock rims would only work with aftermarket wheels if thay had the same hole or something like that. Not sure what they were talking about, but I won't be using their spacers anyways since they are too large.
Old 10-08-2013, 07:13 AM   #28
ericmpena
ericmpena's Avatar
Did some more digging around and found a good side shot of the wheels.
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 05:23 AM
Wheel Directory: Enkei NT03+M 18x8.0 +35 Tunz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 06-16-2016 11:31 PM
Wheel Directory: BBS RG-R 18x8.5 +35 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 04-11-2015 04:03 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 08:49 PM
