#421 | |
Drives: 1
What's surprising about it is that the front is nowhere near its limits when the rear lets go - in fact it feels like I could easily add another 5-10mph on turn in before seeing any signs of understeer. When the rear does let go, it does so quite quickly - think AP1 S2000? - and I am losing a lot of time 'drifting' which is definitely not the type of driving I enjoy. Ideally I don't want to numb down the front end just so I can bring the rears into play but if I have to, I guess I have to. As for my set up, I am on tein flex (before being phased out with mono and street options) with 7kg/mm front and rear. F: 2.3 camber, 0.25 degree toe out, R: 2.15 camber (with lowering, no LCA used to correct atm), 0.25 toe in Lowered 30mm front and 28mm rear |
#422 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Captain Snooze (10-07-2013) |
#423 | |
- Andy |
#424 | |
Generally though I'd say CSG is in the upper range of where I'd be for a car on sticky street tires. Going stiffer or adding big swaybars to that you start overloading the tires prematurely or overheating with multiple laps. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | solidONE (10-07-2013) |
#425 | |
That Guy
Drives: 2013 asphalt FRS MT
I'm certainly not an expert here so please feel free to tell me I'm wrong. By lowering more in the front you've shifted the weight forward without moving mass. That means the front will have more force on the tires creating more grip and conversly, less grip from the rear tires. Adding to things though, is that you still have the same mass and thus moment of inertia pulling the back out in a corner. If you can adjust it so that your level again, I think you might find what your looking for. What was the motivation for the lowering more in the front? |
| The Following User Says Thank You to Calum For This Useful Post: | koevasi (10-08-2013) |
#426 | |
I would do 0 toe in front, a little less toe-in for the rear. Then maybe add a front swaybar. OR raise the front slightly. Seeing some in-car video would help too....gotta be smoooooooth with a car like this! - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | koevasi (10-08-2013) |
#427 | |
But yes, raising the front might help slightly in this case by changing the roll center height. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Calum (10-07-2013) |
#428 | |
That Guy
Thanks |
#429 | |
Drives: FR-S Whiteout
Consistency is probably the top priority in most instances. Also adaptability to all scenarios, circuit, autocross, and canyons with minor adjustments. A streetable car that is capable of throwing down some fast runs on circuit and autocross is was most people *points to self* are after.
Intent > Content
cowardice is the mother of cruelty. |
#430 | |
i'm sorry, what?
Drives: Canada
First, define fast. If fast is “top contender in your class,” then you’redelusional to think that you could build a jack-of-all trades car and becompetitive at every type of venue. Especially when you start factoring in modification rulesfor whatever series you’re participating in. If fast is “turn some heads,” then a trained right footand a completely stock car can do that for you. No need to spend a cent. (okaymaybe tires and brakes, but that’s only so you can stay out longer) If fast is “kill some porsches at my local HPDAs” thenyou just need to add another 100hp or so and train your right foot very veryvery well. Batteling rich folk who can’t drive on large tracks is all aboutpower, cuz they’ll make it really difficult for you to pass during corners, soif you can match their corner acceleration they’ll fold like a house of cards.
#431 | |
"Fast" is a relative word. For the sake of this discussion what I mean by "fast" is faster than a similarly equipped car that doesn't not have the spring rates dailed in to a given tire. This is not taking driver ability into account. I mean having the spring rates dialed to match the tires so that the car is balanced and controllable, predictable at speed in each of the different scenarios with only adjustments to alignment and tire pressures to suit. Again, only talking about springs and tires. I don't think there has to be a huge compromise to acheive this.
Intent > Content
#432 | ||
Yay this thread is back.
As it sits, if I'm going for an all-out DGAF time attack lap where I'm holding nothing back (overdriving the car), I can get 2-3 laps before the tires start to overheat. (2:01-ish pace at BW) If I'm going at a brisk 95% pace with very clean driving (e.g. for the purpose of a video or a ride-along), then I can get 5-8 laps before the tires start to overheat. (2:03-ish pace at BW) Quote:
Sidewall flex, tread squirm, and loading impulse. Let me know if you want me to go into detail. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Racecomp Engineering (10-07-2013), solidONE (10-07-2013) |
#433 | |
That Guy
![]() Also, could you give and few examples like, for RS3's I would run such and such springs rates with proper damping. But with V12's I'd run ______ spring rates. |
#434 |
Yeah the shorter version of my question. I'd also like to know how the "east coast shops" like to set up their tire/springs for circuit auto cross and dual duty 86's.
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | Calum (10-07-2013) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
