Old 10-04-2013, 09:22 AM   #43
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Originally Posted by shiv@vishnu View Post
I didn't see any need to make any changes to fuel mapping since the engine is pretty insensitive to fueling at low engine speeds. Easy enough to play around with in Tuner Pro
I noticed that the per-cylinder compensation for was reduced a bit from the stock values. What was your rationale, if you don't mind sharing, for this? I am guessing that the stock values are probably compensating for increased cylinder temperatures due to the exhaust and cat's proximity.
FrX is offline   Reply With Quote
Old 10-04-2013, 12:51 PM   #44
brn12345
brn12345's Avatar
I would think that the timing offset for cylinders 1 and 2 are related to the oem unequal length header. Or is it something inherent in the boxer engines that one bank runs differently to the other due to rotation of the engine? I just don't see why timing has to be reduced due to heat of the exhaust.
brn12345 is offline   Reply With Quote
Old 10-04-2013, 01:18 PM   #45
jamesm
Originally Posted by Fast_Freddy View Post
I can't data log or re-tune this flash but have no need to either.
...as of today.
Old 10-05-2013, 03:49 AM   #46
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Is there a website/database available for the different tunes? I am assuming access or a link is provided upon purchase?/ or can we see the amt/ number of maps already available? I am really interested in this, loving those torque curves.
Maverick22 is offline   Reply With Quote
Old 10-05-2013, 08:11 AM   #47
Mike86
Drives: Scion frs
Yeah theres a few maps there available for everyone on the site no need to purchase to see the maps!!
Mike86 is offline   Reply With Quote
Old 10-05-2013, 01:07 PM   #48
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Stupid question.....but are changes only made to WOT tables and not to part-throttle tables? If that's true, then would it mean any improvements wouldn't be felt during everyday driving since I seldom WOT on the streets?
Fizz is offline   Reply With Quote
Old 10-05-2013, 01:23 PM   #49
JT86
There is noticeable difference during daily driving. I rarely go WOT but the added torque in the 2500-4000 range makes daily driving much more enjoyable. Accelerating from a stop at part throttle is much smoother because the dip is near gone.
JT86 is offline   Reply With Quote
Old 10-06-2013, 10:56 PM   #50
Maverick22
Maverick22's Avatar
Are there any discounts for forum members or military? I am willing to help sell this to locals as well.
Old 10-06-2013, 11:48 PM   #51
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Dyno Plot #1 - Stock (Run1) vs. OFT Vishnu Stage 1.0 (Run3)
Dyno Plot #2 - Stock (Run1) vs. OFT Vishnu Stage 1.1 (Run5)
Dyno Plot #3 - OFT Vishnu Stage 1.0 (Run3) vs. OFT Vishnu Stage 1.1 (Run5)
Its really nice to see the tq dip leveled off but I was expecting to see more significant gains when comparing it to stock. Perhaps I am not reading this correctly but it appears the 1.0 map (available to everyone today) provides gains of only 3 hp and 3 tq? The new tune provides 5-6 hp and 5 tq.
Am I missing something here? Maybe the point was focused on eliminating the tq dip and this is why we dont see the larger gains mentioned about this product in other forums?
thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 10-07-2013, 12:45 AM   #52
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I believe you're referring to peak gains.....there's actually more than 6hp gain in the mid-range. Peak gains are not really relevant for me, as I seldom rev higher than 5k during my daily commute.
Old 10-07-2013, 03:18 AM   #53
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
thanks
Hi,
As Fizz said, most tunes talk about max gains, not necessarily gains in peak hp. In Dyno Plot #1 (stock vs stage1 v1.1), max gains were around 15whp in the midrange (dip area) and about 15whp at 7400rpm. Also, I'd question any tunes which claim more power since there is really only so much you can squeeze out of these engines safely and consistently when running on pump gas. We could have posted a tuned run that made 5whp more and a stock tune run that made 5whp less to make a more dramatic result. But doing so would require posting the results of a tune that simply is too aggressive (not stable) and a run of the stock tune with the AIM set to the default value of 0.7 instead of letting it roll up to 1.0 to keep all other things equal.
The nice thing that about not selling a tune (we sell a tuning/storage device with free tunes), is that we don't need to necessarily hype it up the tune by claiming the best possible numbers by carefully selecting which dyno results to post. We are merely posting results that you would see in your car. And all the mapping data is out there for anyone to see or adjust. Although I don't see much need to for the vast majority of users.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Boofneenee (10-07-2013)
Old 10-07-2013, 09:12 PM   #54
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Thank you for explaining how to read the dyno graph. I also appreciate that you really emphasize the safety of the engine while designing tunes for the car. Looking better each day
FRS
Old 06-02-2015, 03:45 PM   #55
Darkparadox911
Drives: 2015 Subaru BRZ Pearl White 6MT
I wouldn't go near Visconti with my worst enemies car. Evidently they catch people's cars on fire after their tune, Mr. Visconti himself is a lying snake that doesn't care about his customers, and yea don't want my car to catch fire
Darkparadox911 is offline   Reply With Quote
Old 06-02-2015, 03:54 PM   #56
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Way to bring up a dead thread. BUT. This is Vishnu... not Visconti.
The Following 9 Users Say Thank You to DustinS For This Useful Post:
brandonblt2 (02-10-2016), carlitosway6891 (06-02-2015), Chimera (06-02-2015), drewbot (06-02-2015), D_Thissen (06-02-2015), hav0c (09-26-2015), phrosty (06-02-2015), Porcupint (06-02-2015), raven1231 (06-02-2015)
Perrin Stage I tune review brillo Engine, Exhaust, Transmission 18 12-10-2013 12:06 AM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 02:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 02:39 AM
Visconti Stage 1 NA Tune Pump & e85 Review CBR600RR Engine, Exhaust, Transmission 22 04-26-2013 11:36 AM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 02:30 PM
