Old 02-01-2012, 06:35 PM   #15
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by blur View Post
A car this oversteer happy isn't going to be easy to control after it has 600 hp.
I have yet to read a media review where they actually call the car "oversteer happy". They say the car is balanced, yet is easily controllable when the driver induces a drift.
We're talking about a car that has 200 HP. We're not discussing Corvette ZR1's et al.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-01-2012, 08:04 PM   #16
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I quoted Dave who was talking about a turbocharged 86. I'm not sure why you think I'm talking about the stock configuration.
Easily controllable STOCK.
Besides, have you seen Ken Gushi's FR-S? already in the ball park of 600 hp, and the car hasn't even came out yet. So it's been done and and it will be done again. I'll bet Gushi's not running a square setup.
Edit: looks to be that way.
Front- 19x8.5-inch (+45mm) w/ Hankook Ventus V12 EVO 225/35ZR19
Rear - 19x9.5-inch (+35mm) w/ Hankook Ventus V12 EVO 245/35ZR19
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 02-01-2012, 08:19 PM   #17
coyote
coyote's Avatar
Drives: Slowly
Under 300hp, square.
300-400hp, who knows.
Over 400hp, staggered.
coyote is offline   Reply With Quote
Old 02-01-2012, 09:33 PM   #18
Dimman
Kuruma Otaku
Dimman's Avatar
I think that Scion may be happy if a lot of RWD noobs get this car and go staggered for the RWD/drift look. More understeer = less wrecks.
Because titanium.
Old 02-01-2012, 09:44 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think people tend to greatly overestimate the effects of staggered vs. non-staggered. Camber and toe settings will have a more profound effect on handling balance than stagger. But then this car won't have front camber adjustment, will it. Doh...
Old 02-01-2012, 10:22 PM   #20
fatoni
im going to say that staggering in a car that wasnt designed like that is a bad idea. i guess it can be done but greddy can kind of get away with things because they can make car parts. nobody posting on this forum is going to figure out objectively how that is changing what is happening and how they should design suspension to allow for it
Old 02-01-2012, 10:33 PM   #21
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I really doubt that. There are a few guys on this forum (myself included) that I would be very surprised to see not do exactly that.
old greg is offline   Reply With Quote
Old 02-01-2012, 10:34 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
PLENTY of people on these forums are perfectly capable of tuning suspension parameters to deal with handling changes with a staggered setup.
Plenty of us WILL figure out, objectively, what is happening to the balance and will know how to optimize setup to take advantage of whatever tires we fit.
Getting good handling balance isn't rocket surgery. And 20-30mm stagger isn't going to make as huge a difference as you might think.
That said, I don't see any benefit to going staggered, unless it's not possible to fit wider tires up front.
Old 02-01-2012, 10:35 PM   #23
coyote
coyote's Avatar
Drives: Slowly
Lower strut mounts will likely has eccentric bolts from factory and of course you will be able to get or make adjustable tops.
Old 02-01-2012, 10:37 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'll be pleasantly surprised if it's adjustable. If not, of course there are other ways...
Old 02-01-2012, 10:47 PM   #25
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I think camber plates are going to be a pretty common upgrade.
Originally Posted by MotoIQ.com
No provision for camber or caster adjustment is present on the stock car, at least this stock prototype
http://www.motoiq.com/magazine_artic...cion-fr-s.aspx
Old 02-01-2012, 11:10 PM   #26
Ryephile
Hot Dog
Ryephile's Avatar
Yes, because "everyone" will be running a boosted-to-the-moon EJ25 within minutes of signing their 6 year loan.
The OP didn't mention such absurd context, and Dave was making fun of such lunacy.
Old 02-01-2012, 11:22 PM   #27
coyote
coyote's Avatar
Drives: Slowly
I think you're right, but I'm not so sure they will be necessary on anything that isn't wearing slicks.
This car has very different specs to those that the usual back yard racer is used to.
Old 02-01-2012, 11:34 PM   #28
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I meant it more in the sense that there are apparently no eccentric camber bolts in the front suspension.
