Old 09-18-2013, 03:44 PM   #29
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Originally Posted by mad_sb View Post
I like the fine learning table change, thats about the same values i am using now. In stock form we only seem to use 3 of the 5 bins... I noticed that adding more resolution helps limit timing changes to the area they are needed and ehlps you quickly spot areas that may need some work, if you have a tool that can view the fine learning table in ram.
The Torque change in the dip is impressive.... retarding both cams in at the bottom of the dip, relative to v 1, really seems to help. i never had time to play around with phasing both cams together on the dyno when i did my sweeps so it's great to see the results. i suspect there may be some more gains up top by doing the same, at least there were for me, retarding both together from 7,000 and up.
Time to start asking some questions, I've done hours of tuning with HPT on GM platforms but this new software is presently greek to me.
Basic question. The tables themselves you've posted picture of. Timing and VVT. The axis's. I understand RPM down the side. What is represented across the top. I've seen the same increments in numerous maps.
RPM X ????
FRSFirestorm is offline   Reply With Quote
Old 09-18-2013, 03:49 PM   #30
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Rpm x Engine Load. At wot, a naturally aspirated car will see a load of approx 1.0 at low rpm, ramping up to around 1.2 at 7000rpm. This will be a viewable channel once datalogging is enabled.
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
FRSFirestorm (09-18-2013), MyRx (09-18-2013)
Old 09-18-2013, 03:55 PM   #31
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I don't consider any of it to be inexpensive. My EcuTek tune and license will be sold with the car, and I can still sell my EcuTek cable. I have spent over $1500 for EcuTek and tuning thus far.
exclude expense from tuners.
$500 is inexpensive. I used to run K-Pro on RSX-S and it costed me more than $1,500 ( not including tuning expenses)
everyone's "expensive" term would be different but in general tuning expense, $500 is very inexpensive.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Shiv@Openflash (09-18-2013)
Old 09-18-2013, 04:27 PM   #32
MyRx
MyRx's Avatar
http://www.procedetuning.com/BRZ_FR-...s-4/index.html
Solved my win8 issues and updated to Off-The-Shelf (OTS) Maps v1.1. Time for another drive I suppose
Old 09-18-2013, 04:37 PM   #33
Shiv@Openflash
Drives: 2013 FRS
I've been running around with Stg1 v1.1 in my fully modded NA car (header back full catless) and I've been really happy with it. I think I may need to go back and re-calibrate the Stg2 tune and base it off of this tune. I'm especially happy with how the car drives at low rpm and between 4000 and 5000rpm. Low speed drivability is also improved.
flippy (11-07-2014), MyRx (09-19-2013)
Old 09-18-2013, 04:42 PM   #34
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Fronts: Camber -1.9, Toe -1/16". Rears: Toe -1/16", camber is not even in the rear (stock parts).
For sure. We haven't seen you in a while so yes, try to make it on 9/28 @ BWW.
Yeah. I'll try to make it. It's because of school I haven't gone to any meets. And gas is expensive!
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
MyRx (09-19-2013)
Old 09-18-2013, 06:12 PM   #35
MikeyBRZ
Drives: 2011 EB F150
Originally Posted by shiv@vishnu View Post
Good info. I'll come along for the drive too. Maybe FRSTEVE can come as well to confirm that he is actually a real person
Full disclosure: Steve has been a customer of our for 10+years. First with the WRX (old school NASIOC members may remember his name), then the BMW 335 (first single turbo 6at), and now with the FRS. He was also the person who talked me into getting this car.
I love the term old school nasioc..... how about impreza-rs.com members....if you were a member when it was called that, now your talking
I also look forward to seeing shiv's ,mapping
MikeyBRZ is offline   Reply With Quote
Old 09-18-2013, 07:18 PM   #36
fstlane
fstlane's Avatar
Drives: BRZ Limited
I spent a lot of time working on the all-importnt midrange torque region since this is where most people drive. That extra 15-20lbft comes in handy when exiting a corner.
This was the improvement I immediately noticed the most and my biggest complaint with the car. It's already made daily driving more fun and will be extremely beneficial in autocross where I'm getting killed on corner exit by higher torque cars. Thank you for the excellent base map!
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
Old 09-19-2013, 04:21 PM   #37
mad_sb
Drives: 2013 Asphalt FR-S
@shiv@vishnu,
Did you notice any change in fueling requirements with the cam changes in the dip between 1.0 and 1.1 base maps?
I'm about to steal your settings and see how they feel
Old 09-19-2013, 04:35 PM   #38
Shiv@Openflash
Drives: 2013 FRS
@shiv@vishnu,
I didn't see any need to make any changes to fuel mapping since the engine is pretty insensitive to fueling at low engine speeds. Easy enough to play around with in Tuner Pro
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
mad_sb (09-19-2013)
Old 10-04-2013, 03:04 AM   #39
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks for this. Do you have any exhaust or intake mods? I'm still a little uncertain on whether I should bother getting an ecu flash because my car will be kept stock (apart from a motiv catted front pipe), and I thought a 12hp and 15ft/lb wouldn't even register on the butt dyno
Fizz is offline   Reply With Quote
Old 10-04-2013, 03:29 AM   #40
Shiv@Openflash
Drives: 2013 FRS
You will most definitely feel it. That's a 10% increase in torque in certain RPM ranges. Ranges where you spend most of your time in too.
Fizz (10-04-2013)
Old 10-04-2013, 07:52 AM   #41
fstlane
fstlane's Avatar
Drives: BRZ Limited
The only intake and exhaust mods I have is a drop in air filter.
Old 10-04-2013, 08:16 AM   #42
regal
Drives: Scion FR-S/Toyota Yaris
@shiv@vishnu,
What your posts describes with the v1.1 in in limiting the egr and other emissions bs really hit home for what I hope to do with this car. I'm thinking it will be the starting point for a lot of tunes going forward, really makes sense to base stg2 off 1.1 imho.
Were you able to tackle the stock part throttle low-mid rpm high load knock issues yet ?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Perrin Stage I tune review brillo Engine, Exhaust, Transmission 18 12-09-2013 11:06 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
Visconti Stage 1 NA Tune Pump & e85 Review CBR600RR Engine, Exhaust, Transmission 22 04-26-2013 10:36 AM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 01:30 PM
