Old 10-03-2013, 07:08 PM   #1
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Solid diff mounts
I just ordered megan solid diff mounts. And now looking at it i dont know if itll be an ez install. Can someone tell me if its a real difficult task or not. I couldnt find any inserts so this is the route i went. Does any one with the inserts have problem with noise? Just wondering because if u do then if i put these solid mounts in im sure its gonna be real noisy.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 10-03-2013, 08:12 PM   #2
sosick
fastest frs in sbg
sosick's Avatar
Been looking around and I can find anyone who put solid diff mounts in
2014 firestorm frs
Old 10-03-2013, 08:26 PM   #3
Trac Toy
Trac Toy's Avatar
I've got the white line inserts in my car. It very noticeable the increase in driveline noise. I can only imagine what solid mounts will sound/feel like.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 10-03-2013, 08:44 PM   #4
sosick
fastest frs in sbg
sosick's Avatar
Is it bad? Do u hear it over ur exhaust or feel the vibrations at idle?
2014 firestorm frs
Old 10-03-2013, 09:52 PM   #5
Trac Toy
Trac Toy's Avatar
I get driveline whine at part throttle loads, thats just noise being transferred into the body, and milling around town if your not super smooth on your clutch engagement you'll hear the rear end clunk a little bit. But on the brighter side of things it's a whole lot more responsive back there.
If anything go the white line route, it's easy to install, not a solid mount, and easily reversible if your not happy with the results, and relatively cheap to purchase.
.o0+Eric+0o.
2013 FRS 6MT
The Following User Says Thank You to Trac Toy For This Useful Post:
sosick (10-03-2013)
Old 10-03-2013, 10:18 PM   #6
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
With a solid diff mount unless you want 100% "because racecar" noises 100% of the time you're gonna hate it.
TheseColorsDontRun is offline   Reply With Quote
The Following User Says Thank You to TheseColorsDontRun For This Useful Post:
sosick (10-03-2013)
Old 10-03-2013, 10:53 PM   #7
sosick
fastest frs in sbg
sosick's Avatar
Couldnt find any. Thats y I bought these. I needed them for this weekend. Now im kinda regretting it.
2014 firestorm frs
Old 10-03-2013, 10:54 PM   #8
sosick
fastest frs in sbg
sosick's Avatar
Thats what I dont want. I had that for my mazdaspeed protege n my b16 ek hatch. And I hate it. I like the silence of my car with no vibrations.
2014 firestorm frs
Old 10-03-2013, 11:02 PM   #9
TheseColorsDontRun
You may as well cancel your order. You're gonna hate it if you want quiet. Get the Whiteline diff inserts if you want more support with minimal, albeit some, additional NVH.
sosick (10-04-2013)
Old 10-03-2013, 11:05 PM   #10
Trac Toy
Trac Toy's Avatar
Well, if you need it for the weekend, then stick it in and see what you think. If its way too much sell em and get the white lines.
.o0+Eric+0o.
2013 FRS 6MT
sosick (10-04-2013)
Old 10-03-2013, 11:21 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if it's something that would need to be pressed in with the OEM bushing pressed out.. you're gonna have to drop the entire rear cross member and disconnect everything from it... and take it to a shop to do the pressing for you
have fun!
Old 10-03-2013, 11:43 PM   #12
Trac Toy
Trac Toy's Avatar
have fun!
That's an excellent point. Another plus for the white line inserts, you can do them on your back in the garage!
.o0+Eric+0o.
2013 FRS 6MT
Old 10-04-2013, 12:22 AM   #13
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
20130921-CuscoDifferentialBrace-004-2 by VictorN07, on Flickr
I installed the Cusco diff brace. It's not going to be super fun doing this.
Tips
+ Removing the rear wheels gives you a good deal of more working room
+ Have a breaker bar to break the diff bolts loose.
+ You will want to drop the sway bar so you can get the wrenches/ratchets on the back of the diff.
+ Undoing the bolt that holds the lower control arm to the rear crossmember makes it 100x easier, but it may mess up your alignment. IT IS POSSIBLE TO DO IT WITHOUT LOWERING THIS END OF THE CONTROL ARM. I DID. You will need the right blend of combination wrench and adjustable wrench to get in there to hold the nut.
+ I removed a section of the exhaust to make room to work the wrenches as well.
Yea it is a lot of extra work but it may be worth it.
It looks like the Megan is a replica of J2 Engineering or vice versa. The photos I've seen of each (Megan is pink? J2 is blue?) show different bolts. The J2 ones look too small to hold the brace to the crossmember; the holes are very large. The Megan looks like they come with rings. Please let us know what you end up getting with your brace.
The kit came with super nuts to hold the cusco brace on, if I recall correctly it took like a 24mm box wrench to hold the nut.
F1point4 is offline   Reply With Quote
Old 10-04-2013, 03:52 AM   #14
koevasi
koevasi's Avatar
Drives: 1
even my whiteline diff inserts make the car sound like a touring car with a dogbox, but I LOVe the way they make the car feel.
koevasi is offline   Reply With Quote
The Following User Says Thank You to koevasi For This Useful Post:
sosick (10-04-2013)
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
Turn in Concepts (TiC) solid aluminum steering rack bushings review CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-14-2017 08:24 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
TIC Solid Steering Rack Bushing's Track Review track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-17-2013 01:24 PM
Solid one piece strut bar brace brzzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-16-2012 01:03 AM
