Old 10-02-2013, 12:42 PM   #253
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
guys, could you NOT quote every photo if the post is on the same page...its annoying.
anyways that looks pretty good, the fact you're only a +42 offset is your saving grace, under hard cornering i think you will rub in the front fender, the rear can just rub itself out.
and damn that rear camber is out of sack i bet it feels great on the street though.
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
GTB/ZR-1 (10-02-2013), WHITE (10-02-2013)
Old 10-02-2013, 01:01 PM   #254
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
There is a good chance he is rubbing both the firewall/fender liner and the frame rails with any kind of steering lock.
I agree, there is a good chance. Im rubbing my frame rail and firewall at full lock with 255/40's on a 18x9.5 +38, not sure what offset hes at but im sure his smaller sidewall equals out to the same rubing as i have, wich is completely tolerable, tho im stock ride hieght and alignment.
pulling the caster forward some would help alot with going bigger. Ill be doing that with mine. So much to buy still.
WHITE is offline   Reply With Quote
The Following User Says Thank You to WHITE For This Useful Post:
HRTROB (01-14-2014)
Old 10-02-2013, 01:37 PM   #255
powfrs
Drives: 2013 FRS
That looks realy good GTB!!!!
powfrs is offline   Reply With Quote
The Following User Says Thank You to powfrs For This Useful Post:
Old 10-02-2013, 02:19 PM   #256
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Thx gents, I'm sure the full thrashing will bring to light any real issues. Yeah & that +42 seems to be a good compromise for the setup.
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
Jive Turkey (10-02-2013)
Old 10-02-2013, 07:14 PM   #257
mpg
Drives: black 2013 fr-s
Originally Posted by Thongpocket View Post
17x9 Axis OG with S04 pole position 245/40/17 on Eibach Sport lines.
Sent from my XT1080 using Tapatalk 2
What's the offset and camber in the front?
mpg is offline   Reply With Quote
Old 10-02-2013, 07:58 PM   #258
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
What is considered "maximun meat" (size/width) for a non dropped suspension? I'd be willing to use small spacers and a basic crash bolt to help tuck the top in on the front. Low driveways and Cali roads are keeping me from lowering or compromising the ride quality.. Thanks Meatchachos!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 10-03-2013, 02:30 AM   #259
Kostamojen
I've seen 235's all around fit no problem and I hear 245's fit in the rear stock. Not sure what else works stock but I'm curious too since I'm keeping the suspension stock as well.
Old 10-03-2013, 03:35 AM   #260
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
Don't go too wide on stock wheels... It'll look silly!
boxer 2.5 is offline   Reply With Quote
Old 10-03-2013, 07:04 AM   #261
WHITE
Thats pretty neat
WHITE's Avatar
Im still on stock suspension, i fit 255/40/18 up front and 265/40/18 in back. 18x9.5 +38 all around. It pokes a little, and only ever rubs at full lock in front and full compression in rear.
If you care about the little bit of poke and rubbing but still want to be wide, id say get some camber adjustable tophats for the front, i think camber bolts will push the tire into the strut before you fix any poke and higher offset wheels would definetly cuase more problems.
As for the back going slightly higher offset will fix the poke. You might even be able to fit a 275 in the rear with a higher offset wheel, id have to go check how much room i still have to know for sure. Other option would be getting adjustable lca's and adding a bit of camber.
All problems could be solved by just running coilovers at factory ride height tho, then you can run whatever everyone else is running.
@Norkoastal , sadly switching to wider tires/wheels is going to affect the ride quality. Your car will feel a bit stiffer.
Old 10-03-2013, 10:44 AM   #262
DAMotorsports
Drives: 2013 Scion FRS "Raven"
I can tell you that the 42 off is a magic number with the 275/35. We have been running this for some time and have put several track days on them. There is always a trade off with size. We are still playing with spring weights on our car and if this turnout the way we think they will we might even drop the car a touch more. We did a lot of research to get the biggest tire on this car useing the stock fenders and a square setup.
DAMotorsports is offline   Reply With Quote
The Following User Says Thank You to DAMotorsports For This Useful Post:
GTB/ZR-1 (10-03-2013)
Old 10-03-2013, 04:29 PM   #263
Norkoastal
Norkoastal's Avatar
Thx for all this info.. I'm not looking for any poke or width beyond 7.5 (stock limit), more or less just a better fill in the wells (max meat) with a more flush look (light spacers/camber bolt).
CO>CA Cartel
Old 10-03-2013, 05:31 PM   #264
WHITE
Thats pretty neat
WHITE's Avatar
Appologies, didnt know you wanted to stay stock wheels too. Thought you just ment stock suspension. Wish i could help you out, but i didnt even bother with doing anything with my stock wheels. Definetly dont think i would go over 245 on a 7.5 but thats about all the info i can accurately give you. sorry.
Old 10-04-2013, 12:14 AM   #265
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I'm not sure what "meaty" is maybe I missed it.. 245 and bigger???
I have 245/40 18 on gramlight 57DR 18x9.5 +38 using RSR sport-i coilovers
Again, hope that's meaty enough.. If not, I'm sorry I'll delete this, so far only rubbing was the right front fender and of course the rear bumbler tabs.. I raised it about a 1/4" and all seems good
Gixxersixxerman is offline   Reply With Quote
The Following 10 Users Say Thank You to Gixxersixxerman For This Useful Post:
350zgoingFRS_lol (05-05-2014), Ammunition (09-27-2015), GTB/ZR-1 (10-04-2013), imovertheinternet (08-08-2016), JEFFSTYLE (01-05-2014), MAPerformance (10-11-2013), Mr. (11-03-2013), Silver Ignition (05-03-2014), SkAsphalt (10-09-2013), thatWESguy (10-06-2013)
Old 10-04-2013, 12:31 AM   #266
DAMotorsports
@Norkoastal put a set of 235/40/17 I'm your stock rims and you will be happy!! We're used that setup prior to the jump to our 275/35/18.
Norville Rogers (08-27-2016)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
