Old 10-02-2013, 03:50 PM   #15
B_Rad
B_Rad's Avatar
Drives: 2013 Scion FR-S/Raven Black/6 sp mt
It took me about 18-20 hours to install Air on my FR-S. I've done my fair share of lowering cars (about 10 on springs). I had the actual airstruts on 1.5 hrs. It's running the wiring (removed passenger seat, backseat, trim on bottom of door, trunk floor), mounting the compressors, making something for the relay's and tank to sit on, making a false floor (1/8" plywood wrapped in black duck cloth). Then getting everything set up and installed, running lines checking for leaks (fixing leaks). Adjusting the struts for ride/stance preference. I'm sure the shop is giving you a little high of a qoute but installing air isn't the same as putting on coil overs or lowering springs.
I could have gotten it installed in prolly half that time if I just threw everything (managment system) in the trunk, but I prefer to have it look well done and be able to return the car to stock (if needed).
Pic: Before the fabric was put on.
B_Rad is offline   Reply With Quote
Old 10-02-2013, 03:50 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Pertaining everything, but the Airlifts, do it yourself.
Why do you need a shop to install HIDs???
It took 30 minutes to install arms.
Go to a DiscountTire, Firestone, etc for the wheel related stuff.
Old 10-02-2013, 04:23 PM   #17
MikesFRS
MikesFRS's Avatar
Drives: it like he stole it!!
Ill charge you 1000 to make it look like you drifted into a curb
MikesFRS is offline   Reply With Quote
Old 10-02-2013, 05:06 PM   #18
Shagaliscious
Drives: Firestorm FR-S (MT)
Originally Posted by Admired View Post
6-9 months haha impossible
[ame="http://www.youtube.com/watch?v=bz-9WeHDPV4"]Billy Madison - 69 - YouTube[/ame]
The Following User Says Thank You to Shagaliscious For This Useful Post:
onefitz (10-02-2013)
Old 10-02-2013, 06:12 PM   #19
wallace03
wallace03's Avatar
Drives: WRB BRZ
Originally Posted by jadewbj View Post
Did the CNC all the parts on site? No way even taking a universal kit and making it fit takes that much time.
6-9 months? Are they melting down metals and hand making the kit? Lol
haha i forgot he's always having the guy change something in the interior as well, and i cant remember but i think he also told me some of the parts were hard to get or needed to be shipped from japan because his car doesn't have much of an aftermarket market... either way it shouldn't take that long. Here is a pic he sent me not too long ago https://scontent-b-mia.xx.fbcdn.net/...b4&oe=524E6B14
wallace03 is offline   Reply With Quote
Old 10-02-2013, 07:50 PM   #20
semowashere
Wife’s Car
I'm bagged and it took the shop less than 8 hours to install kit. The install cost about 700 dollars. I would strongly encourage you to install most of that stuff yourself. Also, I would go ahead and order some camber bolts for the front of your car. When you spin the bag down you can tuck rim easily in the back. However up front, without the camber, (depending on wheels) you will hit the fender.
semowashere is offline   Reply With Quote
Old 10-02-2013, 08:16 PM   #21
Hardrock4445
Hardrock4445's Avatar
My take:
1.) Air lift system - never done one, my guess would be 10 hours by professional shop, think: replacing suspension, running all necessary B+ and ground neat, clean and properly. Running air lines and check for leaks in system, proper road test and post install inspections.
2.) Headers - 1 hour includes time to torque all bolts and re-check all gasket seals after installation.
3.) HID - 1 hour to hook up properly, run wires and install ballast boxes cleanly. Re-check all work.
4.) JDM Splitter - 2 hour to install all 3 pieces and any adjustment needed to ensure structural stability and flushness. Re-check for rattles and fitment gaps after road test.
5.) Megan toe arms - 1 hour for both together. Road test and re-check
6.) Stance LCA's - 1 hour for both together. Road test and re-check
7.) Fender Rolling - 1 hour PER corner to be done properly and protect paint. remember this has a high potential to be messed up with one slip. So any shop is really gonna take their time on this one......
8.) 9.) 9.a) Wheel and tire mount, balance and install. 1-2 hours. If properly done: Mount, measure road force and balance, swap and match mount tires as needed to achieve best initial balance/road force combo. then finishing balance. Install and torque wheels to prevent damage. Road test for final vibration testing.
10.) Rattle, 1 hour. Will need to remove front pipe, and heat up (torch work)/clearance slightly to prevent rattle once rattle location is determined.
11.) Proper Alignment on Modded Car - 2 Hours
By looking at this logically I can see 25 hrs. ± 5 hrs. Most likely not less than 25 hrs. = 25-30 hours. Now given a reputable shop has a supply/demand labor rate of around 100-140 per hour.
25@100 = $2500
25@140 = $3500
30@100 = $3000
30@140 = $4200
most likely:
25@120 = $3000
30@120 = $3600
My quick figuring comes up with a high/low of $2500-$4200 estimates based on not knowing your local shops labor rate, work quality, customer satisfaction. I would say the shop is spot on in their estimate if they are reputable and produce quality work.
Now for the people that will flame this: I understand that some of these items can be installed faster than the times I estimated above. Now ask yourself this, Would you want someone that you are paying to install a bunch of quality and $$ parts to just throw them on as quick as possible with no care to quality, longevity, and just give you your car back? if so YOU are crazy. These shops have a reputation they want to build and protect.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following User Says Thank You to Hardrock4445 For This Useful Post:
Old 10-02-2013, 09:26 PM   #22
wootwoot
Drives: FRS
Install it all your self and use the $3500 to buy a turbo system or supercharger. Problem solved.
Old 10-03-2013, 08:48 AM   #23
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I'm a little confused about the fender rolling. Aren't our fenders rolled from the factory?
Old 10-03-2013, 08:57 AM   #24
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by JesseE View Post
3500$ is including parts? if so doesn't seem horrible depending on cost of that airlift suspension... if its just labor... they misquoted you, no way in hell it takes 35 hours to install all that stuff...
I would say 5-8 hours max... 500-800$ is what I would charge you @ my shop here in phoenix...
prices like these are common in small towns/cities where they rarely touch anything but Mustangs.
If you live far from a good shop like yours best bet is DIY.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 10-03-2013, 09:06 AM   #25
jadewbj
jadewbj's Avatar
Your estimates are a little higher than mine but not far off. Shops must be pretty expensive in your area. In Central Florida those are dealer prices.
Originally Posted by Hardrock4445 View Post
My take:
25@100 = $2500
25@140 = $3500
30@100 = $3000
30@140 = $4200
most likely:
25@120 = $3000
30@120 = $3600
jadewbj is offline   Reply With Quote
Old 10-03-2013, 01:26 PM   #26
Hardrock4445
Im in N.Y. EVERYTHING is higher here..... Avg mechanical labor rate $70-90 in the area. Performance shops which are few and good ones are even fewer $100-125
Edit: I would also install everything myself anyways, but I have the time, tools, equipment and ability to do so as well, so that is just my estimates based one what I feel a proper job would take.
Injectors installation kaybee123 Forced Induction 27 03-08-2016 09:26 PM
FA20CLUB TURBO KIT GREAT POWER AFFORDABLE COST $3500 FA20Club.com Forced Induction 92 02-13-2014 10:50 PM
RallySportDirect 2011 STi Shop Car for Sale. Over 50K in Parts, under 3500 Miles! RallySport Direct Cars for Sale/Trade 14 06-21-2013 11:52 AM
FA20CLUB V2 Turbo Kit On Sale @$3500+ FA20Club.com Forced Induction 24 03-30-2013 02:43 PM
Prices quoted at time of deposit. AGM6789 AUSTRALIA 45 06-08-2012 08:29 AM
