Old 10-01-2013, 05:15 PM   #1
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Smile Toe Arm: Is it a Must ?
Now I got a KW V3 and a Cusco LCA.
The alignment shop told me that I would need rear toe arms. The stock cam bolts to adjust the toe is not enough. And it would even be DANGEROUS without a toe arm.
I thought that a little bit toe in on the rear is ok right? got confused.
Can the toe be correct to 0 on the rear without those arms?
I am going to drop about 1''-1.2'', -2 f and -1.5 r camber.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-01-2013, 05:19 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
Running similar camber to your goals I was unable to zero out my toe. I actually was stuck with improper thrust angle. Toe out on one side, toe in on the other ...
Moral: buy toe arms
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-01-2013, 06:49 PM   #3
wallace03
wallace03's Avatar
Drives: WRB BRZ
Your signature is contradicting your topic yo.
wallace03 is offline   Reply With Quote
The Following 6 Users Say Thank You to wallace03 For This Useful Post:
Anthony (10-02-2013), enjoi23 (01-08-2014), Flat Black VW (01-07-2014), frslee (10-01-2013), Jive Turkey (01-18-2014), wparsons (01-07-2014)
Old 10-01-2013, 07:02 PM   #4
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
My guess is he's a Coach, a Manager or a Politician.
BirdTRD is offline   Reply With Quote
Old 10-01-2013, 08:06 PM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The CSG BRZ does not have any toe arms. Zero toe all around no problem...
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Sportsguy83 (10-01-2013)
Old 10-01-2013, 08:10 PM   #6
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
I was able to get -1/16 toe per side with -1.2 degree camber with LCA so -1.5 should be possible. The more neg camber you will get more toe adjustment for the rear.
garfull is offline   Reply With Quote
Old 10-01-2013, 08:11 PM   #7
frslee
Just drive it
Drives: 13' FR-S
DIY...
frslee is offline   Reply With Quote
Old 10-01-2013, 08:23 PM   #8
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I'm on H&R super sports (about 1.5" in the rear), with about 2* neg camber on racerx lower control arms, and stock toe arms. My alignment shop was able to get toe to 0 on both ends without any issue.
Zach3794 is offline   Reply With Quote
Old 10-01-2013, 08:25 PM   #9
mfbmike
Drives: 2013 FRS, 2008 R32
I've got a toe kit from SPC performance but that requires pushing in their bushing into the existing toe arm as far I can tell.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Old 10-01-2013, 08:45 PM   #10
Figo
Figo's Avatar
lol kinda busy cuz just graduatin from college and start my new job。 i actually changed lowering springs on my old car by myself。
Old 10-01-2013, 08:48 PM   #11
Figo
Figo's Avatar
DIY...
i might do it myself now cuz the labor fee is too much。 changed lowerin springs on my old car by myself before。 now just kinda too busy these days
Old 10-01-2013, 09:24 PM   #12
wallace03
wallace03's Avatar
Drives: WRB BRZ
I was just messing and congratz
Old 10-01-2013, 09:30 PM   #13
Figo
Figo's Avatar
lol thanks。the bolts on my old car was rust。I used WD40 and take me half a day to take them off。Building a car during college years is a good memory actually。
Old 10-01-2013, 10:07 PM   #14
mfbmike
i knew that。those r not arms actually
Correct.
Just saying there are alternatives. I might not even end up using them if you're at all interested in them.
