#29 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
What's happening in your situation is that you're quickly going positive up front while the rear is staying closer to square with the road. So to counteract this, you need more negative camber up front so you can afford to lose some to body roll. Reducing the rear camber will nudge it further into positive and reduce rear grip slightly, to assist with rotation. |
| The Following User Says Thank You to Draco-REX For This Useful Post: | wrussi (01-22-2014) |
#30 |
That Guy
Drives: 2013 asphalt FRS MT
![]() Now we just need @Sam Strano saying he needs more front spring rate, and @ZDan to chime in about struts and camber gain. ![]()
#31 |
That Guy
I'll add my opinion to, not because it matters but because I have one...
I, also, don't think a rear sway bar is the right way to go, not until you get the alignment sorted at least. If you find you're still understeering then I'd look at the softest adjustable bar available. This car really doesn't conform to the norms when it comes to suspension tuning. |
#32 | |
Drives: 13 BRZ Limited WRB
If any bar, I would look at an adjustable 16mm rear one.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | Calum (09-30-2013) |
#33 |
That Guy
#34 | |
This is the sheet:
#35 |
That Guy
To my understanding, a touch of toe in up frontmight help, and would be more stable at highway speed. It should make the front tires wear better to consider the amount of deflection in the stock bushings. But your present settings seem to be in the generally accepted sweet spot.
#36 | |
Drives: Mazda 3
More independent rear suspension on a RWD car is faster... |
#37 | |
Corner Junkie
A little bit of toe OUT up front will improve turn-in feel. Toe IN is good gor high speed stability, but hurts feel. In the rear, tow IN will help reduce "snap" oversteer. This is good for track use. Toe OUT in the rear will lead to oversteer. Only good for AutoCross on tight courses and Gymkhana, not considered safe for street use or track use. So I just like 0 all around. It's also much nicer to the tires too, especially when running aggressive camber settings. |
| The Following User Says Thank You to Draco-REX For This Useful Post: | CSG Mike (10-01-2013) |
#38 |
Corner Junkie
I'm also one of those heathens that thinks SAI isn't a big deal. But that's for another discussion.
| The Following User Says Thank You to Draco-REX For This Useful Post: | Calum (10-01-2013) |
#39 |
Drives: GT86
The problem with adjustable bars is it effects the drop link angle which skews the curve of the bar.
For the price of a bar, and the 10 minute installation, just go get one and try it out. It's a no-brainer. |
#40 |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
when looking in to rear sway bar you have to think that our torsen type Lsd really don't have to have that rear inside wheel spinning in the air. big loss of power their. then you have to upgrade to clutch type lsd so more money again. I would go for stiffer back spring's
#41 | |
i'm sorry, what?
Drives: Canada
this is why having your a-arms below parallel and shock travel is important.. macpherson strut properly setup can maintain a proper contact patch while the chassis is rolling within managable levels also castor...
#42 | |
![]() Especially when the rates overall aren't super high (i.e. with springs or softer coilovers like these). - Andy |
| Sway Bars: What's The Trade Off? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-24-2020 11:18 AM |
| brz and fr-s sway bars different? | 1010110 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-03-2013 01:43 AM |
| ST sway bars | bmxhotsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-09-2013 03:11 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
| Cusco Sway Bars? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-04-2012 05:31 AM |
