#57 |
Drives: FRS :D
Damn just installed the Alpine amp and I'm very impressed.
Ended ip using the metal shield of the oem amp and zapping the alpine to it. Made it so I could bolt it all down like oem and tuck all the wires away in a clean manner. Love it thxs for this info and thxs for the diy
Out of the FRS game
#58 |
So I did this install with the Alpine, but my components arrived damaged. Until I get the new ones I am just using the stock woofers. The problem I have is that there is a lot of static coming from the speakers now. The music is definitely louder and doesn't sound bad, but if I turn the amp gain near 1/2 way the static is really loud. I've got it right under 3/8ths right now. All the wiring looks correct, and I have the amp on "speaker", 2 channel and 60hz HPF. Changing the HPF settings or the channel setting to 4 doesn't make any difference. Any ideas? I was thinking it's just the factory woofers.. probably not.
#59 |
Drives: Asphalt FR-S
I did the install with the alpine and the metra harness, easy as pie. I already replaced the stock doors with Kicker CVT652 shallow mount subwoofers and wow what a difference. I have it turned to like 1/4th power and it still shakes the doors.
If I was going to redo the entire job I would have gotten the 4 ohm version of the kickers, the alpine amp isn't stable at bridged 2 ohm load. Right now its running a non-bridged 45w @ 2 ohms when it could be running a bridged 90w @ 4 ohm. Not sure what difference it makes but FYI the stock door speakers are 2 ohm. |
#60 | |
Drives: 2013 BRZ Limited
On the subject of static. I also have some coming from the speakers that is noticeable when no music is playing but does not change with the HU volume. I think this is due to the use of the factory ground in the harness (creates a ground loop) vs. using a short ground to chassis near the amp. In the near future (I have the parts, just need the time) I will be installing an Infinity Basslink sub/amp combo and checking into the ground static issue. I'll take more pics and post an install of the Basslink and update any findings/solution to the static. My goal is to end up with a very affordable and compact solution to make the stereo sound awesome with some more bass than what 6 1/2s can provide without compromising much of my trunk space or adding much weight. I had a Basslink in another car and while it doesn't pound like a pair of 12's, they do put out enough bass to satisfy most people.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#61 | |
Drives: FRS
(a wild lurker appears) Hello!
This thread helped me immensely, I'll give out thanks after I get a few posts under me (5 right?) I also have a light static that rises with HU volume, and I think zdr93523 is right, It's likely due to a ground loop caused by the change in grounding gauge (causing a resistance change from the cable supplied by the amp. My question, did either of you shorten the ground from the amp before attaching to the factory harness? I did not on initial install, and wired it directly to the factory harness full length. I did find the problem persisted but was diminished if I removed the HU inputs to the amp. My thought is that I'm going to get a terminal tomorrow and run the amps ground to the ground that's used by the factory amp behind the driver side rear panels, or possibly behind the trunk liner, I need to poke around to find a nice spot that's not painted. Any one elses input on how they did their grounding would be appreciated, (if I only need to shorten it that's cool.) Otherwise, I'll let you know if it improves the situation. oh, and atm I am also using the factory speakers. Quote:
#62 | |
Also I recently set up my alpine last weekend to compliment my jbl speakers and I get the same noise. I only get it when the volume hits near zero, but let's face it; nobody on this thread ran an aftermarket amp to have their volume at zero ! It can be a bit of a nuisance, so I will run a separate ground this weekend if or when I get time. I'll post my findings if anything changes. Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
#63 |
Drives: Silver Limited BRZ
So I just finished an install today and this thread helped me a lot. However, I did not re-pin my harness to the oem amp. I used a line level converter bought for 20 bucks at my local car audio shop spliced straight into the harness. I only have one problem as of right now. I spliced into the B+ wire running to the oem amp for my remote wire. Now I have constant power, car on or off. Sub works great, I'm just worried about draining the battery, so for now I'm leaving the remote wire disconnected while not in the car. Anyone have suggestions, or am I going to have to run it up to the HU?
I'm running the stock HU for the record. Sent from my HTC One X using Tapatalk |
#64 | |
#65 | |
#66 | |
Drives: FRS
I thought about doing this as well, if I did this i would have gone with a metra 1761 and wired the converter to that, that gives you the remote on output from factory
#67 |
Drives: FRS
My findings:
I reduced the ground wire to approx. 6in. and grounded one of the pins that held the factory amps shroud, same results. (I also tried to ground behind the driver side rear panel). I did find that reducing the gain helped, I reduced the gain to about 1/8, and if I turn the HU up it sounds pretty alright. I do not know (haven't compared) if the stock amp did any HPF, I set mine at 80hz. I have a JL power max wedge that I have the LPF set to 125 hz, and things sound pretty alright. I think Ill be trying out a set of the infinity kappa 62.11i's as suggested earlier in this thread, but I don't know when, ill report back with my findings on gain and noise for those at that time. anyone else try with their gain down at about 1/8 (first white tick) I figure the HU has 62 ticks no reason to try to get everything out of the first 20. I think to get more out of this amp without the dead air noise might require a new HU, others thoughts on this? **edit** I did find that removing the ground all together eliminates the noise issue, do not run your setup this way however. Last edited by Chimera; 12-08-2013 at 03:28 PM. Reason: additional info |
#68 |
I may turn my gain down just a tad once I get in there to install the Basslink. I have it set to about 1/2 way right now with the Kappa 62.11s. I also have Reference 3 1/2s in the dash with the factory tweeter bypassed. My EQ tapers the high frequencies to almost zero to balance the extra tweeter since both speakers are 2-way. I think I'll be able to balance this out once the sub is in.
#69 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
how do i get rca out from my stock headunit?
#70 |
Trust me, I'm the Doctor
You don't have it in the BRZ. You'll need something like an LC2 to do that.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| Wideband LC-1 wiring. | MattF | Forced Induction | 9 | 07-09-2013 09:33 AM |
| Wiring a sub in a BRZ | Shizuma | Electronics | Audio | NAV | Infotainment | 22 | 06-08-2013 01:02 PM |
| So is there a DIY yet for BRZ headlight wiring for the FR-S? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-25-2012 09:24 PM |
| x940bt wiring help | encity5 | Electronics | Audio | NAV | Infotainment | 10 | 08-31-2012 04:08 PM |
| Is foglight wiring in the car? | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-26-2012 11:54 PM |
