Old 05-27-2013, 01:32 PM   #15
Shaun.
Drives: '13 Silver BRZ Limited MT
I just did this today with a K&N, was fairly painless thanks to this DIY guide: http://www.ft86club.com/forums/showt...010#post881010
Pay special attention to step 4 and you'll be fine.
Shaun. is offline   Reply With Quote
Old 05-27-2013, 10:57 PM   #16
Rabble
Drives: Asphalt FR-S
Originally Posted by _hollywood View Post
Is there a thin red line exposed all around the filter when closed? My trd drop in is facing the correct direction and the clips on top closed but i can see the outline of the red surrounding the box when closed......weird
No, its a bad seal. You might see a bit of the red from the tab on the bottom of the filter but you most definitely should not see any filter stick out around the seal.
You really can't just wedge the two things back together and shove the clips back on. It's doable, but its not going to seal correctly on the bottom. They definitely could have made it easier but it's not too hard once you "get it". Just follow my DIY and you'll get it, the box wants to stay closed and the clips should just pop on without any forcing.
Sideways is a normal operating condition.
Rabble is offline   Reply With Quote
Old 09-30-2013, 02:50 PM   #17
soulever
soulever's Avatar
Drives: DGM BRZ Limited
Thanks for the post, just realized I did it wrong... going back to fix it tonight.
soulever is offline   Reply With Quote
Old 10-03-2013, 11:50 PM   #18
BlackyRose
Drives: 2013 Raven FR-S
Mine is doing the same thing. The rubber polyurethane border is exposed a little on 2 sides. Was this normal or did you figure out a way to have the filter totally enclosed without any part of it showing?
BlackyRose is offline   Reply With Quote
Old 10-04-2013, 08:04 PM   #19
timerbob
Drives: 2013 FRS Argento
Good looking out. It's the little things people tend to overlook.
timerbob is offline   Reply With Quote
Old 10-04-2013, 08:08 PM   #20
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
First time I tried to install my K&N filter I didn't take the whole airbox out, just the back half. I put it back together but really had to force it, so I ended up redoing it - this time taking out the front half as well. That time it went in much smoother so I think I got a better seal.
I'll probably put in an actual intake at some point down the road (more for the sound than the performance gain, TBH) but I'm happy enough for now. I notice more intake noise at WOT than I did with the stock filter.
YMAA is offline   Reply With Quote
The Best Drop in Air Filter? FT-86- Engine, Exhaust, Transmission 46 06-05-2014 07:54 AM
Drop-in Filter huma Engine, Exhaust, Transmission 33 02-07-2013 02:47 AM
FS: Perrin drop in filter SubaSteve Engine, Exhaust, Bolt-Ons 4 01-21-2013 12:04 PM
FS: K&N Drop-in Filter DookDookDGM Engine, Exhaust, Bolt-Ons 4 01-19-2013 01:45 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
