Old 09-25-2013, 10:37 PM   #155
MikeW
MikeW's Avatar
Drives: 2013 BRZ | 2013 WRX | 1991 318i
This thread force me out of the stalk mode and actually had me checking my accounts for available funds!!
Any rec's on best shop to install a full blown kit in New Orleans area?
Thanks to those that spent the early dollars on these cars!!
MikeW is offline   Reply With Quote
The Following 4 Users Say Thank You to MikeW For This Useful Post:
Dipstik-sportech (09-26-2013), Frs300 (10-16-2013), mack4477 (09-26-2013), ravenblackfrs (09-26-2013)
Old 09-25-2013, 11:23 PM   #156
mike the snake
I'll second those comments.
My full Blown kit should hopefully be ready very soon. Looking forward to getting it installed and feeling some decent power. Stock, my BRZ is a dog.
It makes more noise than "go".
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
Dipstik-sportech (09-26-2013), pmccut (09-26-2013)
Old 09-26-2013, 04:13 PM   #157
FRSTEVE
@pmccut and king_tut - thank you so much for sharing the boost chart.
I am far from an expert, but looking at the graphs, its not 100% clear that the turbos are out of steam. What I do see is the linearity I would expect from a manual boost controller or the tuner's programming of a EBC on wastegate's state.
At the lower RPMs, we want the wastegates completely shut to improve spool. That is "easier" to do with the combination of wastegate spring tension and the wastegate controller's duty cycle.
As you run up in RPM, you are producing more exhaust pressure, which in turn should spin your turbos faster - assuming the wastegates are still completely shut. You should be building more boost. But on the graphs, its tapering boost. A manual boost controller, will hold the same input to the wastegate since its a static device. But (stating it again), its harder to hold the wastegates shut at 7000 rpm vs. 4000 rpm, so it could be creeping open higher in the revs, which would give us a boost taper.
Being in or out of the optimal VE of the turbo is a different question. If you're out of the VE, you'll have boost, but its so hot, you're not getting any additional power (and in turn back off the boost until you see the same power output - less stress for the same power).
Let me know if I'm off on anything ... I guess, my only last question is, did you guys try to run more boost and did it make any more power?
thanks again ... much appreciated with all your sharing!!!
FRSTEVE is offline   Reply With Quote
The Following User Says Thank You to FRSTEVE For This Useful Post:
Old 09-26-2013, 06:26 PM   #158
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
Off topic... but I love this thread!!!
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
The Following User Says Thank You to ravenblackfrs For This Useful Post:
Old 09-30-2013, 11:55 AM   #159
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
No recommendations for NOLA, but you can make the 3 hour drive to my house to have it installed.
MikeW (10-03-2013)
Old 09-30-2013, 11:57 AM   #160
King Tut
NASA SpecE30 Racer
King Tut's Avatar
All I can tell you is that with just wastegate spring, MBC, and EBC I have had boost taper off in the upper RPM range. I have yet to see any GT2871R plot or AVO plot that doesn't.
Old 09-30-2013, 12:13 PM   #161
jamesm
i'll grab a plot with my gtx when i get my car back and see if it's doing the same... i've never noticed it tapering off but then i'm not staring at the gauge at WOT either lol
Old 09-30-2013, 03:47 PM   #162
CajunFRS
Drives: Challenger R/T, CRX SI,
That's kind of you to offer him that. D3 in Houston is the closest shop I've found on this side of LA that I would trust installing a turbo.
I've followed your build thread Tut you and sportsguy have some nice Twins.
CajunFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to CajunFRS For This Useful Post:
Sportsguy83 (09-30-2013), whitefrs (10-01-2013)
Old 10-03-2013, 11:51 AM   #163
MikeW
MikeW's Avatar
Hey, I might just take you up on that!! what does your calendar look like over the next two months??
Old 10-03-2013, 11:53 AM   #164
MikeW
MikeW's Avatar
I'd basically be ripping your entire build off so it makes sense to use your garage as well!
Old 10-03-2013, 02:20 PM   #165
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I will shoot you a PM.
Old 10-14-2013, 01:01 PM   #166
Ash_frs
Drives: 2013 FR-S firestorm (MT)
Love this set up. What else is done to the driveline other han fbm turbo kit?
Any diff work or oil coolers? Love to see your intire parts list?
Awsome thread. Ash
Ash_frs is offline   Reply With Quote
The Following User Says Thank You to Ash_frs For This Useful Post:
mack4477 (10-16-2013)
Old 10-16-2013, 06:54 PM   #167
mack4477
Drives: 2013 Firestorm FR-S
Awsome thread. Ash
The parts list is short. It's everything included in the FBM base kit. Upgraded turbo, and upgraded injectors/fuel pump for the E85. ACT clutch. Cusco motor mounts and catch can. FBM 3" exhaust. Nothing done to the diff other than running some good Motul fluid for now.
Somewhere down the road, I'll be looking into having FBM build the motor, upgrading the rear axle and tranny, and possibly adding the larger radiator and an oil cooler.
mack4477 is offline   Reply With Quote
400HP Toyota GT86 GT4 Racer by GPRM Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 46 04-10-2015 10:31 PM
DCW Firestorm FRS doggy Member's Car Journals 381 02-28-2015 05:29 AM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 02:41 PM
L3P's Firestorm FR-S L3P47 Member's Car Journals 67 06-02-2013 11:32 PM
Looking for a Firestorm 6MT? phm14 Scion FR-S / Toyota 86 GT86 General Forum 1 06-11-2012 02:46 PM
