Old 09-30-2013, 01:45 AM   #1
fitcious
OEM mud guards
Anyone with OEM mud guards? How do you like them? Was the rear hard to install without removing the wheels?
I just got some today...
Sent from my Samsung S4 using tapatalk
fitcious is offline   Reply With Quote
Old 09-30-2013, 01:52 AM   #2
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Where did you get them? I'm thinking of getting myself some
Jolaessss is offline   Reply With Quote
Old 09-30-2013, 01:58 AM   #3
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
I was wondering the same things. Also: is weather tape needed, does it form to the curves of the panels, and how is the quality?
boxer 2.5 is offline   Reply With Quote
Old 09-30-2013, 02:08 AM   #4
Well, I installed the OEM mud guards on my white FR-S and I think they look just fine .... they sort of "blend in" with the black wheel well panels.
They are good quality .... for mud guards .... and they fit nicely.
The front wheels DO NOT need to be removed for installation, just turn them.
I tried all my best "around the corner" tools to get that inner fastener hole drilled/punched in for the rear guards without removing the wheels .... I finally gave up and removed the rear wheels.
I think they work pretty well for helping keep the sides of the car claener.
Jolaessss (09-30-2013), NWFRS (08-05-2015)
Old 09-30-2013, 04:21 AM   #5
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
I've got them too, one of the first mods when I got mine a month or so ago. I have a white 86 and they look okay on them, blend in like they are standard. They function as I thought they would. Though they are the only thing I've scrapped on a gutter so far.
Easy to install, had left over bits. I brought them from a local person who had an aero kit and couldn't use them. But can get them from eBay or even my local Toyota dealer sell them.
Top quality or standard OEM quality. Fit very snuggle to the car and after a month of use no movement.
Rumbaar is offline   Reply With Quote
Old 09-30-2013, 04:27 AM   #6
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
I managed installing the rears with tires on, just turned the drill bit by hand, if the proper size won't bite in, start with a smaller one. Good fitment, love the look. Good luck.
Tim
TEWwild is offline   Reply With Quote
The Following User Says Thank You to TEWwild For This Useful Post:
Suberman (10-08-2013)
Old 09-30-2013, 07:19 AM   #7
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Tim
You can also heat a drill bit with a torch and just push it through the plastic. Makes a clean hole and no need to remove the wheels. Just don't let anything hot contact the tire.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following User Says Thank You to Clembo For This Useful Post:
Old 09-30-2013, 08:15 AM   #8
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Are we talking about the ones they come with? Are these not coming with some or what's going on??
Old 09-30-2013, 08:22 AM   #9
Mikem53
Drives: FR-S 6MT
I installed a set. I did remove the rear tires for easier access, just turned the front wheels was enough.. They look good and blend in well with the raven look.
Mikem53 is offline   Reply With Quote
Old 09-30-2013, 08:57 AM   #10
TEWwild
TEWwild's Avatar
Apparently they are standard equipment in Canada, not so in the lower 48....
Old 09-30-2013, 08:58 AM   #11
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
I installed them all without using the inner plug, been on a year Without issues.
speedy racer is offline   Reply With Quote
Old 09-30-2013, 09:14 AM   #12
USMC
USMC's Avatar
Drives: 2013 Scion FR-s
I also installed them and they look great. I removed the rears to make it more easy to install.
USMC is offline   Reply With Quote
Old 09-30-2013, 10:04 AM   #13
frs10
Drives: tezla
OEM mud guards are great, great quality and great fit.
do urself a favor... remove ur back tires and install all the screws... they feel flimsy without the last nut installed.
check the DIY section for the mud guard install
frs10 is offline   Reply With Quote
Old 09-30-2013, 11:12 AM   #14
fitcious
Thanks all!
Got it yesterday at longo
where to get frs/brz mud guards in GTA? chenshuo CANADA 6 03-10-2013 10:30 PM
FRS OEM Mud Guards FRS2000 Exterior Parts (Aero, Lighting, Etc.) 2 02-07-2013 05:00 PM
mud guards - anyone else got them? Cornell89 Cosmetic Modification (Interior/Exterior/Lighting) 13 09-03-2012 09:00 AM
WTB: OEM mud guards 86_ZN6 CANADA 9 07-16-2012 01:36 AM
Anyone getting mud guards? zoomzoomers BRZ First-Gen (2012+) — General Topics 13 06-15-2012 08:40 AM
