Old 09-29-2013, 12:11 PM   #57
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm still deciding if I should bother replacing my diff fluid. Has anyone felt any noticable improvement after doing just the diff fluid change only (separately to the trans fluid)?
Fizz is offline   Reply With Quote
Old 09-29-2013, 01:32 PM   #58
vincent201089
vincent201089's Avatar
Drives: frs
Originally Posted by Anthony View Post
I went ahead and bought 3 liters. I looked at several tranny oil threads, but no one seemed to mention how much they actually used. Then I finally got smart and looked up the DIY. The DIY said 2.2 liters is what it takes, so I figured I should be safe with 3.
As for the differential, I want to change my final drive eventually, probably after I do aluminum flywheel and carbon fiber driveshaft. So I'll just hold off until then.
There's a thread about this. Fill until the fluid comes out the fill hole. Wipe it and put the nut back.
vincent201089 is offline   Reply With Quote
Old 09-29-2013, 01:42 PM   #59
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Youll be fine with 3liters. I just changed my trans and diff using 4liters motul gear 300. When filling the trans you will easily fit 2liters(2 bottles) then when your on your 3rd bottle just fill it slowly untill you see it start to seap from the fill hole.
MAKE SURE YOUR CAR IS LEVEL WHEN FILLING AND DRAINING! I did this by jacking up both the front and rear and placeing 4 jack stands(all the same hieght) on the OEM lift points on the pinch seam/rail.
I replaced my diff fluid yesterday after 10,000 miles of mixed highway and abusive driving, it looked worse then my trans fluid. the drain plug was entirely covered with shavings and the fluid itself was glittery from shavings. My trans fluid was also glittery but not to the same extent as the diff.
I cant say anything definetively about difference in driving feel since i changed both trans and diff for the first time both at 10,000miles. However, before changing my fluid i would get a "jolting" feeling from the rear when i accelerate after changing gears, ive only put about 100miles on the new fluid(motul gear 300 75w90) but it hasnt "jolted" yet and everything is 100% smoother compared to my oem fluids. But not sure if this was a result from the trans being smoother or if the diff oil actualy made a difference but based on the glitter i got from my diff id say change it at some point.
WHITE is offline   Reply With Quote
The Following User Says Thank You to WHITE For This Useful Post:
Fizz (09-29-2013)
Old 09-29-2013, 11:59 PM   #60
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Thanks. And that will be exactly how I do it too. I'm all about some jack stands.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-30-2013, 02:37 AM   #61
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
Glad to see some people doing this! This is a very tight trans, and as such has a harsh break in period. New fluid is almost necessary!
boxer 2.5 is offline   Reply With Quote
Old 09-30-2013, 04:14 PM   #62
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Hawaiian View Post
And my drain plug
Changed mine at 8200:
I don't think the metal shavings on the plug were abnormal. The shavings were comparable to other manual transmission cars in the past with 30-50k miles.... but I've also changed out fluid at 10k with pretty much the same amount of shavings.
I swapped mine out to Amsoil 75W-90 and noticed a small difference in shift feel. Downshifts and rev-matching are better, but it wasn't as dramatic of a difference as some others have suggested. Perhaps that is a byproduct of driving style.
-alex
Old 09-30-2013, 05:15 PM   #63
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by imom View Post
Hi... Just want to be clear...you are using Motul Gear 300 for the tranny and differential or are you using Motul Gear LS 300 (limited slip version)?
Anybody?
sato is offline   Reply With Quote
Old 09-30-2013, 05:18 PM   #64
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by sato View Post
Anybody?
Motul Gear 300 regular goes in both.
Mike
AZP Installs is offline   Reply With Quote
Old 09-30-2013, 06:06 PM   #65
loogs
Drives: on cruise control
just picked up some fluid. how long does it last? Motul 300
loogs is offline   Reply With Quote
Old 09-30-2013, 09:36 PM   #66
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
I did both at the same time and noticed zero difference. I justified it because I wanted to see how much metal had accumulated on the drain plugs. Wasn't terrible but I'm a bit disappointed in the lack of shifting feel improvement. I used Motul 75w90.
TheseColorsDontRun is offline   Reply With Quote
Old 09-30-2013, 09:38 PM   #67
TheseColorsDontRun
I was told ~20-25k.
The Following User Says Thank You to TheseColorsDontRun For This Useful Post:
loogs (09-30-2013)
Old 09-30-2013, 09:44 PM   #68
AZP Installs
We change it every 30k miles on street driven cars. On track driven cars we change it 1x a year, usually at the end of the season.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Now we have an Online Catalog where you can purchase Parts! AZPParts.com
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
The Following User Says Thank You to AZP Installs For This Useful Post:
loogs (09-30-2013)
Old 09-30-2013, 09:45 PM   #69
AZP Installs
Feel isn't necessarily why one changes their fluid. The Motul is fully synthetic and a much higher quality than the factory fluid, and will provide better protection under severe conditions.
-Mike Paisan
Jstunna (12-04-2013)
Old 09-30-2013, 09:48 PM   #70
TheseColorsDontRun
-Mike Paisan
Thanks for the info. I was disappointed because I have read posts about folks raving that all notchiness and grinding magically disappeared after swapping out the factory fluid. Not the case with Motul. At least not in my car.
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
