Old 09-18-2013, 01:19 PM   #1
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Tapping into badge lighting
I am writing this to see if anyone has yet checked out the badge lighting system on the 10 series?
I looked at the diagrams that came with the car but they don't show much of what I need.
I am planning to add accessories/lighting that goes with the badge lighting.
Does anyone know, or can give advice, on a good,safe way to tap into the circuit for the badge lights?
Essentially I want some accessory lighting to fade on/off with the badges.
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 09-18-2013, 01:44 PM   #2
frs10
Drives: tezla
isnt everything in the booklet?
frs10 is offline   Reply With Quote
Old 09-18-2013, 02:14 PM   #3
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
I don't think the wiring for the glowing emblems will support anymore added lighting.
I'm not screwing around with the emblems seeing how they cost $400.00 each to replace.
Old 09-18-2013, 03:01 PM   #4
SillySaxon
SillySaxon's Avatar
I'm not touching the emblems themselves, i'm wanting to add on to the circuit so it powers more stuff.
Might have to use my multimeter to do a power pull test on them to see how much more amperage I can consume
Old 09-18-2013, 04:43 PM   #5
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
I hope you don't burn your car down because a wire decided to overheat ....
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 09-18-2013, 04:54 PM   #6
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
You can run additional accessories through a relay and use emblem wire as remote to turn them on
#944_10_Series_FRS is offline   Reply With Quote
Old 09-18-2013, 05:44 PM   #7
SillySaxon
SillySaxon's Avatar
That's close to what I want. Which of the emblem wires would be used to open/lose the circuit
Old 09-18-2013, 07:11 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
seriously?!?!? that does it. i'm gonna make a set just out of spite.. especially considering toyota makes them so cheaply.. i can see the acrylic below the emblems that was loosely cut to the shape of the finished emblem..
but for those of you lacking the talent, this guy has put up with plenty of my harassment about his product and still somehow kept it professional.. and his emblems look a heck of alot better then just an 'acrylic sandwich'..
http://shop.ampdemblems.com/
kakarot1657 (10-02-2013)
Old 09-18-2013, 07:18 PM   #9
TRD-X
TRD-X's Avatar
OK you go make one and post it up.
Old 09-18-2013, 08:54 PM   #10
soundman98
soundman98's Avatar
don't laugh too hard, you might hurt yourself.
http://www.hidplanet.com/forums/show...lipse-led-swap
retrosmiths (09-26-2013)
Old 09-25-2013, 01:10 AM   #11
SillySaxon
SillySaxon's Avatar
If I upload the wiring diagram could anyone here let me know which of the wires to use as the relay for on and off to some additional lighting?
I'm assuming I could run a serial circuit through the badge ground wires?
Or would it be best to find the connectors and tap in there, similar to how the always on LED box upgrade on here has wires directly to the pins?
Sent from my SGH-T999 using Tapatalk 2
Old 09-25-2013, 11:05 PM   #12
soundman98
soundman98's Avatar
no guarantees, but i can try..
SillySaxon (09-26-2013)
Old 09-26-2013, 01:02 AM   #13
retrosmiths
Drives: Scion FR-S Whiteout
I'd love to see your take on this.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 09-26-2013, 04:44 PM   #14
SillySaxon
SillySaxon's Avatar
Cool I'll get it to you this evening
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Tapping sound above 70 mph Fugazi BRZ First-Gen (2012+) — General Topics 24 10-20-2015 04:04 AM
DIY remove FR-S 86 badge and installing JDM 86 badge Tylub DIY (Do-It-Yourself) Guides 13 07-07-2013 10:24 PM
Strange Tapping noise from under car after use rhood168 Issues | Warranty | Recalls / TSB 10 02-12-2013 02:16 AM
Tapping my oil feed Silverdub Forced Induction 9 10-17-2012 04:22 PM
