go_a_way1
Old 09-25-2013, 04:33 PM   #1961
raven1231
Originally Posted by fenton View Post
Remember though if he is at work or something he might not see much on post 1.
Im at work now and all pictures of DYNO's and whatnot are blocked.
True! lol but coming in here with an unnecessary negative attitude just annoyed me.
Old 09-25-2013, 04:40 PM   #1962
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Gary in NJ View Post
I'm tuned. Some of you are not going to be happy, but I chose not to dyno tune. The dyno was available, and I asked about getting on the dyno, but Mike gave me the following choice: we can get on the dyno and tune it for the dyno, or we can get a lot more data doing the tune right on the car. While he didn't use the exact words, the intent was "do you want it to look good on a dyno or run great on the street".
We were able to get about 16 pulls on the road next to Mike's shop. Mike also had me hammer the car for him so he could get a feel for what the ESC was capable of. After I was able to prove that this wasn't a glorified "leaf blower" it was time to get to work. Here's the way it rolled out:
The first 4 runs were baselines. Looking at the data Mike could see some detonation at the onset of boost. We took the data to a computer with a very large screen and Mike started to build a map based on the split personality of the power delivery. Mike must have opened 2 dozen different tables to gather information that he wanted to use. After he had the timing in a range that he thought would work well he performed the first flash of the ECU and we went out for another four pulls.
During these pulls Mike focused on a particular rpm range. With new data in hand it was back to the computer. Mike reviewed the results and determined that his initial thoughts on tuning this car were correct so he once again focused in the timing.
For the third set of runs he looked at the full rpm range from 2500 rpm to redline. With this data he was able to adjust fuel trims, the MAF a host of other things that I can't remember. He also asked me about the features I wanted to include on my tune.
We went back out and did a few more runs. Mike was satisfied that the engine was running safely on the available boost. Then he took the helm and ran the car through its paces. I'll let Mike give his own conclusions and impressions. But I'm fairly certain that he liked it. Mike's personal car has an Innovate SC so he can give a great comparative reference.
So how much horsepower do I make. Enough. I really don't care. Like I've said before, I'm not fighting the horsepower wars. I wanted outstanding drivability. I have that. Oh man do I have that. What was once the valley of death is now where this engine shines. It's a complete transformation.
Mike is a nice guy and a very experienced tuner. He was able to zero in on what had to be done and didn't spend any time guessing and playing "what if" games. His focus was on one thing, a safe tune. I look forward to his input on the ESC. I also left out a lot of the details of the tune. Mike can share what he wants. I'll have direct input for Rob.
I will say this, like many I've been intrigued by Open Flash. But after watching Mike at work, Open Flash (in my hands) would be a serious can of worms. It was nice to be able to sit down with Mike and understand what he did, but I have no business attempting to tune an ECU.
Final thoughts: I really liked my BRZ before I added the ESC. With the ESC installed the car moved into my Favorite Car Ever position (a coveted position given the other cars I've owned). Now that its properly tuned the ESC feels so perfectly integrated into the car. I actually look forward to driving the car. I haven't had that feeling in a very long time.
Ug... no dynos... Well, I'm happy your car is running well, that's something.
Old 09-25-2013, 04:46 PM   #1963
Diggitydog89
Drives: 2005 Chrysler Crossfire
Sorry to rustle your jimmies... didnt mean to be negative
Diggitydog89 is offline   Reply With Quote
The Following 2 Users Say Thank You to Diggitydog89 For This Useful Post:
fenton (09-25-2013), NoChance (09-25-2013)
Old 09-26-2013, 10:02 AM   #1964
mid_life_crisis
Drives: FR-S 10 #103 AT
I meant I would like boost to be the same across all rpm range which I guess means limiting boost to 1 psi across the board in order to not feel a drop-off in torque. I figured drag reduction requires changing motor speed already, it might be doable when the WOT means maintaining 1 psi?
@Robftss
Thinking along those lines, how hard would it be to determine at what boost level the CELs go off and create a system that doesn't boost quite high enough to overrun the factory tables? It would obviously not make as much power as a tuned, higher boost system, but it would still be a nice bump for those who want to improve the car but don't want to tune and get nervous about faking out the ECU with voltage clamps and the like. It could be done with a bypass valve I suppose, but that would be a waste of electricity.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-26-2013, 12:09 PM   #1965
bfrank1972
Originally Posted by mid_life_crisis View Post
@Robftss
It's interesting that the system can seemingly run ok with a stock ECU (Gary reported some detonation), but I personally think this system should be sold with a map. Long term it doesn't seem right to run it with no tune, even if boost is limited.
Old 09-26-2013, 12:20 PM   #1966
mid_life_crisis
If I recall correctly, it will come with a base tune for BRZEdit. Be nice if they could get the OpenFlash guys to do one.
I'm hoping that limiting the boost would clear up the detonation/CEL worries and still provide a nice bump for those who would like to avoid a tune.
Old 09-26-2013, 12:27 PM   #1967
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Ditto. I'm interested in this combined with the OpenTablet. Sounds like a good combo.
Old 09-26-2013, 01:06 PM   #1968
fenton
OpenTab is in communication with Rob to my knowledge.
What kind of power are you looking for? 10hp across the board? This is alot of work for only ten hp. I dont think you would be happy with that and the rest of the time the SC would just make you lose power over stock.
The main point of this is the huge boost in low end you get to get rid of the tq dip. There are always risks and if you arent running a tune those risks just increase.
Personally i wouldn't spend 1500 on something that only gave you 10 hp.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
raven1231 (09-26-2013)
Old 09-26-2013, 01:11 PM   #1969
fenton
@Robftss
Anything over Atmospheric pressure trips the CEL to my knowledge.
Old 09-26-2013, 01:15 PM   #1970
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
People spend that on exhaust systems for that exact result. And a full exhaust system and a tune just barely fill in the torque dip (some just shift it) while the ESC makes it into a mountain. Once experienced, you'd never want to water it down.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
Old 09-26-2013, 01:46 PM   #1971
fenton
I agree 100 percent with this. Once you feel the pull down low you would never want to dial it down.
Its like a locomotive down there. With how light the car is 180ft/lb of torque is massive!
Name another 2700lb car thats less than 30k and that generates 180ft/lb at 2500 rpm and holds it to 5500rpm or so.
I know some little hatches and whatnot but they spike 180 and dive down.
Old 09-26-2013, 01:59 PM   #1972
raven1231
I want to experience it!
Old 09-26-2013, 02:13 PM   #1973
Robftss
Drives: VW
@Robftss
Here is what we know:
CEL triggered up to ~4000-4500 rpm for SL guys.
CEL triggered even when 2 psi was bleed pre MAP sensor..so it saw ~ 2 psi above atmos.
Above ~4000 rpm and 3-3 1/2 psi...no CEL.
From this, and possibly a time component of high pressure seen, it looks like anything a little above ambient P, and below ~4000 rpm will trigger a CEL.
So...
A) Tune
B) Window switch for full activation (3500 to 4500 rpm?) and DR below that RPM.
Rob.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
DAEMANO (09-26-2013)
Old 09-26-2013, 02:23 PM   #1974
Gary in NJ
Gary in NJ's Avatar
I don't see the need for DR. You're either in the rpm range where it would have little effect (cruise throttle position at 2000-4000 rpm) or accelerating with enough throttle that you'd just engage the ESC anyway.
I find myself now conditioned to run 0-40% throttle or WOT. There's just little point in running 50 to 70% because the ESC is engaged with around 70-80% throttle.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
