Old 09-13-2013, 08:54 PM   #1
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Suspension clunk/thump going over bumps
i.e. my driveway has one of those humps, or say a speed bump - especially if the wheel is turned. I can hear and feel a thump in the steering wheel and through the floor board. It's getting increasingly worse. I did a very quick check under the car and didn't find anything.
Would rather fix it myself if possible because the dealer here couldn't fix anything if their lives depended on it.
Before I break down and take it to the dealer, has anyone else experienced something similar?
Old 09-16-2013, 01:25 PM   #2
Dinko
Drives: Scion FRS
had a similar issue after i installed RCE Yellow lowering springs. Both my front struts blew out.
Dinko is offline   Reply With Quote
Old 09-25-2013, 04:35 AM   #3
Scoobybrz
Scoobybrz's Avatar
Have you figured out the cause? My brz has been making clunking noise when I go over bumps or up a driveway too. The sound is coming from front underneath of the ca.
Scoobybrz is offline   Reply With Quote
Old 09-25-2013, 08:13 AM   #4
SloS14
SloS14's Avatar
Getting worse, dealer appointment on Friday. I'll update the thread...then again I forget things so if I haven't replied by mid-week next week remind me!
Old 09-25-2013, 12:29 PM   #5
dehydratedH2O
Drives: 2014 BRZ Limited DGM
every time I've heard this noise on a car, it has been a blown strut. when it blows out, even small bumps hit the bump stops, causing the noise.
dehydratedH2O is offline   Reply With Quote
Old 09-25-2013, 02:07 PM   #6
onepremiere
Drives: Space Shuttle
check nuts on the bracing under the hood, but do not tighten them anything over 15lbs other wise you will sheer the stud off.
mine were loose and shifting under load. sounded like I had toasted a ball joint.
i added some rubber washers under the brace where it meets the body just in case. haven't heard anything since.
onepremiere is offline   Reply With Quote
The Following User Says Thank You to onepremiere For This Useful Post:
paintdude258 (11-19-2015)
Old 09-25-2013, 02:31 PM   #7
SloS14
SloS14's Avatar
Thanks for the tip!, I'll check it out when I get home
Old 09-25-2013, 02:55 PM   #8
Thorpedo
The SquadWhisperer
Sub'd. Have the same problem and mentioned it in another thread.
Thorpedo is offline   Reply With Quote
Old 09-25-2013, 02:59 PM   #9
jadewbj
jadewbj's Avatar
I have the same issue, thought it was from all the bushings I did.
jadewbj is offline   Reply With Quote
Old 09-26-2013, 09:45 AM   #10
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
The clunk you are referring to is bare metal rubbing in the trunk, a huge thread already exists about it and using/spraying WD40 fixes it
Old 09-26-2013, 10:01 AM   #11
jadewbj
jadewbj's Avatar
Tried the WD 40 trick and one of the sounds went away but I still have another.
Old 09-26-2013, 08:22 PM   #12
SloS14
SloS14's Avatar
Mine wasn't the under-hood braces.
Old 09-26-2013, 08:35 PM   #13
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I get this in my personal BRZ, but we have not seen it in the shop car. It almost feels like the front lower control arm bushings to me. I check them every time I have the car in the air, and have also poked and prodded just about everything I can think to check and have come up with nothing.
Also, mine has not gotten any worse, but I noticed it around 1.5K miles and I am just over 3K miles now, no suspension mods besides front camber bolts, and Whiteline rear subframe bushings. The noise happened when the car was 100% stock as well.
I almost hope it is the front control arm bushings as I want an excuse to go with the Whiteline Anti Lift Kit haha. Oh and just to be clear, this is not the sound of the rear trunk pop, I have that as well
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-27-2013, 03:06 AM   #14
Scoobybrz
Scoobybrz's Avatar
Thanks,
Rick
I was barely over 200 miles when I started to noticed this issue.
Front suspension squeak going over bumps Gords_zenith Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-19-2017 10:57 AM
rear suspension clunk Gen Issues | Warranty | Recalls / TSB 67 04-03-2015 09:52 PM
acceleration thump mid_life_crisis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2013 10:19 PM
Thump happened on downshift into 2nd husker741 Issues | Warranty | Recalls / TSB 11 07-19-2013 01:07 AM
Clunk sound from rear suspension. j-tan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-05-2013 01:39 PM
