Old 12-19-2012, 02:21 PM   #15
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Originally Posted by Nardi330 View Post
i used RCE's recommendation and adjusted to my taste.
This is what I did as well. I am really blown away at how KW retains ride comfort. Most people who ride in my car are surprised when I tell them it is on coilovers.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 12-19-2012, 02:27 PM   #16
gmookher
Originally Posted by robispec View Post
in testing we have put heavier rear springs on the car
what is your front sway bar at present, and why havent you tried a 20/16 or 22/16 combo?
Old 12-27-2012, 10:12 AM   #17
nix
nix's Avatar
Drives: AVO BRZ
User manual says 9 rebound / 6 compression front and rear.
RCE suggest to start at 10 / 7 front, 7 / 8 rear.
nix is offline   Reply With Quote
The Following 2 Users Say Thank You to nix For This Useful Post:
DriftEightSix (12-27-2012), Flasher (07-21-2015)
Old 12-27-2012, 12:40 PM   #18
Racecomp Engineering
Originally Posted by qtwre View Post
I have a set of KW variant 3s on order and in the interest of clearing up some of my own confusion, I'd like to ask the current owners out there a few questions.
I first read that some people are running the springs upside down. Do you? Why?
I've already recently learned that some people swap the front and rear springs to have more rate in the front rather than the back. How many of you are doing this? Frankly it sounds like a good idea to me but I can't help but think about how people are so impressed with how much R&D KW puts into their products, so why mess with it? KW got it wrong?
Lastly, this question is less important but what compression and rebound settings are you running front and back and in what environment? I know it's preference but I'd like to try some recommended setups.
Thanks guys.
If you've seen people say they've "flipped" the springs, they mean they've swapped them front to rear.
KW puts the firmer springs on the rear because the motion ratio is lower back there, so a firmer spring is needed for an equivalent rate to the front. See the sticky thread I made in this forum on spring rates.
Some people are putting the firmer springs on the front because these cars do not have problems understeering, so a little more front spring rate goes a long way in improving stability.
There's a balancing act and it depends on tire choice, driver preference, application (auto-x, street, track), and other mods. We often do even rates but it all depends.
- Andrew
Old 12-28-2012, 01:57 AM   #19
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm running KWs and I did flip the springs front to rear for better balance for autoX, but they are still not ideal spring rates IMO.
The reason the kit ships with stiffer springs in the rear is because the car is that way stock so out of the box the kit will retain a stock balance. In my case the stock balance is not what I was looking for.
You can just take them right out of the box and install then (and get an alignment) and everything will be just fine if that was a concern of yours.
Old 09-25-2013, 12:55 PM   #20
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Why no one talk about camber? for the RCE suggestion, whats the front and rear camber if I only got KW V3? I just order my V3 and LCA, and plan to go -1.5 or more front and -1 rear. Will this be a good setting with RCE damper setting?
@Racecomp Engineering Thx!
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-25-2013, 01:27 PM   #21
Who did you order your suspension from?
Not to be a jerk, but if you go and buy X suspension from another shop, then on the same day turn to us and ask for tech support, it kinda rubs us the wrong way. I'm glad to help people where I can but part of buying from us (and other good shops like CSG, Turn In Concepts, Rally Sport Direct, our other RCE dealers, etc.) is that you also get good tech support. We've posted a lot of "free" information because we like to help people and like talking about suspension, but we really don't like doing other shops work for them as I'm sure you understand. There is a lot of information on the board here provided by the community to help you too.
- andy
7thgear (09-25-2013), mfbmike (09-26-2013)
Old 09-25-2013, 01:58 PM   #22
Figo
Figo's Avatar
LOL I actually asked about the camber.. and I order whiteline camber bolt from u...
Not trying to get tech support.....just some general talk in this thread....cuz I think people are talking about damper even if they hav different other setting. So I assumed that they all hav nothing but KW V3, nd the biggest difference IMO is camber.
And I @ u cuz we are talking about ur recommend damper setting here.. and u might help us. .not as a seller, but like general talk.:happy0180:
- andy
Old 09-25-2013, 02:03 PM   #23
Ah okay. That's fair.
If I recall you were running some pretty wide tires in the rear.
-2 degrees camber front and -1.5 in the rear with 0 toe front and a tiny bit of rear toe-in will work as a good all-around street/fun set-up...
In general the alignment is done first, then you worry about the damper settings.
- Andy
gdrider77 (06-30-2014)
Old 09-25-2013, 02:06 PM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
corner balance before alignment though, right?
Old 09-25-2013, 02:09 PM   #25
Figo
Figo's Avatar
I think ur r developing a top mount right? Is it done?
Or u think I will be good to use those whiteline bolts on slotted hole without any issue and reach -2 front?
- Andy
Old 09-25-2013, 02:13 PM   #26
Yes.
You'll be able to get -2 easily.
- Andy
Old 09-25-2013, 02:15 PM   #27
Figo
Figo's Avatar
Thank you.
Yes.
- Andy
The Following User Says Thank You to Figo For This Useful Post:
Racecomp Engineering (09-25-2013)
Old 09-25-2013, 03:59 PM   #28
kanundrum
Drives: 2013 Whiteout FR-S
DIY on Adjusting the Compression and Rebound for the rear ?
I am thinking to put it all the way soft and then click up for stifness
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 10:35 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
