Old 11-24-2012, 11:25 PM   #15
gmookher
You really don't want zero camber. Handles best with just a hair over (1)
Old 11-25-2012, 08:44 PM   #16
wparsons
wparsons's Avatar
Originally Posted by Supermassive View Post
Because I drive the car daily, and don't like not using the full width of my tread.
Depending on how hard you drive, you could end up using less of the tire width with less camber. You get more traction (to a point) with more negative camber because under higher cornering loads you're getting the full tire on the road. With too little camber you'll be scrubbing the outer edge of the tire in corners.
The only time you really want 0* of rear camber is in a drag car for best launch grip.
flickr
Old 11-26-2012, 12:00 AM   #17
jamal
jamal's Avatar
Drives: Legacy GT
Any cornering force at all is going to cause tire flex no matter how stiff the suspension is. Additionally, the camber doesn't gain a degree for every degree of body roll so every bit of roll causes a deficit.
If you don't start out with negative camber all the work gets done with the sidewall and outer part of the tread. Some cars are better than others, but everything needs camber, and the BRZ isn't anything special.
jamal is offline   Reply With Quote
Old 12-09-2012, 11:44 PM   #18
robispec
Drives: Black frs project
dont forget radial tire "camber thrust"....(wants to turn in the direction of the side of the tire most loaded)...equal in a straight line but as soon as weight transfer enters the picture a WHOLE new set of forces come into play!
robispec is offline   Reply With Quote
Old 12-10-2012, 01:14 AM   #19
chutrain
chutrain's Avatar
Drives: WRB BRZ
I agree with this. You want just a tad of camber so that the suspension can work properly. When you go into a turn with a shifting of weight, the car suspension will have slight variances in camber, so you might be creating a positive camber situation. For a RWD street car, I would run a little camber.
Since the OP had concerns of wearing out the insides, when alignment is done properly there is very little uneven wear. It will also help if you are not overly aggressive with the throttle either. Follow recommendations on tire rotation and you will be fine. You will be saving yourself some money from not having to buy and install those extra components. Also, what tire are your running? This will also determine how it will wear.
But in the end, to each their own. It's your own car and money, and in no way am I telling how to spend. Just offering my opinion.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 09-24-2013, 08:00 PM   #20
diss7
Drives: AE86, 2x GT86, TE27
Old thread, but will comment anyway.
Ideal camber is entirely subjective, on driving style, track/street, and tyre.
I'm looking at Rear UCA options at the moment. As I currently have 2.3 Rear camber, but want 0.5 - 1.0.
Little rear camber, street tyres, much nicer for sliding. They let go sooner at initiation, and have more forward grip/drive during the slide.
diss7 is offline   Reply With Quote
Old 09-24-2013, 09:01 PM   #21
wparsons
wparsons's Avatar
Racer X has been selling adjustable UCA's for a while now, they aren't cheap, but I'll be going with UCA's when I finally bite the bullet on suspension stuff.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
448hpsti (09-24-2013), el-92 (04-23-2016)
Old 09-24-2013, 10:12 PM   #22
xwd
I have a set of the Racer X ones, they are very nice.
Old 09-24-2013, 11:42 PM   #23
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
trying to get to 0 camber with an lca will be impossible as you will run out of toe adjustment. so you will have to also get the toe links or the spc lower arm with the offset bushing to fix the toe.
however you can get to -1.2 with 1/16" toe in.
http://www.ft86club.com/forums/showthread.php?t=47291
garfull is offline   Reply With Quote
Old 09-25-2013, 12:26 PM   #24
Dezoris
Dezoris's Avatar
This is what I will go with next year.
http://racerxfabrication.com/product...trol_arms.html
Get rid of those shit whiteline rear upper control arm bushings that are impossible to adjust.
The Following User Says Thank You to Dezoris For This Useful Post:
448hpsti (09-26-2013)
Old 09-26-2013, 12:01 PM   #25
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
YUP mine are coming OUT this weekend! Going with the WL non adjustable top bushings. NOTE** to anyone that ever wants to put back in (STOCK) bushings after your shop takes yours out KEEP EM if they're good. If you goto Subaru or Toyota they will NOT sell you a set, they will only sell you new stock UCA with their bushings you can not buy just the bushings. I went through this recently in my decision to remove the WL adjustable UCA bushings.
Old 09-28-2013, 01:38 PM   #26
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
wow good to know. Although im sure some aftermarket (nonadjustable) bushing should be available?
+1 on the racer X upper arms, beautiful arms. wish i picked those up before i went with lowers- currently running both
SLICVIC is offline   Reply With Quote
Old 09-28-2013, 05:25 PM   #27
wootwoot
Drives: FRS
I like the racer-X except for the spherical bearing.... I wish they could do a standard ball joint on that unit. It may be too much for a daily driver...
Old 09-29-2013, 04:09 AM   #28
OICU812
Just a dude
OICU812's Avatar
I ended up ditching the Whiteline adjustable UCA bushings "junk IMO" and installing there non adjustable bushings 70-80 bones .. which fit great and now using a LCA and WL toe links finally got my rear camber and toe perfect. Learning lesson indeed...
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
Rear control arms EN2_Squirrel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 11-07-2012 04:04 PM
Delete driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-31-2012 08:42 PM
Agency Power Control Arms | Best Price Anywhere IslandImportPerformance Brakes, Suspension, Chassis 0 07-20-2012 02:17 PM
