Old 09-25-2013, 12:16 PM   #43
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Originally Posted by Enraged21 View Post
you have TWO?!?! Man I'm jelly
No the other one is my brothers. He bought his about 4-5 months before me and I loved it so i got one to..lol..i even bought the same color. Everyone always asks why we have the same exact car..lmao
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 09-25-2013, 12:46 PM   #44
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by cfusionpm View Post
One of my all-time favorite cars was my 1990 turbo Eagle Talon TSi AWD. I had a few light bolt ons and upped the boost a little bit and that thing was just a BLAST to drive. On the other hand, the electronics were iffy at best, rear hatch hydraulics shot, couldn't drive with the windows up thanks to exhaust leak, horrible tint job made it impossible to see out of, it broke down and/or overheated more times than I could remember and spent more of its life on a flat bed than on the road. But I'd buy another one in a heartbeat if I found a good condition model today. My girlfriend can drive the smooth, reliable, quiet, comfortable car. I want something fast and fun.
I have a mostly stock '99 Eclipse GSX.
It is an older car so almost every year I've had to replace some parts on it (just got done replacing the brake rotors, pads, fluid, and wheel bearings). But it's still cheaper than paying new car payments. I think the biggest problem with the DSM's is that most people put bigger turbos on them and modify them to heck which obviously results in reliability issues. Mine has never overheated with the stock turbo and I've driven it hard many times. Although my turbo did eventually blow out last year (which I replaced with another new stock Garrett turbo). I will probably sell it when the MY2015 FR-S's come out if you're interested. I don't think I can justify having 2 cars and I think I'm ready for something new. But we'll see...
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 09-25-2013, 12:53 PM   #45
SCharged
Drives: asphalt fr-s
I understand what some of you are saying about luxury, etc. in this car. And the rattles to some extent add to the car's character, adding to the ''no compromise'' philosophy. However, the mechanical problems are harder to ignore or live with... The car has shut-down on me while driving when I pressed-in the clutch. I mean that's just dangerous.. We'll see I guess, if things don't get significantly better, I certainly won't keep the car beyond warranty.
SCharged is offline   Reply With Quote
Old 09-25-2013, 01:08 PM   #46
wbradley
Sarcastic SOB
wbradley's Avatar
You mean you stalled, or it shut down before you lifted the pedal?
Old 09-25-2013, 01:09 PM   #47
DAEMANO
Time Traveller
If that happened in any other gear but 1st and from a dead stop (likely just a stall), then take the car in right away.
Old 09-25-2013, 01:18 PM   #48
SCharged
I mean it shut down by itself. Was approaching a stop, clutched in, stopped, put it in first, declutched, and nothing, the car was off.
I took it in they said it could be related to the crickets, changed the HPFP, crickets came back after a couple days. The car has not stalled again, but idle drops till the cars almost dies then goes back up.. I think it's just a matter of luck that it hasn't stalled since.
Old 09-25-2013, 01:19 PM   #49
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
SCHARGED: It's obvious that you have a negative opinion of the car. Doesn't matter what anyone here says. Obviously we all love the car and are defending it. At this point ... you should get the dealer to fix the problems and move on. No big deal. Part of life. But ... as you will soon find out. Your next car will not be flawless. No car is. Good luck.
Braces is offline   Reply With Quote
Old 09-25-2013, 01:37 PM   #50
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
First step is to take it to your dealer / service department. See what they can fix and then take it from there. I have been guilty of complaining about issues without actually asking anyone to see if they can be fixed. That being said, this car is not a Corolla where they have continually refined an existing model / platform, it is all new. Issues will be worked out, but, concerns need to be brought to the dealers so they can be adequately addressed. As long as we remain silent, all will be assumed as good. All that being said, I will be seeing if some of my nagging issues can be resolved at my next service appointment. I am definitely not giving up on a car that I have soooooo much fun driving.
Demandred7 is offline   Reply With Quote
Old 09-25-2013, 02:06 PM   #51
pasternak
Drives: Asphalt FR-S
Good luck & bye.
No issues w/ mine & still loving it.
pasternak is offline   Reply With Quote
Old 09-25-2013, 02:59 PM   #52
AsianStyle
AsianStyle's Avatar
Drives: Whiteout FR-S MT
I don't think its right to defend a car and say mine doesn't do that so its not a big deal. I think as owners we should support people with issues and help them try to get their issues resolved. It helps create a better car and community.
However, rattles, noises, crickets, etc... seriously? If that is your only problem I don't know what to tell you except you bought the wrong car.
The only issues that should be a concern are the DI and the old CEL bad idle issue. I believe all the CEL issues only affected early cars and have been cleared up by the later ecu flashes. The only remaining issue with the DI should only affect early cars with 2012 build dates. The newest ecu flash fixes it possibly fixes the DI issue, but they aren't willing to give the flash to anyone due to no TSB.
AsianStyle is offline   Reply With Quote
The Following 2 Users Say Thank You to AsianStyle For This Useful Post:
SCharged (10-07-2013), strat61caster (09-25-2013)
Old 09-25-2013, 08:23 PM   #53
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I've never owned a car without quirks (aka: things you come to love or hate about it).
Heck one of my favorite cars in the world is the 2nd Gen CRX si and that thing is real shitbox but I love the hell out of it and every time I see a clean one on the road I think about making the guy an offer.
In my Hondas (one that weren't raced or modified) I've had water leaks, broken engine mounts, seat mounting hardware fail (seriously), dropped a valve, lost a pilot bearing, countless bad distributors/ignitors/coils, and so on and so forth.
Even my bone stock S2000 broke it's own windshield when I was thrashing it on a mountain pass. It wasn't without it's quirks either... Front bumper paint was peeling after 30k miles, soft top was wearing a hole in it after 45k miles, etc etc. My girlfriend's Toyota Matrix only has 60k on it and it and we already had to replace the radiator. I was really surprised by that.
And don't get me started on the old Alfa Romeo's my dad had while I was growing up.. Holy sheeze. I really learned how to cuss watching my dad work on Alfas.
So yeah... if you're unwilling or unable to fix the rear deck popping and the crickets are too much to tolerate then this definitely is not the car for you. Oh how I would love the crickets to be gone but... cest la vie.
PRO86 | WTCC | STL
Old 09-25-2013, 08:31 PM   #54
thill
[ame="http://www.youtube.com/watch?v=z8mn3nLPSMY"]Good Will Hunting - "Idiosyncrasies" - YouTube[/ame]
S
ean: Maybe you're perfect right now. Maybe you don't want to ruin that. I think that's a super philosophy, Will. That way you can go through your entire life without ever having to really know anybody.
My wife used to fart when she was nervous. She had all sorts of wonderful idiosyncrasies. You know what? She used to fart in her sleep. Sorry I shared that with you. One night it was so loud it woke the dog up. She woke up and gone like "oh was that you?" I'd say yeah...I didn't have the heart to tell her...Oh God...[laughing]
Will: She woke herself up?
Sean: Yesssss. Oh Christ....aahhh, but, Will, she's been dead two years and that's the shit I remember. Wonderful stuff, you know, little things like that. Ah, but, those are the things I miss the most. The little idiosyncrasies that only I knew about. That's what made her my wife. Oh, and she had the goods on me, too, she knew all my little peccadillos. People call these things imperfections, but they're not, aw, that's the good stuff. And then we get to choose who we let in to our weird little worlds. You're not perfect, sport. And let me save you the suspense. This girl you met, she isn't perfect either. But the question is: whether or not you're perfect for each other. That's the whole deal. That's what intimacy is all about. Now you can know everything in the world, sport, but the only way you're findin' out that one is by givin' it a shot. You certainly won't learn from an old fucker like me.
Even if I did know, I wouldn't tell a piss ant like you.Substitute "wife" for "FRZ"
The Following User Says Thank You to thill For This Useful Post:
Ramster (10-03-2013)
Old 10-01-2013, 02:03 AM   #55
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Here's my list:
-Rough idle, bogging and stalling.
-Crickets, fixed once, came back within 100km.
-various rattles
-rear deck popping
-clutch throwout bearing noise (I think that's what it is)
-AC issues.
I completely agree with most of these. I never stalled but rough idle (when AC is on) really worries me. Crickets used to piss me off but if you deaden your doors the sound becomes almost muted. Rear deck popping, as someone mentioned before, can be fixed with grease spray (though I recommend something thicker than wd40). Various rattles is like a witch hunt, I've taken panels and pieces out of my car over and over to fix rattles by deadening things and I agree it's pretty frustrating.
What AC issues are there? I haven't really heard of anyone having AC issues.
In the end it really depends on how much you let these little things bother you. I'm assuming you are a little OCD with your car and want to fix this and that as soon as you discover them and that's great but this car is definitely not for you then since various rattles will almost always be a problem and I don't believe the crickets will ever really go away. =/
Best of luck.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 10-02-2013, 03:43 PM   #56
SCharged
I really dan't believe how many of you seem to say that my expectations are too high.. I've had other new cars before, and none with as many ''little'' things as my FR-S... rattles and all, as I said before, not a big deal.. But I really don't think it's too much to expect that my brand new car doesn't turn it self off when I drive it.
For the record, the car has not stalled again, but idle is still rough.
And I understand what some of you are saying about the crickets, that it doesn't affect performance and whatnot, but it does affect the overal driving experience IMHO... I mean really, sounding like an old tempo with a squeeky belt doesn't screem sports car experience...
Move O2 sensors to secondary cat? PantsDants Engine, Exhaust, Transmission 3 09-20-2013 12:57 AM
Anybody else about to move on? TylerLieberman Scion FR-S / Toyota 86 GT86 General Forum 356 09-19-2013 08:51 AM
Decide to move on F3dzo Southeast 9 07-21-2013 10:09 PM
Looking to move to Phoenix from WI FR-Shadow Southwest 37 01-23-2013 11:38 PM
