Drives: Scion FR-S A/T, Whiteout
Move O2 sensors to secondary cat?
So I was checking out some local shops for a custom header-back system and I was thinking about the header to go with it. The majority of headers available are catless, and the few catted ones are about 50% more expensive. Plus the general consensus seems to be that a cat in a header is just gonna wear out/clog up really quickly.
Now I'm aware that you can disable the code for cat inefficiency via a tune. But my thought was that if there were a way to extend the sensor wires, couldn't the O2 sensors be mounted around the cat in the front pipe instead? Like I said, I'm looking at custom exhausts, so it probably wouldn't be much of a stretch to relocate the front pipe cat further down a bit and weld some bungs on either side. Thoughts? |
Drives: Passat
The primary O2 sensor is actually a wide range AFR sensor and needs to be located before any cat and not too far downstream. It needs to stay in the header. The secondary O2 sensor is a traditional narrow band sensor and could be placed in the front pipe after a cat. It's probably easier to simply install a CEL Eliminator on the second O2 sensor instead. I've used both the angled version and the mini-cat with 100% success (see below link).
http://www.bigdaddiesgarage.com/ |
| The Following User Says Thank You to Fast_Freddy For This Useful Post: | PantsDants (09-20-2013) |
#3 | |
Drives: Passat
The mini-cat fit my Borla UEL very well but I don't know about other headers. The angled one worked well on my turbocharged XB2 for 4 years and 40k miles w/o a related CEL.
| Anybody else about to move on? | TylerLieberman | Scion FR-S / Toyota 86 GT86 General Forum | 356 | 09-19-2013 08:51 AM |
| Decide to move on | F3dzo | Southeast | 9 | 07-21-2013 10:09 PM |
| Looking to move to Phoenix from WI | FR-Shadow | Southwest | 37 | 01-23-2013 11:38 PM |
| Report: Toyota FT-86 will move up in price and age demographic | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 201 | 06-02-2010 03:36 AM |
