go_a_way1
Old 09-24-2013, 04:52 PM   #1933
fenton
Originally Posted by autobrz View Post
Anyone had a chance to dyno the ESC with just drag reduction mode and hopefully vs completely off the same day for comparison?
This might sound crazy but I might get this kit and run it in drag reduction mode only. 10-20lb-ft more than stock peak torque everywhere will be about perfect for me.
I have a question, if the drag reduction works off the manifold pressure to control motor speed, why can't it be used to maintain boost (pressure) when WOT as well?
DR is used to match manifold pressure to negate the effects of having the SC in the intake track.
I dont think it will net 20tq though. It will make the engine happier, my guess is about 5 to 10tq though.
The bread and butter of this is the WOT operation, the DR is just a nice touch that maintains your previous NA performance.
fenton is offline   Reply With Quote
Old 09-24-2013, 10:05 PM   #1934
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by rusty959 View Post
Sounds about right. And honestly for me, a 4:1 ratio is perfect. I doubt I would ever top that.
25.5V is about what I was expecting. I'm just curious how a setup like this would run with say a few hundred farads or so in parallel. If that 21V could be held closer to that 25V range the performance benefit would be pretty substantial. I know this has been talked about here and there but as far as I know hasn't been tried. Someone should send a kit to @neutron256 and let him throw his caps he has laying around on it to see what happens.
Running caps in parallel is one of the things I plan to try when I get my system up and running.
The Following User Says Thank You to neutron256 For This Useful Post:
DAEMANO (09-25-2013)
Old 09-24-2013, 11:40 PM   #1935
autobrz
Drives: Mazda 3
Originally Posted by fenton View Post
Ill let Rob respond to this properly.
Maybe you can elaborate as well, are you meaning to maintain boost in the higher RPM?
Because keeping boost up requires more motor speed, and amps which both the motor and the controller are not capable.
I meant I would like boost to be the same across all rpm range which I guess means limiting boost to 1 psi across the board in order to not feel a drop-off in torque. I figured drag reduction requires changing motor speed already, it might be doable when the WOT means maintaining 1 psi?
Why do I want a slower car? because I like how the stock motor feels the best at 6500 rpms and like to keep that character of the motor even if it means slower. I'm not racing anyone and in the narrow and winding canyon roads, having more power sucks and is probably dangerous for my driving skills, lol...
p.s. the reason why a lot more power sucks in the canyon roads is because I can't put my foot down for nearly as long before having to brake and I have to brake a lot earlier and the driving becomes more work and less fun.
autobrz is offline   Reply With Quote
Old 09-25-2013, 12:22 AM   #1936
fenton
DR looks at matching a certain level of vacuum, to do that it pulses the motor. Im not sure how that theory would transfer into maintaining positive boost but i cant imagine it is that great.
Honestly, i can kind of see where you are going here with the "maintaining the engine's characteristics"...however, If you could drive one of these phantom supercharged cars you would see that it isn't a crazy amount of power.
Its very smooth/fluid and above 4000 rpm it just feels like you got more power.
First person ever i have met saying, "sucks having more power".... that just sounds crazy :P
What could be possible is "sucks having too MUCH power" IE having so much power that you wheels are spinning to 7000rpm every time you touch the gas in 2nd or third gear. That i could see.
Im sorry im just having a hard time reasoning with this, all for just 1psi.
Long story short, yes its probably possible..... do i think its the best option... maybe not, but who am i to tell you what is right and wrong
The Following User Says Thank You to fenton For This Useful Post:
autobrz (09-25-2013)
Old 09-25-2013, 09:33 AM   #1937
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Off to see Moto-Mike for a tune later today. Hopefully I'll have dyno results to share later today. While I've been modifying cars for decades, I've never participated in a dyno ECU tune (I've always just purchased a new ECU) so this will be a real learning experience for me. I've dyno tuned motorcycles, but changing jets and changing bits are two completely different functions.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 4 Users Say Thank You to Gary in NJ For This Useful Post:
bfrank1972 (09-25-2013), Bu-Tang (09-25-2013), fenton (09-25-2013), raven1231 (09-25-2013)
Old 09-25-2013, 09:57 AM   #1938
fenton
Cool, all the best!
Make sure you pull the SC off and use the stock intake for a baseline.
Old 09-25-2013, 10:13 AM   #1939
Gary in NJ
Gary in NJ's Avatar
Cool, all the best!
Do you think there would be much of a difference between just leaving the SC unarmed vs reverting to the stock intake tube?
Old 09-25-2013, 10:25 AM   #1940
mid_life_crisis
Drives: FR-S 10 #103 AT
It sounds like all you need is a good tune. Have you checked out the thread for the openflash tuner? A tune and maybe a rear gear change would probably be plenty for you.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Old 09-25-2013, 10:46 AM   #1941
bfrank1972
Drives: 2013 FR-S Argento
I think this is one of those questions that have been floating around but not really confirmed - I would think so, but maybe not much? Ideally it would be nice to have 4 curves to compare: baseline, installed not tuned, installed tuned armed, installed tuned disarmed. Maybe even a WOT run with DR but not engaging the supercharger (switch disabled), but might be getting a little crazy. In the name of science!.. I also realize it's your extra effort and money to do that, so anything you could provide would be appreciated :happy0180:
Old 09-25-2013, 10:51 AM   #1942
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
x2...hopefully we see some good results
brichard0625 is offline   Reply With Quote
Old 09-25-2013, 10:57 AM   #1943
fenton
Yes it will make a difference. The SC while not engaged is a restriction without drag reduction.
It isnt much for every day driving(part throttle - most people dont even notice) but going WOT without the charger on or DR activated will cause a loss in HP. Its really a edge case because you are never going to be going WOT without the system armed.
Its just good practice to get a solid baseline without the charger on and lets be honest its only a 2 minute job to disconnect.
I dont have DR on my current controller.
Old 09-25-2013, 11:04 AM   #1944
Gary in NJ
Gary in NJ's Avatar
I was wondering about that.
I may do a double baseline to see what the effect really is. As you say...it's really a moot point anyway.
I'll see how much time Mike has to play.
The Following User Says Thank You to Gary in NJ For This Useful Post:
p00mba (09-25-2013)
Old 09-25-2013, 12:38 PM   #1945
autobrz
Drives: Mazda 3
That's an excellent suggestion. Thanks
Old 09-25-2013, 02:04 PM   #1946
p00mba
p00mba's Avatar
Drives: FR-S :)
@Gary in NJ let me know how it goes i'm thinking about going out to him to get my tune as well...
p00mba is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
