| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2003 Subaru Outback
The most narrow wheel the PSS comes in with a 35 sidewall is 245. 40 is the least sidewall available for a 225.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#16 |
I Love custom Turbo kits
Drives: Limited BRZ
Ok, in that case, the speedo difference is about 2-3 mph. Not a big deal either.
#17 | |
| The Following User Says Thank You to Tansey86 For This Useful Post: | Sportsguy83 (09-24-2013) |
#18 |
Drives: 2013 Subaru WRB BRZ Limited Manual
If I were to get 245 which has 35z18, what would be different other than the obvious weight? Would it be louder and a more harsh ride? I have Eibach lowering kit which drops it by almost 1"
#19 |
The issue is you have a 18x8 size wheel. You need a wider wheel to use that wide of a tire correctly. The ride noise/harshness would not be very noticible. The PSS have a stiff sidewall so the transition from one tire to the next will cause more a impact than the sidewall height.
#20 |
Ah okay, thanks for the help guys. I will most likely go with 225 or 235 40zr I guess. One last question unrelated to tires. With the new wheel, I need tpms right? Where can I get those for a decent price?
#21 | |
TPMS you can steal from your stock wheels and re-use. You don't NEED them per-say, but you will always have that light on the dash if you don't put them on. That, or disable the light. I say its a great feature and a safety feature as well. Expensive, but worth having especially if you re-use your stock ones for free. |
#22 |
I am going to use the stock with winter tires. It would be a pain to have to constantly switch them every time I swap back(well not really, but I rather not). Do they have to be programmed to work with my car by someone, or is it plug and play?
#23 |
I'm getting PSS 225/45r17s on 17x7.5s. That seems to be the standard tire size for that size rim. I would think you would want to go with at least 235s on 8 inch wide wheels.
| Alignment Shop/ tire changing recommendations | HATED1 | Northwest | 4 | 09-20-2013 06:03 PM |
| Tire Recommendations | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 09-17-2013 12:06 AM |
| Inexpensive but Safe Tire Recommendations? | Anthony | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 08-14-2013 12:18 AM |
| Recommendations to a speed/wheel/tire shop around orange county?? | eddieEndo | Southern California | 6 | 02-10-2013 08:36 AM |
| Need Tire recommendations please, non track use | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 01-03-2013 05:15 PM |
