Old 09-23-2013, 09:31 PM   #1919
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by bfrank1972 View Post
what your general impression?
It's a great addition to an already fun platform. The only complaint I've had about my BRZ has been power delivery (or lack thereof) below 5000 rpm. The ESC completely remedies this lack of performance. Every review you read about the -86 makes this same comment - so it's no surprise. What would be surprising to any of those magazine reviewers is how this simple device transforms the power delivery and drivability of the car.
Rough around the edges/needs some refinement (i.e. how it installs, fit/finish, any hiccups other than the CEL etc)? Or do you feel like it's pretty near prime time?
The installation was a snap, but then again I have built an airplane and rebuilt motorcycles...so maybe I'm not the "average guy". Even so, I thought the installation went flawlessly. I've made some recommendations Rob to help the process. I think the fit and finish of the compressor and motor are damn near perfect. The packaging of the controller/charger is very well done. From photos you may think that the throttle switch is lacking, but the truth is it's a solid design. It would be nice if there were two attachment points for the switch, but the design of the OEM throttle leaves few (no) options. I think an installer would do well to strap the three batteries together (around the sides). I also would like to find a better way to install the controller...but once again, there are just limited options. The controller needs to be mounted as close as possible to the compressor and the batteries...I can't think of another location...but maybe a different bracket. Maybe a winter project.
How does the transition feel from part throttle to ESC engaged? I know you're sans tuned - I'm just curious how well the system integrates on a non-tuned car (know CEL issues aside). Gracias!
It feels like any well integrated turbo. Boost hits hard in the lower rpm's. Boost doesn't build as it does on a turbo or SC...but then again, boost doesn't come on in a turbo or SC like it does with the ESC. When I first installed the ESC it took about 500ms for it to spool up. Now that the batteries are conditioned, it's probably just 250ms. Oh, something else...with the radio off you can hear this thing spool up. It sounds quite cool.
The travel on the -86 throttle is so short that it doesn't seem unnatural to put the throttle to the floor. Heck, before I installed the ESC my throttle was usually at WOT. Now when I go WOT, something actually happens.
Is it ready for primetime? I can't answer that because the final product is not my vision, it's Robs. With that said, I'm 100% satisfied with the result.
The part I really (and I do mean really) like; 99% of the time I don't need the power, so the car is as economical as its always been. But when I want to pass, accelerate or just hear my exhaust howl, power is just about 3 inches of travel away...and then it's back to the way it was. 5 to 10 seconds of boost is a lot on public roads. Yes, the ESC will make boost for many multiples of this time, but on the street...with 10 seconds of boost, you'll be exceeding any speed limit in North America.
When Rob makes this available, buy it. If you've read through 1,800+ posts for all of these months, you know what the ESC is and what it isn't. You wont be disappointed. It delivers. It really is the ultimate bolt-on.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 9 Users Say Thank You to Gary in NJ For This Useful Post:
bfrank1972 (09-23-2013), BlueDubbinTDI (09-23-2013), Bu-Tang (09-25-2013), immaculate (09-24-2013), jflogerzi (09-26-2013), Pug (09-24-2013), Robftss (09-24-2013), SloS14 (09-24-2013), zc06_kisstherain (09-24-2013)
Old 09-23-2013, 10:04 PM   #1920
bfrank1972
Drives: 2013 FR-S Argento
Brilliant. Thank you for the concise and well thought out post. That's a pretty strong endorsement, especially for a non-tuned car! I think a lot of people will be very excited once this thing becomes publicly available...
Old 09-23-2013, 10:27 PM   #1921
jpit
Drives: Subaru BRZ
What exactly does the arming switch do? Why wouldn't you leave it on all the time? Also,
doesn't the compressor operate slightly to avoid cutting the amount of air entering the intake manifold when not having a WOT?
jpit is offline   Reply With Quote
Old 09-23-2013, 10:36 PM   #1922
fenton
You should leave the arming switch off when the car is off because it will eventually kill the battery. Just think, you are driving around using the supercharger and you shut the car off. Your main battery is still going to top up the dump batteries after the car is off(with system still on). If the main battery goes below a certain voltage the ecu can tell the car to not start.
The compressor is very large and air can pass though it normally as it free wheels. Once it becomes a restriction later on in the rpm drag reduction starts it spinning to equalize pressure.
Long story short.... Car on system armed..... Car off system off.
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
Old 09-23-2013, 10:43 PM   #1923
fenton
I should also mention that under no circumstance should you arm the device while already wot! It is extremely hard on the control box and Rob said if you did it even a couple times you are likely to blow the capacitors in the controller.
The Following User Says Thank You to fenton For This Useful Post:
DAEMANO (09-24-2013)
Old 09-24-2013, 12:23 AM   #1924
jpit
Drives: Subaru BRZ
Why couldn't the arm switch be connected to a 12V source that turns off when the ignition is off to prevent the batteries from discharging?
The Following 2 Users Say Thank You to jpit For This Useful Post:
neutron256 (09-24-2013), NoChance (09-24-2013)
Old 09-24-2013, 01:06 AM   #1925
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
@jpit That's one of the things my advanced monitor does; it replaces the arm switch with a relay keyed off the 12V accessory with a microprocessor-controlled timer (not ignition, I'm too lazy for that).
Alternatively, you can add a relay to the engine bay with an add-a-fuse, but there's no way that I've found yet to do it on a BRZ without drilling a hole in the fuse box. Be sure to use a DPDT or DPST relay though, as there are two circuits that must be broken.
Pug is offline   Reply With Quote
The Following 2 Users Say Thank You to Pug For This Useful Post:
DAEMANO (09-24-2013), Robftss (09-24-2013)
Old 09-24-2013, 09:01 AM   #1926
fenton
UPDATE
Was thinking about this the other day so i tried to record some video's.
I got 2 video's 1 is just 10 seconds acceleration starting at bottom of third and into 4th(sorry window open)
[ame="http://www.youtube.com/watch?v=n1XvfYcm0es"]FRS Brz phantom electric supercharger 3rd to 4th - YouTube[/ame]
The next i did in 4th gear and only managed 4 seconds of acceleration which took me from 80 to almost 140!
[ame="http://www.youtube.com/watch?v=Pl5aN3oQaOk"]FRS brz phantom supercharger 4th gear - YouTube[/ame]
PS. Look at that recharge, its almost instant!!
Old 09-24-2013, 10:16 AM   #1927
rusty959
Drives: DGM BRZ limited
UPDATE
This has been said before, but just because the voltage jumps back up to 28.3v does not mean it is recharged. So you are fair to say "PS. Look at how fast it starts recharging again, its almost instant!!" but not that it is recharged as saying recharge is almost instant implies.
Additionally, just because your voltage drops to 21v doesn't mean it is discharged, just that it is at the time discharging. It dropping so low while you have it engaged due to internal resistance in the battery and possibly wires and such. Now over a period of it discharging yes the voltage will drop further due to loss of charge.
This might be a point of interest because if you kept the voltage up higher due to better batteries or capacitor bank you would get better performance. On that note, what is the resting voltage of your batteries?
rusty959 is offline   Reply With Quote
Old 09-24-2013, 11:01 AM   #1928
Robftss
Drives: VW
Yes, not instant.
Referring to the '4sec boost' vid:
21V is Vdrop during discharge/engagement, ~28.0V recovery, then charge.
Fenton's set up is ~ 4:1, so 4 sec (boost) and 16 sec to restored used capacity but dump pack has ~1:00 minute of sustained capacity.
The voltmeter is just for reference of current condition and a diagnostic tool for me.
Resting is 25.5V as with all SLA's in this configuration.
Rob.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
Old 09-24-2013, 11:21 AM   #1929
rusty959
Originally Posted by Robftss View Post
Yes, not instant.
Rob.
Sounds about right. And honestly for me, a 4:1 ratio is perfect. I doubt I would ever top that.
25.5V is about what I was expecting. I'm just curious how a setup like this would run with say a few hundred farads or so in parallel. If that 21V could be held closer to that 25V range the performance benefit would be pretty substantial. I know this has been talked about here and there but as far as I know hasn't been tried. Someone should send a kit to @neutron256 and let him throw his caps he has laying around on it to see what happens.
Old 09-24-2013, 01:52 PM   #1930
fenton
You are correct. The point that i was really trying to make was what 4- 10 seconds of boost equalled in terms of raw speed.
Old 09-24-2013, 02:51 PM   #1931
autobrz
Drives: Mazda 3
Anyone had a chance to dyno the ESC with just drag reduction mode and hopefully vs completely off the same day for comparison?
This might sound crazy but I might get this kit and run it in drag reduction mode only. 10-20lb-ft more than stock peak torque everywhere will be about perfect for me.
I have a question, if the drag reduction works off the manifold pressure to control motor speed, why can't it be used to maintain boost (pressure) when WOT as well?
autobrz is offline   Reply With Quote
Old 09-24-2013, 03:50 PM   #1932
fenton
Ill let Rob respond to this properly.
Maybe you can elaborate as well, are you meaning to maintain boost in the higher RPM?
Because keeping boost up requires more motor speed, and amps which both the motor and the controller are not capable.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
