Old 09-21-2013, 04:58 PM   #43
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by pixel67 View Post
False alarm. Not being picked up today as they don't have a tech working on a Saturday to finish it up. It wasn't being tuned yet...
They were having some issues installing it if I recall correctly. Supposedly the FA20 kit doesn't fit all that well.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-21-2013, 07:28 PM   #44
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Some confusion around the correct mounting of the down pipe. They were able to figure it out.
Sent from my Nexus 7 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 09-21-2013, 08:46 PM   #45
cb7tuner
Drives: 2013 whiteout FR-S
Mine fit perfectly fine
cb7tuner is offline   Reply With Quote
Old 09-22-2013, 06:35 PM   #46
pixel67
pixel67's Avatar
Yeah, I am at a disadvantage since I am not there in the shop looking at the parts myself. The big drawback of having a shop install another shops kit is the potential for finger pointing. In many ways these guys are competitors...
Old 09-22-2013, 09:17 PM   #47
cb7tuner
Hell, I could have thrown it on there for you, took me 6 hours start to finish
Old 09-22-2013, 10:34 PM   #48
pixel67
pixel67's Avatar
Man, you sure know how to kick a guy when he is down.
Old 09-23-2013, 09:48 AM   #49
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
As you're getting yours done, I'm getting my turbo rebuilt lol. I blew the seals right off the bastard
Shoulda went Garrett turbo bro. Still not too late to switch to a GT2871R.
Old 09-23-2013, 04:43 PM   #50
cb7tuner
My buddy is actually trying to sell me his barely used t3/t4 gt2871r off of his 240 that ran for like a month. Only question is, where did you tap into your motor / coolant system for your turbo water lines?
Old 09-23-2013, 04:48 PM   #51
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The Full Blown kit by default uses the throttle body coolant hoses and a weird looking brass T, but I didn't like that setup so when I pulled my intake manifold to fix the hose that blew off, I plugged the ports on the throttle body (don't really need to) and ran my hoses from the turbo to where the throttle body coolant lines came from which is the aluminum channel that is under the intake manifold and mounts to the top of the block and a hose barb on the back driver side of the block.
Old 09-23-2013, 05:24 PM   #52
cb7tuner
Wink
Nice!! I'll do some looking around under the manifold. Thanks
Old 09-24-2013, 09:44 AM   #53
Synack
Boosted
Synack's Avatar
Drives: Sideways
Just had to replace a cracked stock manifold lol, bought Agency Power to replace it.
Clutch line is getting bled to hopefully fix the clutch issue, only engages 80% at most.
Sending turbo back to Precision for warranty rebuild, if you send to them overnight they will put it at the front of the line and fix it ASAP and send back overnight at their own expense, pretty f()ckin cool!
Old 09-24-2013, 10:30 AM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Unless you have found a leak or fluid, this will 80% chance not fix the issue. Knowing you, there is some clutch or throwout bearing damage.
Old 09-24-2013, 09:24 PM   #55
Synack
Boosted
Synack's Avatar
Drives: Sideways
Don't kill my chances man. I'll be looking at a $2000 bill if it's anything actually inside of the trans that's messed up.
Old 11-27-2013, 11:09 PM   #56
Taz
Master of What
Drives: Asphalt FR-S
Staying on topic, is there anyone with a s/c in the ATL area? I was about to post my own thread and found this one.
2013 Asphalt FR-S, K&N drop in, poly on stock bars
2004 Sienna Van chase vehicle, awesome steel wheels, full size spare tire
2015 Camry with one power seat
Taz is offline   Reply With Quote
Atlanta/SE area hook up - LED bulbs chuchutrain Southeast 0 07-17-2013 11:09 PM
I Just Saw another FRS (Atlanta area) Ahernandez0909 Southeast 9 02-22-2013 06:16 AM
SPOTTED FRS/BRZ ATLANTA AREA ravenblackfrs Southeast 1 12-22-2012 09:33 PM
Atlanta Area Manual FT86 Dominic@CCI Southeast 0 08-22-2012 01:12 PM
Scion FR-S Coming to Atlanta area fastdrivingjr Scion FR-S / Toyota 86 GT86 General Forum 17 05-17-2012 10:56 PM
