Old 07-19-2013, 01:16 AM   #71
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by wootwoot View Post
Agree on both points. I want to like the diffuser... but it just sticks out a bit too far. My suggestion would be to stop it at the black plastic piece under the bumper. I would also line up your fins with the "fangs" on either side of the reverse light. It is so close to being the PERFECT aero upgrade! Just my opinion of course.
Very nice work none the less. Keep it up. Your car is beautiful.
Send your comments to the guy that made it @Wonderbar and perhaps he will work them into a redesign.
Old 07-19-2013, 01:17 AM   #72
stockysnail
Just the tip
Speed bleeders ordered for my brake pad and fluid upgrade as seen in the great post on this forum:
http://www.ft86club.com/forums/showthread.php?t=20311
Old 07-20-2013, 03:08 AM   #73
stockysnail
Just the tip
Greddy red short lug nuts finally arrived after over 2 months waiting on a backorder. They are so light it's crazy. They look good too!
Pics added to bottom of first post.
Old 07-21-2013, 05:21 PM   #74
stockysnail
Just the tip
BRZ Cupholder Plates Red/Black ordered from Diodedynamics.com
Old 07-25-2013, 02:02 AM   #75
stockysnail
Just the tip
BRZ Cupholder Plates Red/Black from diodedynamics.com added today. See first post down a ways for a picture.
Old 08-04-2013, 04:43 PM   #76
stockysnail
Just the tip
Here's what I installed today on my BRZ:
Carbotech AX6 brake pads
Motul RBF600 Racing Brake Fluid
Speed bleeders SB1010-SS
MTEC transmission shift spring kit
See first post for details on the part install and impressions.
Old 08-06-2013, 12:58 AM   #77
stockysnail
Just the tip
Update on Carbotech AX6: These pads squeal like a pig so I won't be using them for daily driving after the track day in a few days. They will be saved, swapped, and used for track and autox however. They stop like mad, just can't handle the squeal when driving every day. I never drive crazy/hard enough on roads to need a pad and it's higher heat range anyway. After I wear through the 2 sets of oem pads I have I think I'll go with Carbotech's street pads which are one step down from the AX6 pads. Swapping pads on this car is so simple that I'll be doing just that for track/autoX/rallyX/Hillclimb days.
Old 08-16-2013, 02:35 AM   #78
stockysnail
Just the tip
Ordered a super light aluminum drive shaft that's even lighter than all the carbon fiber ones I've seen. Here's the post about it. http://www.ft86club.com/forums/showthread.php?t=44150
Old 08-24-2013, 07:23 PM   #79
stockysnail
Just the tip
Grimmspeed strut bar in red added to first post. More red bits for my car.
Old 09-01-2013, 03:17 AM   #80
stockysnail
Just the tip
I installed my new Axle-Exchange aluminum drive shaft that weighs only 12lbs yesterday. See first post for video and impressions.
Old 09-01-2013, 09:16 AM   #81
mfbmike
Drives: 2013 FRS, 2008 R32
I also got into an 86 twin from an (mkv) r32.
Miss your R32 at all?
mfbmike is offline   Reply With Quote
Old 09-15-2013, 09:44 PM   #82
stockysnail
Just the tip
Ordered a couple parts today.
-Raceseng Cam Plate
-Raceseng red rear tug tow hook
Old 09-22-2013, 12:32 AM   #83
stockysnail
Just the tip
Things I added to my car this week:
-Sound dampening throughout the car
-Car door laser Projector autobot logo.
-Raceseng red rear tug tow hook (they also have a gopro mountable version)
Old 09-22-2013, 08:38 PM   #84
stockysnail
Just the tip
Here are the decals installed on my car, **see first post at the end**. Thanks Kevin aka @digital_assassin
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
No Limit's DGM BRZ limited build thread No Limit Motorsport Member's Car Journals 10 05-10-2013 12:09 PM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 12:50 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 12:56 PM
