Old 09-21-2013, 11:58 PM   #351
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by retrosmiths View Post
Here's a pic..
No pic...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-22-2013, 02:33 AM   #352
retrosmiths
Drives: Scion FR-S Whiteout
It didn't attach the previous time lol.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 09-22-2013, 02:46 PM   #353
vincent201089
vincent201089's Avatar
Drives: frs
looking great so far. All it needs now is a final sanding and polishing, I guess.
vincent201089 is offline   Reply With Quote
The Following User Says Thank You to vincent201089 For This Useful Post:
retrosmiths (09-22-2013)
Old 09-22-2013, 03:40 PM   #354
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Mine have a semi matte finish to them as well. I pre sanded with 800 grit and put about 3-4 coats of the red Metalcast. I wet sanded 2000 grit in between coats as some dust got on the paint. The wetsanding seemed to make it worse as it was very clear before I wetsanded it again. I sprayed about 3 coats of clear on it. I'm hoping after I let it cure for a week that when I polish the lights the gloss will come out.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-22-2013, 04:12 PM   #355
retrosmiths
Yeah, there are also dusts in between the clear coats that I did, but they are barely noticeable and sanding them out would not be feasible for me as the 2K Clear Coat can only be used within 24-48 hours after activating.
When I did the 3x light coats of clear, the texture is still matte and I was getting a bit worried, so the next 2 coats I sprayed on heavy and it worked! I got the gloss that I wanted.
2013 Scion FR-S
Old 09-22-2013, 05:06 PM   #356
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
retrosmiths, do you have any more pics you can post maybe at different angles? Any pics from during the process at each step?
B-R-Z is offline   Reply With Quote
Old 09-22-2013, 07:54 PM   #357
retrosmiths
Not for every step, but here's how it looks like last week when I sanded and painted them red:
And here's after I cleared them:
Next week, I will polish the surface and get rid of the orange peels and surface irregularities, and achieve more shine at the same time.
2013 Scion FR-S
Old 09-22-2013, 08:14 PM   #358
B-R-Z
B-R-Z's Avatar
Looks nice, post pics when you're done. I just ordered my spraymax 2k, I will be doing mine hopefully next weekend.
The Following User Says Thank You to B-R-Z For This Useful Post:
Fizz (09-22-2013)
Old 09-23-2013, 11:36 AM   #359
Tt3Sheppard
I've noticed there is a certain appeal to the more matte red finish. I kind of like it.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 09-23-2013, 12:35 PM   #360
retrosmiths
Well the matte look isn't even all around (probably the way I sanded it), which causes uneven distribution of light when it's on, which doesn't look so good.
2013 Scion FR-S
Old 09-24-2013, 01:32 PM   #361
xxscaxx
Just an FYI, I didn't sand my stock tails. I cleaned them well, then applied the metalcast.
Maybe thats why your tails were a bit hazy. I also noticed you have some orange peel, mine don't have that at all. hmm.
Either way, still looks good.
xxscaxx is offline   Reply With Quote
Old 09-24-2013, 01:40 PM   #362
Tt3Sheppard
So I should apply a few more coats of clear and the haze should go away?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 09-25-2013, 06:41 AM   #363
Shawnofthedead
Shawnofthedead's Avatar
Drives: Black on black with so much class
Very useful thread 'twas a success
Shawnofthedead is offline   Reply With Quote
Old 09-27-2013, 08:12 PM   #364
B-R-Z
B-R-Z's Avatar
I'm going to do mine tomorrow. Is it best to apply the red then wait a few days to do the clear or is same day better? I just read on metalcast site that if you wait over an hour between a coat that you have to wait like 6 days to respray. Does this only apply to metal cast coats or clearing after the metalcast?
Can someone who has successfully redded with the below cans please post your prep procedure and dry times between red coats and time between red and spraymax?
Using metalcast and spraymax 2k.
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 10:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
