Old 09-20-2013, 10:24 PM   #1
Salgts86
Drives: tornado Grey Manuel
cheapest HP improvements for under $500
Hi, My wife runs the car daily to n from work, and I get to drive it when we go out for dinner with friends etc...
What I'm wanting to do is a simple few tweeks to the bog stock standard 86 (all at once whilst the misses doesn't know) include
Perrin Crank Pulley (majority of weight saving is here so can't justify the extra expense for the set)
K&N/ Perrin air filter for stock air box (30% less resistance to standard flow)
My own forced air induction system designed and installed using house hold plastics and tools
Exhaust tape for Headers and mid Pipe etc...
has anyone got any more cheap ways to increase HP... regards Pete... PS my first attempt at posting...
Salgts86 is offline   Reply With Quote
Old 09-20-2013, 10:28 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
you say household plastics... all i see is an 86 with this...
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Enraged21 (09-21-2013)
Old 09-20-2013, 10:32 PM   #3
Salgts86
Hey thanks Supra,, I hadn't thought to use PVC pipe?!? Wonder if it comes in black lol
Old 09-20-2013, 10:33 PM   #4
Tiremonkey0824
Drives: 2013 Argento 6mt
How are you going to make a forced induction system out of household plastics?
Tiremonkey0824 is offline   Reply With Quote
Old 09-20-2013, 10:35 PM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Rotate your distributor to advance the timing a bit..oh wait, it's 2013. There is no cheap horsepower for NA cars anymore.
I'd look into one of those Open Tablet whirlygigs or one of those BRZEdits if you want a noticeable improvement for under $500.
Old 09-20-2013, 10:53 PM   #6
utekineir
blowhard
Drives: frs, project forester
Turbonator comes in awesome colors now.
/thread
utekineir is offline   Reply With Quote
Old 09-20-2013, 11:12 PM   #7
Salgts86
Wink
many ways to do this... all is required is to direct Cooler air from in front of the Radiator...using Kiwi Know how!! will post pics once it has been done.. Buy redirecting air flow away from the Radiator and into the ram air will not be hard..
Forced induction on naturally aspirated engines will pretty much increase volumetric efficiency to 100%
Old 09-20-2013, 11:12 PM   #8
ciro
Drives: Scion FR-S
What is going on tonight with these thread!
ciro is offline   Reply With Quote
The Following 2 Users Say Thank You to ciro For This Useful Post:
Anthony (09-21-2013), ftc~brz (09-26-2013)
Old 09-20-2013, 11:17 PM   #9
Tiremonkey0824
Do you even know what forced induction is?
The Following User Says Thank You to Tiremonkey0824 For This Useful Post:
Wo6M (09-21-2013)
Old 09-20-2013, 11:39 PM   #10
Salgts86
TireMonkey, You have little to contribute and looking at your past posts and you don't have much to contribute other than correcting peoples terminology of words... I used the term loosely to explain Ram Air...
At speeds faster than 30kph any redirected Air into a standard air box will in its self be Forced induction as any Motorcyclist will understand?
What engine improvements have you done on your Car that increased HP through slight changes? I'm suspecting very few for a lot of Dollars? which in terms of HPx$ was very expensive!!
Old 09-21-2013, 12:09 AM   #11
Tiremonkey0824
A) Thanks for stalking me but your assumptions about my contribution to this forum are false. Also when people use the term forced induction around this forum they usually mean super/turbo charger. Which is why I was wondering how you were going to accomplish this with "household plastics".
B) I never said anything about my engine improvements or that my car was better than anybody else's. If you really want to know what I have done to my vehicle then check my garage. You probly should have done that while you were stalking me.
C) You probly shouldn't criticize others about contribution to a forum when you only have 11 posts.
Old 09-21-2013, 03:56 AM   #12
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
Twin Leaf Blowers = Twin TURBO!!!!!!!
jk
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
The Following User Says Thank You to Lanbaldo3 For This Useful Post:
mikepaul21 (11-18-2013)
Old 09-21-2013, 10:16 AM   #13
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
This would have been true 30 years ago but now everything is controlled via the ECU and MAF sensor. It isn't as easy as just blowing more air through the intake using homemade plumbing. Good luck with the trolling and all.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 09-21-2013, 10:30 AM   #14
Muskokan
Drives: white Sport-tech
Yea Ive been planning on making a turbo out of my vacuum, I estimate 80-120 Hp improvement at only " medium " height floor setting. It's a Dyson so I can only assume it's gunna be just as, or more reliable than a stock turbo if it ever came out.
Next I plan on making a set of coil overs for under $50 using high grade slinkies, stay tuned!
Op was trolling right? Lol
Muskokan is offline   Reply With Quote
The Following 3 Users Say Thank You to Muskokan For This Useful Post:
Anthony (09-21-2013), mikepaul21 (11-18-2013), sklimo (11-14-2013)
FA20CLUB Innovate Supercharger Tuning, Parts, Improvements & Results FA20Club.com Forced Induction 143 12-18-2013 08:48 AM
Cheapest GT86 Badges gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 5 12-17-2013 06:28 AM
Hypothetical: Cheapest way to 200 whp w/o E85 m.wood0213 Engine, Exhaust, Transmission 19 09-16-2013 07:05 PM
cheapest oem parts Bt216 Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2013 07:40 PM
Cheapest paid for Evo 3? TheGuyWithTheFireStorm Engine, Exhaust, Transmission 15 07-02-2013 12:04 AM
