Old 09-16-2013, 10:25 PM   #1
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
BBS SR - 17x7.5 +48 & 18x8 +48
I stumbled across these on Tire Rack and really like them, despite the conservative offset. Currently trying to decide between 17x7.5 (21.8lbs) ($215 each) or 18x8 (24.6lbs) ($265 each). Thoughts?
Originally Posted by humfrz
I'm old and lazy
Laika (09-17-2013)
Old 09-17-2013, 03:20 PM   #2
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Wow, great find! I might consider these as they are the perfect specs. Weight will be the deciding factor..
ap5512 is offline   Reply With Quote
Old 09-17-2013, 03:23 PM   #3
KSpider
KSpider's Avatar
Drives: '14 S4
I really liked them too, but I couldn't wait the 6 weeks!
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 09-17-2013, 04:01 PM   #4
mid_life_crisis
Drives: FR-S 10 #103 AT
I saw the title and thought you were going with different diameters front and rear.
Like the rims though.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-17-2013, 07:32 PM   #5
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Holy sex those are nice. Hows the weight?
Mobius357 is offline   Reply With Quote
Old 09-17-2013, 09:18 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
I'm not sure yet on the weights, I've emailed Tire Rack and BBS and I'll make a post if they reply.
Here's some info about the wheel from BBS' site, they're calling it a winter wheel, hope that doesn't mean it's overly heavy.
"The new BBS premium winter wheel combines elegance and sportiness with maximum functionality. True to the BBS company philosophy, it is completely and exclusively produced in Germany, just like all other models of the manufacturer.
Soft radii and contours from the hub to the flange enable easy wheel cleaning, which proves itself extremely practical especially during the winter. Nevertheless, the rim design speaks loud and clear and unmistakably identifies the new addition from Schiltach as a distinguished member of the BBS family.
Spokes that continue through to the hub bore make the SR model seem bigger. Even in 16 inches, the smallest available size, the wheel makes a significant impression."
I'm old and lazy
Old 09-17-2013, 11:04 PM   #7
Kostamojen
Whoa... these look fantastic!
I hope the weights are good.
Old 09-17-2013, 11:27 PM   #8
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Looking at some of the other BBS wheels on tirerack, I'm not sure these wheels will be that light
G_Ride is offline   Reply With Quote
Old 09-17-2013, 11:29 PM   #9
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Those look sick! Hadn't seen this style yet! Post some pics if you end up getting them!
tuckdaddy is offline   Reply With Quote
Old 09-18-2013, 05:30 PM   #10
Mobius357
@G_Ride good point, the other wheels are 21-22lbs for 17x7.5. This will likely be in the same area, that's too bad. If only TSW made a rotory forged split 5 spoke.
Old 09-18-2013, 11:25 PM   #11
DAEMANO
Time Traveller
Lightbulb
Here's some actual data to go by (remember '86 stocks are approx 20.1 lbs)
Name|Method|Size|Lbs
BBS RV Cast 17x7.5 18.4 lbs **lightest 17
BBS CH Cast 17x7.5 20.2 lbs
BBS RK II Cast 17x7.5 20.7 lbs
BBS RX Cast 17x7.5 20.9 lbs
BBS RX II Cast 17x7.5 21.2 lbs
BBS VZ Cast 17x7.5 22 lbs
BBS CV Cast 17x7.5 22.5 lbs
BBS RW II Cast 17x7.5 22.6 lbs **heaviest 17
BBS RC Cast 18x8 19.5 lbs **lightest 18
BBS CK Cast 18x8 23.5 lbs
BBS RX Cast 18x8 23.5 lbs
BBS CH Cast 18x8 24 lbs
BBS SX Cast 18x8 25 lbs **heaviest 18
BBS VZ Cast 18x8 25 lbs **heaviest 18
Code:
From @DarrenDriven 's wheel weights thread
Average Wheel Weights by @coyote
I've listed what I'd consider to be average weights.
Anything under or over these ranges would be light
and heavy, respectively.
16x7 14-18lb
16x8 15-19lb
17x7 16-20lb
17x8 17-21lb
17x9 18-22lb
18x7 18-22lb
18x8 19-23lb
18x9 20-24lb
19x & 20x... Who cares, they are all heavy.
Old 09-20-2013, 02:22 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
Straight from BBS-USA:
The 17x7.5, 5x100, et48 (SR025SG) weighs 21.8 lbs.
The 18x8, 5x100, et48 (SR024SG) weighs 24.6 lbs
I'm old and lazy
DAEMANO (09-23-2013)
Old 09-20-2013, 02:52 PM   #13
jonbonazza
$216/wheel for BBS? Are they fake? O.o
jonbonazza is offline   Reply With Quote
Old 09-20-2013, 03:07 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
No.
I'm old and lazy
Wheel Directory: BBS RK 17x7.0 +48 Laika Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 05-21-2017 06:31 PM
18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back KSpider Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-14-2013 07:06 PM
18x7.5 +48/18x8 +43 staggered or 18x8 +43 square? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2013 02:56 PM
Wheel Directory: TSW Nurburgring 18x8.0 +45 / 18x8.0 +35 mike_ekim1024 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-10-2013 06:35 PM
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 xravexboix Wheels and Tires 0 05-24-2012 08:04 PM
