Old 09-20-2013, 01:05 PM   #15
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
Mine manual trans is still a little rough shifting. The warmer the engine the smoother it shifts. Waiting and hoping for the experience that many posters on this thread have achieved. I'm at 3,100 miles.
Jertronic is offline   Reply With Quote
Old 09-20-2013, 01:20 PM   #16
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Mine became really smooth when I finished a 5hr autox session lol.
bkblitzed is offline   Reply With Quote
Old 09-20-2013, 01:42 PM   #17
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
I used to have the difficult 2nd gear when cold requiring a doubleclutch until warm, but that went away at 2000mi, transmission is smooth in every gear now (at 5000mi stock fluids except oil)
kludger is offline   Reply With Quote
Old 09-25-2013, 04:38 PM   #18
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
I"m at 2500 miles and still tough to shift into 2nd in cold weather.
Must need better fluid
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 09-25-2013, 04:56 PM   #19
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
When completely cold in the morning, I make sure to be extremely gentle with the 1st-2nd gear change. If it won't go in easy, obviously don't force it! Just take another second and try again and it will go in. Once all warmed up, the gearbox is perfect.
I'm thinking about doing fresh fluids for the gearbox and diff though. My break-in peroid is over and it's a good idea to flush out any sort of metal shavings as with all new cars.
hmong337 is offline   Reply With Quote
Old 09-25-2013, 11:32 PM   #20
stugray
Drives: 2013 GBS BRZ Limited
I have ground my gears a few more times than I am comfortable with.
Sometimes it just seems to require two clicks instead of just one.
I have not changed the stock MT fluid yet.
However, I was wondering if some of the problem might be the fault of the hydraulic clutch....
I dont recall ever having a hydraulic clutch, maybe it makes the cold shift problem worse.
Should I flush & replace the clutch MC with the good blue brake fluid when I do the redline MT fluid change?
Old 09-25-2013, 11:56 PM   #21
torqdork
torqdork's Avatar
Drives: RV-7
That's what I did when I flushed the brakes. It made no difference. Tranny lube is what you'll notice.
torqdork is offline   Reply With Quote
The Following User Says Thank You to torqdork For This Useful Post:
stugray (09-27-2013)
Transmission frosty86 Issues | Warranty | Recalls / TSB 7 05-16-2013 03:15 PM
Smoothing out 1st and 2nd gears BRZerk Engine, Exhaust, Transmission 33 02-26-2013 06:30 PM
First Time Driving Manual Transmission...Need Advice! Veloist Off-Topic Lounge [WARNING: NO POLITICS] 30 01-02-2013 01:22 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 01:48 PM
