go_a_way1
Old 09-18-2013, 11:25 PM   #1891
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
With first hand experience on what Shiv was able to do with my BMW 335, I'm now even more excited about this ESC (if that is possible)
nlowell is offline   Reply With Quote
Old 09-18-2013, 11:35 PM   #1892
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Got your PM. Glad to hear from you again! The ball is rolling. Hopefully will be able to meet up with Gary in NJ this weekend to check out his electric SC set-up. And hope to test one in our own car soon as well. Of course, we will develop maps and release them to the public if we get to that point
Shiv@Openflash is offline   Reply With Quote
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
Bu-Tang (09-18-2013), DAEMANO (09-19-2013), MarcusM117 (09-19-2013), TIE Pilot (09-18-2013), waterbison777 (09-19-2013)
Old 09-19-2013, 12:21 AM   #1893
waterbison777
and if this happens, i know where about 2 grand of my savings will be going
waterbison777 is offline   Reply With Quote
The Following 2 Users Say Thank You to waterbison777 For This Useful Post:
Shiv@Openflash (09-19-2013), Thatruth2001 (09-21-2013)
Old 09-19-2013, 01:05 PM   #1894
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I thought I might share some of the details from my installation yesterday.
I wanted a stealth look for the indicator/arm switch. Also, I HATE the passenger warning. So I covered the passenger warning with the arm button. First I marked with a sharpie where I wanted the wire to pass through the radio radio surround. I then drilled three 1/8" holes and opened them up with a knife:
I opened the back of the indicator to see if there was a possibility to have the wire exit from the top of the box...there wasn't much room in there so I went to plan B. I put three drops of crazy glue on the outside of the unit and attached the wire to the unit.
Here's how it looks from an angle that you'll never see:
And here's how it looks to me...the only person that matters.
While I was in there I secured the wires for the throttle switch:
The easiest way to route the wires behind the instrument panel is to lower the glove box. This gives much better access to the VERY small passageways behind the IP. To lower the glove box there are two tabs on the side. Simply press them in and lower the box. Here is a shot of what you'll see (wires secured too)
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 10 Users Say Thank You to Gary in NJ For This Useful Post:
autobrz (09-23-2013), DaBrz (09-19-2013), fenton (09-19-2013), immaculate (09-19-2013), neutron256 (09-19-2013), NoChance (09-19-2013), p00mba (09-19-2013), Robftss (09-20-2013), Shiv@Openflash (09-19-2013), VR46 (09-19-2013)
Old 09-19-2013, 04:01 PM   #1895
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Gary in NJ.... That's a great spot, but I don't like the wire going around the side like that.
I wonder if the front of the switch can be flipped so the wire would be on the top? Rob??????
mtimney is offline   Reply With Quote
Old 09-19-2013, 09:51 PM   #1896
MarcusM117
Looks like its time for me to order my OFT! Can't wait
~2013 Scion FR-S~
~2004 Honda CBR600RR~
~Skip Barber Grad~
MarcusM117 is offline   Reply With Quote
Old 09-19-2013, 09:55 PM   #1897
Gary in NJ
Gary in NJ's Avatar
I'm not thrilled about the glued wire on the outside of the unit either, but the truth is once it's in place on the black surface of the IP, it isn't at all noticeable. Surely not while I'm driving...your eyes are drawn to the bright voltage reading.
The wires that enter the indicator are soldered to the switch and the circuit board. I felt if I tried to relocate the wire within the unit that one of those connections might not survive to move. Since there are so few "extra" components of this system in existence I felt it was better to tack 'em to the outside then risk rendering the system inoperable.
Old 09-20-2013, 01:03 AM   #1898
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
In other news: The advanced monitor's ready for installation into my car. I'll make a video tomorrow of it operating on the bench for one last time before I try it in the real deal.
I've posted the circuit design and software under the Apache 2.0 open source license to my GitHub page: https://github.com/jcjones/phantom-s...vanced-monitor. If you want to build your own, please note that I have errata listed for the current Fritzing diagram, and that I do plan to layout a PCB for manufacture at some later date.
Pug is offline   Reply With Quote
The Following 2 Users Say Thank You to Pug For This Useful Post:
DAEMANO (09-22-2013), VR46 (09-20-2013)
Old 09-20-2013, 10:16 PM   #1899
Pug
Atoning Unifex
Pug's Avatar
And here's the video. I hope to have some time this weekend to install it and see how it really performs!
[ame="http://www.youtube.com/watch?v=Ott8WUZGKK8"]Bench Test 2: Phantom Full-Throttle Supercharger Advanced Monitor - YouTube[/ame]
The Following 6 Users Say Thank You to Pug For This Useful Post:
Bu-Tang (09-22-2013), DAEMANO (09-22-2013), fenton (09-20-2013), s2d4 (09-21-2013), SloS14 (09-20-2013), VR46 (09-21-2013)
Old 09-20-2013, 10:23 PM   #1900
fenton
As always, good work Pug. I'm really impressed with what your doing here and look forward to seeing more and hopefully one day getting my hands on this
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
Old 09-21-2013, 12:08 AM   #1901
Gary in NJ
Gary in NJ's Avatar
Old 09-22-2013, 05:40 PM   #1902
Pug
Atoning Unifex
Pug's Avatar
And here's the system installed and working! I'll have to watch it closely for the next week to make sure everything's OK.
[ame="http://www.youtube.com/watch?v=hcG-ldU4S9Y"]Installed Test 1: Phantom Full-Throttle Supercharger Advanced Monitor - YouTube[/ame]
Here's a picture after the first drive test showing more normal 60C temperatures. Note that it wasn't a long drive, so I expect much higher than that in real operation.
The Following 3 Users Say Thank You to Pug For This Useful Post:
DAEMANO (09-22-2013), mike_ekim1024 (09-22-2013), neutron256 (09-23-2013)
Old 09-22-2013, 06:00 PM   #1903
wbradley
Sarcastic SOB
wbradley's Avatar
Very nice. What are you using for a controller? These days Arduino, Beagle Board or Raspberry Pi make sense if you can get them configured for the task. Gotta get some programming done, a whole other learning set.
I was looking into controller boards for custom pinball machines but electronics is completely self taught for me and the task of creating the programming was daunting. Incidently most of my pinball machines were used to raise funds for the FRS.
Old 09-23-2013, 02:42 AM   #1904
Pug
Atoning Unifex
Pug's Avatar
Circuit design and source code are released under the Apache 2.0 license here: https://github.com/jcjones/phantom-s...vanced-monitor
It's built on top of an Arduino Uno and the Adafruit Logging Shield, though I am going to look closely at laying it out in Eagle from straight components.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
