Old 09-18-2013, 06:02 PM   #15
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Originally Posted by lychee View Post
Is your a/c on during cold start up? If so, turn it off.
AC is not on and I prime the pump for 5 seconds before turning it over, etc. This isn't the usual idle stumble everyone complains about. I had that previously. This is MUCH more drastic. LTFT's on stock map are now +40% across the board.
Nightbringer is offline   Reply With Quote
Old 09-18-2013, 06:32 PM   #16
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
What does the short term trims look like?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-18-2013, 07:19 PM   #17
Nightbringer
Drives: Scion FR-S
They max out when the LTFT's reset of course, otherwise if the LTFT's are staying at 40%, the STFT's range from -5 to +5, so normal. Trying to see if I've got injector duty cycle in these logs...
Old 09-18-2013, 10:42 PM   #18
feldy
feldy's Avatar
I have been seeing -14 to +14 sometimes other times -10 to +10 I need to get that looked at. Short trims my long trims are disabled currently.
Old 09-18-2013, 11:19 PM   #19
Nightbringer
Drives: Scion FR-S
Honestly that doesn't sound all that bad to me. I'm a novice, so mad_sb or one of the other pros would have to give further thought, but if that's the total variance... if you had LTFT's enabled that'd be like a +10 constant LTFT, and +/- 4 for STFT. Not perfect but that seems pretty decent compared to some of the crap I've seen. LTFT's turned off to narrow in maf scaling or something?
Old 09-18-2013, 11:24 PM   #20
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
boosted FRS here on e85
Short trims are -3 to 3
and
Long are 13.3
Old 09-19-2013, 12:27 AM   #21
feldy
feldy's Avatar
No tony has them off to keep the ltfts from stacking up and from giving the stock ecu issues when going wot and adding extra fuel. I autocross all year long and this year I was switching from 93 to e85 every few weeks.
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
FR-S cold start stumble - video whtchocla7e Issues | Warranty | Recalls / TSB 11 04-17-2013 08:02 AM
Misfire Jono AFRICA 49 12-12-2012 07:01 AM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 09:53 AM
Idle Fluctuation FIX empower-auto Issues | Warranty | Recalls / TSB 2 09-14-2012 03:36 PM
