Old 09-16-2013, 06:32 PM   #1
Hayame
Drives: Fr-s
Morimoto retro kit worth it??
Hey guys, im shopping for HID conversion kit... Just not so sure if i should go with a standard type HID conversion or go with the Morimoto retro fit. Trying to find side by side comparison pics if anyone that has the Morimoto's and have tried the stantard HID what is the major differences between two in terms of performance?
Thanks guys!
Hayame is offline   Reply With Quote
Old 09-16-2013, 06:39 PM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Bulbs and ballast are not in the same category IMO.. BUT, my old DDM tuning kits look just as good as my new morimoto kits.. Difference is now that the ballast from DDM tuning went out in my moms car, we are having the hardest time getting it warranty.. Call TRS and it's handled.. Also morimoto is just a better name and better quality
HIDplanet.com have comparisons side by side of morimoto and others even OEM to see how they stack up as far as ballast and bulbs
Gixxersixxerman is offline   Reply With Quote
Old 09-16-2013, 06:53 PM   #3
retrosmiths
Drives: Scion FR-S Whiteout
http://www.hidretrofits.com would be a good source for this topic
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
The Following User Says Thank You to retrosmiths For This Useful Post:
Gixxersixxerman (09-17-2013)
Old 09-16-2013, 07:08 PM   #4
Hayame
Drives: Fr-s
Thank you much guys ill check the sites.
Old 09-17-2013, 11:46 PM   #5
msile
msile's Avatar
Drives: ISF
I have the Morimoto retro kit and it is brighter and clearer than OEM with HID (which I had before)
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 09-18-2013, 01:13 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Yes, the kit is amazing
Old 09-18-2013, 01:18 PM   #7
STV3
Señor Member
STV3's Avatar
Dumb question.... do you have to re-aim/level you head lights after installing the morimoto retro fit kit?
STV3 is offline   Reply With Quote
Old 09-18-2013, 01:22 PM   #8
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Yes they are worth it! Just a overall better projector and light output then stock plus high and low beam both in the projector. You will have to adjust your headlights using the stock adjustment screws.
Sent from my SCH-I545 using Tapatalk 2
Lee358 is offline   Reply With Quote
Old 09-18-2013, 03:10 PM   #9
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
Thanks guys!
I purchased my kit from theretrofitsource.com. The kit is very well constructed and the lighting output is very bright! well worth the money. The reason these kits are more money than your average kit is due to the harness kit they give you with the relays. The bulbs and ballasts that are used are more quality than most of these eBay and cheap chinese kits. Your paying for quality something that is going to last. The people over at the retrofit source are one of a kind with the customer service that you get. I also purchased the Black series clear lenses as upgrades. The light output is amazing.
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
Old 09-18-2013, 03:12 PM   #10
Simply_the_best
Tom's Racing ADDICT
depends on how you do the install. I removed my headlamps from the car for that OEM hidden look.
Old 09-18-2013, 03:47 PM   #11
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
My daughter has the MoriMoto retrofit kit and it is significantly brighter and much clearer with a safe for on coming traffic cutoff than the OEM with an HID plug in kit which was my first effort. The amount of fragging/abuse I received with my OEM hid posts was predictable for such a group of enthusiasts on this forum. Do it once and do it right.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-20-2013, 03:23 PM   #12
Hayame
Drives: Fr-s
Wow so many great reviews. ok morimoto retro kit for me then, once again thank very much for ur feed back!!!
Old 09-20-2013, 04:36 PM   #13
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
biggest difference is having the high beam come from your projector. I'm very happy with my morimoto retroquick kit.
FastLane1000 is offline   Reply With Quote
Old 09-20-2013, 05:07 PM   #14
tonystewart
This allowed me to replace the stock high beam bulb with led drl in superwhite, no more yellow light during the day.
DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S civicdrivr DIY (Do-It-Yourself) Guides 236 07-10-2017 01:04 AM
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 08:37 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 03:03 AM
DRL and Morimoto Retro-Quik Xenon Retrofit System denverizzles Cosmetic Modification (Interior/Exterior/Lighting) 1 09-07-2012 11:46 AM
Any chance of a group-buy on TRFS Morimoto Retro-Quik? SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 2 07-20-2012 02:06 PM
