Old 09-17-2013, 03:07 PM   #15
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
This thread is nonsense. Mixing together blow off valves and wastegates.
An internal wastegate will never perform the function of a blow off valve.
The wastegate regulates boosts by preventing the turbo from building anymore boost.
It does this by venting the excess to the exhaust. (or atmosphere if you have a dump pipe)
The BOV eliminates compressor surge.
(Compressor surge - the event where the pressurized air in your intercooler piping stops when the throttle body closes and bounces back towards the compressor blades of the turbo.)
The blow off valve will protect the turbo.
Venting to atmosphere is only better if we are talking about wastegates.
Recirculating is always better if you are running a MAF setup unless it is blow thru, in that case.. it doesnt really matter.
BOVs can be on either the hot or cold side but performs best on the hotside.
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 09-17-2013, 05:00 PM   #16
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
no bov ftw
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Prava (09-23-2013)
Old 09-17-2013, 05:03 PM   #17
jamesm
every car with a turbo needs a bov. the only exception being very, very low boost systems (< 5psi) and even then, the only reason not to install one would be to save money. that chopping sound you're hearing isn't cool... it means your compressor is being stalled by the pressure in the charge pipe. that's bad, in any case.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
glorydays (05-05-2014), Sportsguy83 (09-17-2013)
Old 09-18-2013, 09:11 AM   #18
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Some racers choose not to run blow off valves to increase the response time between shifts. A few of the crazier time attack cars have no blow off valve.
No Limit Motorsport is offline   Reply With Quote
Old 09-18-2013, 09:28 AM   #19
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Run it oe first
448hpsti is offline   Reply With Quote
Old 09-18-2013, 12:55 PM   #20
jamesm
You understand that the main benefit of not stalling the compressor, aside from not damaging it, is that it helps spool between shifts right? It makes no sense at all that not having a bov would help spool, or anything else other than your wallet.
Old 09-18-2013, 01:56 PM   #21
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I just got off the phone with FullBlown and with my Greddy Turbo kit pushing 14psi--which is max for the OE waste gate--on E85 they were able to get near 300whp. LJ is going to weld the flange on for me since I decided to have one [BOV] put on. I'm not looking to race or anything otherwise I would have went with FullBlown's turbo kit and setup. I just can't wait to pick her up Friday!
BTW, FullBlown did a great job on doing all the installs and tuning. I'll be sure to write up a good trader report. Thanks.
shiro is offline   Reply With Quote
The Following User Says Thank You to shiro For This Useful Post:
ImperiousRex (09-26-2013)
Old 09-18-2013, 02:36 PM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Make sure you get the Dynojet data files from him so you can post some nice graphs. I would like to see a boost plot for the kit as well as I think this is the smallest turbo kit on the market currently.
Old 09-18-2013, 02:42 PM   #23
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I got it all on a usb flash drive for him car ended at 300hp.
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
shiro (09-18-2013)
Old 09-18-2013, 02:50 PM   #24
shiro
shiro's Avatar
I will be sure to upload them for everyone to see. That way everyone can see what the current Greddy kit is able to do. Though I will need to find a place I can post the project pictures of the installation and the graphs. I took a lot of pictures during the turbo installation!
Thank you! Completely excited on all the work you guys did. Thanks again!
FullBlown (09-18-2013)
Old 09-18-2013, 03:05 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You da man LJ.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
FullBlown (09-18-2013), whitefrs (09-19-2013)
Old 09-18-2013, 03:48 PM   #26
mad_sb
Drives: 2013 Asphalt FR-S
Hey Guys,
Just got my Greddy Turbo Kit installed last week and I am having FullBlown tune her this week. However, since the Greddy Turbo Kit has an internal waste gate that dumps to the exhaust I am contemplating on puting an external BOV in. I have the flange and a Greddy FV BOV that I can install. I've contacted Greddy about installing it and should be no problem on the hot side of the turbo.
Basically, my question is should I just keep the stock Greddy setup with the fludder noise or should I add the sick sounding BOV? Actually, they both sound pretty cool. And will adding an external BOV degrade the turbo's performance design?
Thanks all!
I think you are mixing your terms. Sounds to me like you want to know if you should install an External Wastegate, NOT blow off valve. Blow off valves go on the charge pipe, not the hotside of the turbo.
The Following User Says Thank You to mad_sb For This Useful Post:
infinite012 (09-18-2013)
Old 09-18-2013, 04:08 PM   #27
infinite012
Drives: 13 DGM BRZ Ltd
This thread seriously is hurting my head.
Wastegate =! BOV/BPV
Internal, external, whatever. They're not performing the same function.
infinite012 is offline   Reply With Quote
Old 09-18-2013, 04:22 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
He didn't really mix any terms other than saying hotside of the turbo instead of hotside of the intercooler. The only confusing thing is he said external BOV when we generally consider all BOVs to be external although those new fangled BW turbos have them internal BOVs. At no point did he want to change his wastegate I think he just wanted to point out that his is quiet since it has an internal wastegate so he wants some turbo BOV noise.
ftc~brz (09-18-2013), shiro (09-19-2013)
bov, fabrication, greddy turbo kit
Greddy turbo MikesFRS Forced Induction 104 11-24-2014 11:47 PM
Greddy Turbo! Threads Forced Induction 16 08-29-2013 05:11 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
Greddy turbo brocktwalker Forced Induction 3 04-03-2013 09:03 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
