#603 |
Drives: 02 Sequoia 2013 Scion FR-S
#604 | |
Nobody beats the B[I|R]Z
Drives: shopping cart i stole from walmart
Americans especially seem to like to use the term "sports car" for anything high performance/high HP. |
#605 |
Thanks
So what should it be referred to? Track killer? Import and exotic slayer?
#606 | |
Drives: 2013 Ultramarine FRS
Why do you think AMG/Audi/Koenigsegg, among others, are moving away from superchargers and towards turbos. I doubt it'll happen with this generation of the Vette, but it wouldn't entirely surprise me if the ZR1(or whatever the new top vette is called) came out with with non belt driven blowers. A guy can dream anyways.
#607 | |
Drives: '06 AM V8V Coupe
Tunes? The adjustment is not as great as you make it sound. All you get to change is allowed boost pressure, which you can do on a supercharger with your foot. There's no reason an electronically controlled bypass can't emulate the behavior of different turbo tunes. The greatest strength that turbos have is probably modularity; You can strap one onto an engine without special considerations for the manifold since it's smaller and you can just stick it somewhere where there's some space in the engine bay, self contained power source(no belt drive), and it's easy to control the torque since it's a self-regulating system of sorts, no need to think about the interplay between bypass and the main engine throttle. And they're a little more efficient at certain points in the powerband as well as partial boost. Last edited by serialk11r; 09-18-2013 at 04:33 AM. |
#608 | |
Drives: '23 BRZ
It takes power to compress the intake charge either way. Power comes from a crank-driven pulley in the supercharger case and from exhaust pressure in the turbo. When a turbo is making boost, it is adding tremendous backpressure in the exhaust, the power from the turbine side driving the compressor side it is not free. It is usually a bit more efficient as off-boost the losses associated with it are less than with most supercharger setups.
#609 |
Drives: '23 BRZ
Rumor has it that the top C7 will be a smaller displacement turbocharged Z07, btw...
#610 |
Drives: Attitude
#611 | |
Drives: Car
| The Following User Says Thank You to LSxJunkie For This Useful Post: | Prog (09-22-2013) |
#612 |
Drives: Attitude
That's exactly what a sports car is...engine placement can of course change, though. The 911, GTR, etc. are GT cars. The Corvette is a sports car and it always has been.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Marchy (09-18-2013) |
#613 |
Drives: 2013 raven black fr-s
saw a blue one today on my way to work. I'm still not the biggest fan of the back end, but the rest looks like sex.
#614 | |
Boost control through the rpm range? I feel like this is a weird advantage to be stating; you have to change housings and turbines/compressors to get a different response characteristic. |
#615 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
| The Following 2 Users Say Thank You to chrisl For This Useful Post: | LSxJunkie (09-18-2013), OrbitalEllipses (09-18-2013) |
#616 |
Drives: '23 BRZ
There are about as many definitions for "sports car" as there are for "God", so obviously people will disagree.
To me, outright speed has little to do with it. IMO a Triumph Spitfire (slow in every direction) is 1,000,000 times more of a "sports car" than a GT-R. "Sports Car" to me implies a small, minimalist, lightweight car with pure driving enjoyment being a larger priority than huge power and maximum speed around a track. The Corvette is, to me, more of a supercar. There are those who consider a 4100 lb. Dodge Challenger to be a "sports car". But whatevs... |
| 2014 Chevrolet Camaro Z/28: The Trans-Am Racer Returns! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 53 | 02-24-2016 10:55 AM |
| OEM Chevrolet Corvette 17x9.5 +56 | BII302 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 06-07-2014 01:52 AM |
| Marc08EX Detailed: 2007 Chevrolet Corvette Z06 - Black | Marc08EX | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 07-11-2012 10:57 PM |
| 2011 Chevrolet Corvette Z06 Carbon slots in right below ZR1 | vh_supra26 | Other Vehicles & General Automotive Discussions | 2 | 03-14-2010 09:09 PM |
