go_a_way1
Old 09-17-2013, 05:05 PM   #1863
fenton
Originally Posted by tennisfreak View Post
Im interested but skeptical.
This goes against myth busters and countless other videos that have proven its impossible for an electric motor (in a cars engine bay, running on batteries) to produce boost.
With over 100k views and 1800 replies on this thread you got a lot of reading to do
Start with post number one. Dyno Numbers do not lie, it is possible.
This isn't you typical eBay crap, it pulls over 3000 watts and about 200amps peak
Its treated like nos where you only use it at wot
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
DAEMANO (09-17-2013)
Old 09-17-2013, 05:08 PM   #1864
fenton
Originally Posted by bfrank1972 View Post
Yah I took a look at your last dyno posted in the thread, you are getting a bigger jump during the dip - your 7000 rpm looks to be a just a bit over 25, maybe 30 lb-ft. You and ThatTruth are at roughly the same altitude?
A side thought - would this system partially compensate for altitude? The thing is trying its hardest to force as much air as it can into the engine - if the air is thinner my intuition says it would at least partially make up for the deficit from altitude - in other words I'm wondering if you guys at altitude will see bigger gains than us at sea level? If that's the case, would the dyno's altitude compensation be optomistic? I'll be interested to see some low altitude dynos soon!
The only thing that helps us at altitude is the electric motor doesn't have to work is hard. You will always make more boost at sea level given a static compressor rpm.
At sea level the HP you make is what you put to the ground. At altitude the HP you make on the dyno is corrected. When I left the dyno in uncorrected mode I made 150hp stock and 180 boosted
Old 09-17-2013, 05:25 PM   #1865
raven1231
Originally Posted by Robftss View Post
Attachment 51579
Thatruth dyno.
Boost from 1800 rpm.
180 ft-lbs @ 2800 rpm
Similar gains to other dyno runs, best @ 4200 rpm
Wonky boost plot.
Nice AFR's Bob!!
looking good!
Old 09-17-2013, 06:02 PM   #1866
Thatruth2001
Drives: Raven FR-S
Attachment 51579
Thatruth dyno.
Wonky boost plot.
Nice AFR's Bob!!
Keep in mind the intake temps started to run hot during the session prior to the last run. Prior to the break 10+ runs were completed. With that said, the chart posted I believe reflects the last after about a 1 hour break with no prior runs to warm the batteries up. Additionally, the outdoor temp during the session was between 85-90 F.
Additionally after the session I installed the aux battery charger and noticed I had some light corrosion around the ESC batteries. I do not think it really mattered, but just a note.
Personally, I think the car is even faster since the tune has adapted to my driving. Additionally since things have cooled down into the mid-70's in the NW, the unit is really kicking some ass! Which leads me to believe the optimal intake temp to get the most of the unit is roughly between 65 and 80 degrees. I have notice using the torque app the intake temps when moving tend to run approximately 10 to 15 degrees warmer. Once the unit is engage the air measured in via the intake and external thermometers are almost identical. Some here is the million dollar question:
What is the most effective way to control and maintain a constant 65-75 F intake temp?
Thatruth2001 is offline   Reply With Quote
Old 09-17-2013, 06:08 PM   #1867
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Million dollar question indeed lol
Sent from my SGH-I337M using Tapatalk 4
Bu-Tang is offline   Reply With Quote
Old 09-17-2013, 06:24 PM   #1868
Calum
That Guy
Drives: 2013 asphalt FRS MT
There's a difference between a fan and a compressor. A fan isn't capable of creating a pressure ratio.
The Following User Says Thank You to Calum For This Useful Post:
Old 09-17-2013, 06:46 PM   #1869
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
Have an ESC thermister feedback loop control a 12v servo mixing damper (butterfly valve) with separate intakes (y pipe) one drawing cold bumper air and one drawing warm air near exhaust manifold.
PowderfaceTr. is offline   Reply With Quote
Old 09-17-2013, 07:50 PM   #1870
fenton
Attachment 51579
Thatruth dyno.
Wonky boost plot.
Nice AFR's Bob!!
Nice! Over 175ft/lb torque from 2500 to almost 6000rpm.
That thing must feel like a blast now.
Old 09-17-2013, 08:09 PM   #1871
rusty959
Drives: DGM BRZ limited
I see no reason to assume the intake temp needs to be atleast 65 degrees. Just make it as cool as you can and profit.
rusty959 is offline   Reply With Quote
Old 09-17-2013, 08:14 PM   #1872
mid_life_crisis
Drives: FR-S 10 #103 AT
Or just spend the money on a hyper efficient water/air intercooler.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-17-2013, 08:34 PM   #1873
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
At 11 PM last weekend, Torque measured an intake temperature of a cool 114 F. Lowest I've run so far.
Pug is offline   Reply With Quote
Old 09-17-2013, 08:49 PM   #1874
fenton
Jeeze where do you live??? The sun?
Old 09-17-2013, 08:51 PM   #1875
radroach
Drives: car
The Following User Says Thank You to radroach For This Useful Post:
Calum (09-17-2013)
Old 09-17-2013, 08:53 PM   #1876
fenton
Soon I will be testing -20c or -4f !
I give it 2 months
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
