#393 | |
Also, make sure the springs are the right size, not just the length you want. |
#394 | |
Drives: Raven FR-S
#395 |
i'm sorry, what?
Drives: Canada
define "better"
what is it that you don't like about your current setup?
#396 |
Drives: Raven FR-S
#397 | |
i'm sorry, what?
Drives: Canada
remember that the best tuned suspensions are generally comfortable. When you say "stiff" i think "harsh" what is the car doing that you don't like? What would you like it to do? furthermor, unless you are running aero and slicks, there is a limit to how high you want your spring rate to be. it is very important that you understand cause and effect... that what you may want is not achieved in the way you think it is achieved.
| The Following User Says Thank You to 7thgear For This Useful Post: | YDNA (09-17-2013) |
#398 |
#399 |
#400 |
Drives: Raven FR-S
#401 |
Drives: Whiteout 6MT FR-S
I've been thinking about replacing the bushings in the rear subframe and diff mounts, but I'm reluctant to charge ahead without knowing the reason for doing so, even though it's a relatively cheap upgrade. whenever I see underbody videos of the movement in these locations, it seems to me that they exist to eliminate smaller vibrations which cause NVH.
my question is, is making these locations more stiff by replacing with poly equivalent to slightly increasing the damping in the coilovers, or do you think the dampers were designed to work with the bushings to start with? that is, if you put in poly, are you feeling the damping as it was meant to be, or not going to get enough damping? thanks for the great thread, let me know if i'm in over my head. |
#402 |
i'm sorry, what?
Drives: Canada
if you're not doing autocross "stock class", then I would highly recommend rear subframe bushings... on ANY car, you will feel the improvement and the NVH is not important, you will be very happy that you've put these in.
| The Following User Says Thank You to 7thgear For This Useful Post: | iketeru (09-17-2013) |
#403 |
thanks 7th. any long term wear concerns with poly?
#404 |
i'm sorry, what?
Drives: Canada
not in applications where no twisting forces are involved. The subframe bushings will last you the life of the car, the diff inserts might wear out eventually but I don't see it being a problem for at least 10 years.
#405 | |
That Guy
Drives: 2013 asphalt FRS MT
Like 7thgear, I'll also recommend these. |
#406 |
i'm sorry, what?
Drives: Canada
this isn't directly related to anything in particular but i figured this would be the best place to post this
[ame="http://www.youtube.com/watch?v=NeXIV-wMVUk"]Wheel momentum Walter Lewin.wmv - YouTube[/ame]
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
