Old 09-17-2013, 11:20 AM   #393
CSG Mike
CSG Mike's Avatar
Originally Posted by YDNA View Post
my friend has some leftover swift springs in 6" 10k/12k and said i could have them for free. if i were to swap them out onto my kwv3s, would i have to revalve them? i was thinking of going to a stiffer rate but i think that might be way too high.
You'll be way underdamped. Yes, you'll need to revalve to properly damp 10k/12k springs.
Also, make sure the springs are the right size, not just the length you want.
Old 09-17-2013, 11:48 AM   #394
YDNA
YDNA's Avatar
Drives: Raven FR-S
10k/12k would be pushing it big time for KW V3.
- Andy
would 60mm id or 65mm id be what i want? would running 7/8k or 8/9k be a better option?
YDNA is offline   Reply With Quote
Old 09-17-2013, 12:02 PM   #395
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
define "better"
what is it that you don't like about your current setup?
Old 09-17-2013, 12:06 PM   #396
YDNA
YDNA's Avatar
Drives: Raven FR-S
Originally Posted by 7thgear View Post
define "better"
in my honest opinion, it's not stiff enough to my liking. i've been playing with the adjustments on the setup and would like to go a bit stiffer
Old 09-17-2013, 12:11 PM   #397
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
define "stiff."
remember that the best tuned suspensions are generally comfortable. When you say "stiff" i think "harsh"
what is the car doing that you don't like? What would you like it to do?
furthermor, unless you are running aero and slicks, there is a limit to how high you want your spring rate to be.
it is very important that you understand cause and effect... that what you may want is not achieved in the way you think it is achieved.
Old 09-17-2013, 01:38 PM   #398
Originally Posted by Wepeel View Post
Real quick RCE - does the BRZ have the same rear tophats as the GR STI/WRX?
Crap...I'm 90% sure they are but can't exactly remember.
- andy
Racecomp Engineering is online now   Reply With Quote
Old 09-17-2013, 01:38 PM   #399
60mm
What kind and what size tires do you run?
- Andy
Old 09-17-2013, 04:42 PM   #400
YDNA
YDNA's Avatar
Drives: Raven FR-S
60mm
- Andy
im on some cheap tires that my wheels came with right now but im gonna probably change to a 245/40/18 in rs3s or something along the lines of that
Old 09-17-2013, 07:37 PM   #401
iketeru
Drives: Whiteout 6MT FR-S
I've been thinking about replacing the bushings in the rear subframe and diff mounts, but I'm reluctant to charge ahead without knowing the reason for doing so, even though it's a relatively cheap upgrade. whenever I see underbody videos of the movement in these locations, it seems to me that they exist to eliminate smaller vibrations which cause NVH.
my question is, is making these locations more stiff by replacing with poly equivalent to slightly increasing the damping in the coilovers, or do you think the dampers were designed to work with the bushings to start with? that is, if you put in poly, are you feeling the damping as it was meant to be, or not going to get enough damping?
thanks for the great thread, let me know if i'm in over my head.
iketeru is offline   Reply With Quote
Old 09-17-2013, 07:45 PM   #402
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you're not doing autocross "stock class", then I would highly recommend rear subframe bushings... on ANY car, you will feel the improvement and the NVH is not important, you will be very happy that you've put these in.
Old 09-17-2013, 07:47 PM   #403
iketeru
thanks 7th. any long term wear concerns with poly?
Old 09-17-2013, 07:52 PM   #404
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
not in applications where no twisting forces are involved. The subframe bushings will last you the life of the car, the diff inserts might wear out eventually but I don't see it being a problem for at least 10 years.
Old 09-17-2013, 09:28 PM   #405
Calum
That Guy
Drives: 2013 asphalt FRS MT
This is completely different then increasing damping of the shocks. These inserts will give more feedback about what's going on back there.
Like 7thgear, I'll also recommend these.
Old 09-18-2013, 02:22 PM   #406
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
this isn't directly related to anything in particular but i figured this would be the best place to post this
[ame="http://www.youtube.com/watch?v=NeXIV-wMVUk"]Wheel momentum Walter Lewin.wmv - YouTube[/ame]
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
