Old 09-17-2013, 03:29 PM   #71
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Originally Posted by Dezoris View Post
No relays either?
Sorry, I should have been more clear. They will still need to have the included relay plugged in
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-17-2013, 03:40 PM   #72
Dezoris
Dezoris's Avatar
Thanks,
Rick
How much horsepower do I gain? They look pretty good.
Old 09-17-2013, 04:15 PM   #73
RallySport Direct
I would say at least 18.7 HP. I'm sure it would be more but they don't include any stickers...
Thanks,
Rick
Old 09-20-2013, 02:57 PM   #74
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thanks for the DIY
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
RallySport Direct (09-20-2013)
Old 09-20-2013, 03:32 PM   #75
RallySport Direct
Originally Posted by tonystewart View Post
Thanks for the DIY
You bet, glad to help!
Thanks,
Rick
Old 09-24-2013, 03:21 AM   #76
KONVERTER
KONVERTER's Avatar
Just put these on my brz. The new relay makes the turn signals slllloooooowwwwwww
Sent from my Nexus 4 using Tapatalk 4
KONVERTER is offline   Reply With Quote
Old 09-24-2013, 11:02 AM   #77
RallySport Direct
Really? I have heard of people saying this before. Do they blink slower, or are they just slower to respond to the first tap on the stalk? I've tried to replicate this on our shop BRZ and my personal one as well, and I did not notice anything different compared to stock. Maybe I am just not sensitive to this like others are, but I did not notice any delays or slow blinks with the Tom's relay.
Thanks,
Rick
Old 09-24-2013, 11:54 AM   #78
KONVERTER
KONVERTER's Avatar
The first blink is definitely delayed. It hangs there. Then the blinking seems slower than stock. Will see if I can get a comparison on Wednesday at the local gtg
Old 09-24-2013, 05:37 PM   #79
RallySport Direct
I will check this out on my car again as well. Too bad all of the BRZ's(3) we have here have the Tom's lights installed on them.
Thanks!
Rick
Old 09-24-2013, 06:30 PM   #80
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
how fast do the tom's lights blink before swapping out the stock relay? is it a bit faster or a lot faster? anyone got a vid?
shiumai is offline   Reply With Quote
Old 10-02-2013, 02:56 AM   #81
DIF
DIF's Avatar
Drives: FR-S in Firestorm, Katzkin, alpine
Originally Posted by Skurj View Post
Got them installed today. Changing the pins was easy for 3 of the wires... the last left a little damage to the plug, so I will have to just keep an eye to ensure the pin doesn't creep out.
Wow it's just amazing how installing different taillights made your license plate so much brighter!
DIF is offline   Reply With Quote
Old 10-02-2013, 03:05 AM   #82
DIF
DIF's Avatar
HAHA yeah my first time doing it, I got pretty cut up. When I installed them on my own car, I knew what I was getting into and managed to only have one small but on my hand. But we all know cars need a blood sacrifice, so if you are not getting cut, you are installing it incorrectly
Thanks,
Rick
Seriously though, There must be a tool the dealer mechanics have for this. I can't imagine them going through this every time they have to replace a flasher which burnout occasionally over the lifetime of a vehicle.
Old 10-02-2013, 03:35 AM   #83
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Solution, lay down, look under the dash, reach up, pull down. I did not get cut up and it popped right out.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 12-07-2013, 02:29 AM   #84
etherealfall
Drives: Toyota 86 GTS Storm Black
`1
etherealfall is offline   Reply With Quote
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 02:02 PM
FS: FRS/BRZ Red OEM taillights 86design Exterior Parts (Aero, Lighting, Etc.) 4 06-26-2013 06:34 PM
New taillights youngy AUSTRALIA 7 04-14-2013 06:16 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
