Old 06-27-2013, 03:55 PM   #1
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
DIY Tom's Taillights Install
First Step, make sure you have the LED relay and the 2 rear tails and that everything is in good condition. Yes? Then proceed
I installed the LED flasher first, but you could do this at anytime.
Open the driver side door, pop off the side access panel, it pops off easily from the bottom.
We need to take off the lower dash panel, so we will need to remove the 2 screws holding it to the dash.
Now you can take off the lower dash panel, which should pop right out with light force
I did not remove any of the electrical connectors as changing out the relay/flasher is a quick job.
The relay is located just to the left of the steering column, but is a bit tricky to access due to the location.
I did not take a picture of this, but I had to insert a very small flat head screwdriver to release the relay from the white plastic clip holding it to the dash beam. Once the relay is free from the clip, you have a bit more room to change it out.
The new LED relay is a direct plug and play and will even attach to the dash beam just like stock.
Plug the new relay in, attach it back to the white clip, and reinstall the lower dash panel and access panel.
Moving on to the Tail Lights, we will need to first remove the trunk floor liner, and the center plastic section which is held on by 3 black plastic clips.
Pop all 3 clips out and remove the center plastic section.
Now we can remove the driver side trunk panel. There should be 5 clips total and the trunk popper switch.
The passenger side panel should also have 5 clips total to remove
With the trunk liners removed we now have access to the tail light harness and nuts.
I popped the white harness holders off the stud with my flat head, there will be 1 on the passenger side and 2 on the driver side. You could also use a pick to lift up the clip holding the zip-tie
Unplug the main harness from the tail lights
Now use your 8mm socket to remove the 4 nuts on each taillight
With all 4 nuts removed and the harness unplugged, carefully remove the tail lights.
Carefully put the new tail light back in, making sure everything is aligned correctly.
Install all 4 nuts on the new tail light and plug in the harness. Check to make sure the lights are functioning properly.
*PLEASE NOTE* We had to re-pin our factory harness connection due to the difference in JDM Vs. USDM cars, so here is a brief description of how to re-pin the harness in if your car requires it.
On the harness plug itself, there will be a plastic tab on the top, use a small flat head or dental pick to lift it up and away from the plug.
Always take a picture of the wires for reference
I was not able to take a non-blurry picture of the pins and the small plastic clips inside the plug that hold the pins in, but using your dental pick you will want to essentially push the metal pin down, slide the pick towards the back of the plug, and this should also lift the plastic clip up, freeing the pin to be slid out from the back.
The end result, here is the proper wire configuration for the driver side taillight.
And the passenger side tail light's correct wiring
Once you confirm the tail lights are working to your liking, go ahead and secure the pins back into the plugs, and snap down the small plastic tab we removed earlier. Button everything back up and go enjoy your new tail lights!!!
For more info on the Tom's Tail Lights, please click here
Before:
After:
New Video we made
[ame="http://www.youtube.com/watch?v=nYjuGWeb4XE"]http://www.youtube.com/watch?v=nYjuGWeb4XE[/ame]
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following 12 Users Say Thank You to RallySport Direct For This Useful Post:
burnt toast (06-30-2013), Chee-Hu (07-01-2013), crizkay (06-27-2013), DragonDriver5 (03-24-2014), Drebin252 (03-13-2014), hernanBRZ (07-05-2013), MikeM5 (07-03-2013), Overland'n'5thGEN (06-27-2013), p00mba (06-27-2013), Retro86 (07-09-2013), Shinryu (06-29-2013), Yamaha_R6 (03-28-2014)
Old 06-27-2013, 04:07 PM   #2
CBR600RR
Drives: Raven Black
NICE!!! that's easy enough!
Can you show us some pics of the running lights, brake lights, turn signals???
Old 06-27-2013, 06:02 PM   #3
RallySport Direct
I will get some up here shortly
Originally Posted by ATL BRZ View Post
I thought these were plug & play for USDM cars?
You can just plug them in and run them, but then when your driving lights are on, it will light up the amber turn signal light, so we wanted to make sure it was working 100% like we wanted them to, so we had to re-pin the harness. The JDM models seem to use a slightly different wiring compared to the USDM models. Let me know if you have any questions on that
Thanks,
Rick
Old 06-27-2013, 06:22 PM   #4
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Sweet write up!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
The Following User Says Thank You to Norkoastal For This Useful Post:
RallySport Direct (06-27-2013)
Old 06-27-2013, 07:35 PM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Question, the relay, this controls the front and rear flashers, or are they seperate front and back?? I already changed ONE to a CF18 I believe for my front LED switchbacks so wondering if I am good to go if I go this route?
Old 06-27-2013, 08:29 PM   #6
RallySport Direct
Originally Posted by Norkoastal View Post
Sweet write up!
Thank you!
That is a great question and to be honest I am not 100% certain on that, but I do think the single flasher will control both front and rear blinkers/hazards. I would assume you would be fine.
Hope this helps
Thanks,
Rick
Old 06-27-2013, 11:14 PM   #7
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
If I didn't already have and love my crystal eyes red, I would have been all over these. Very detailed install! But when I installed my hyper flash, I was able to just crawl into the footwell of the driver seat an reach up to swap the relays lol.
FRSfan111 is offline   Reply With Quote
Old 06-27-2013, 11:15 PM   #8
OICU812
Just a dude
OICU812's Avatar
Thanks Rick great job on the write up. I'm really suprised re doing the pins however, given time for them to come to NA market figured these would be 100% plug and play.
Old 06-28-2013, 11:26 AM   #9
RallySport Direct
Good to know! And even with the lower dash panel off, I still cut up my hands on the sharp metal haha.
Thanks! And I am assuming that they never really intended for these to come to the North American market, so for now we will just have to deal with the difference between the JDM and USDM models.
Thanks again!
Rick
Old 06-28-2013, 02:12 PM   #10
swift996
swift996's Avatar
Wow those look great. I'm neck deep in performance mods right now but want to pick these up down the road.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-28-2013, 08:45 PM   #11
RallySport Direct
Thanks!!! And I know the feeling haha.
We also just posted up a video we made
Thanks,
Rick
Old 06-28-2013, 11:59 PM   #12
E46toFT86
Drives: IB '05 E46 M3 ZCP
Damn. You've convinced me to purchase these taillights vs. the Crystal Eyes. That White BRZ looks amazing!
E46toFT86 is offline   Reply With Quote
Old 07-01-2013, 11:35 AM   #13
RallySport Direct
HAHA nice, glad we could help! Let me know if you have any questions.
Thanks,
Rick
Old 07-02-2013, 01:18 PM   #14
loogs
Drives: on cruise control
looked easy enough up until the pin thing. now i need to find someone to do the install cause i just dont get it
loogs is offline   Reply With Quote
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 03:02 PM
FS: FRS/BRZ Red OEM taillights 86design Exterior Parts (Aero, Lighting, Etc.) 4 06-26-2013 07:34 PM
New taillights youngy AUSTRALIA 7 04-14-2013 07:16 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 01:40 AM
