Old 09-16-2013, 08:32 PM   #1849
FT_Monk
Drives: Over the hill WRX
Originally Posted by Thatruth2001 View Post
We all want the bells and whistles, but the cost of the feature might become a turn off. Personally, I thnk Toyota should write Rob a fat ass check and incorporate the unit into an hybrid version of the car.
Here is a unit from a OEM supplier:
http://www.valeo.com/en/page-transve...ercharger.html
FT_Monk is offline   Reply With Quote
Old 09-16-2013, 08:47 PM   #1850
raven1231
Here is the funny thing ......Chinesse manufactures are looking at this thread and are attempting to develop a unit... Some have gone as far as contacting some people about testing and tuning.
Knowing how long it took Rob to R&D this unit I have a feeling there will be many knock offs around the corner.
Concerning modulation of the unit's output, I can send you about 20 emails debating it with Rob. At the end of the day is it achievable, yes but it becomes more complicated which leads to driving up costs.
I was thinking the same thing about Toyota writing him a check lol and using it
Old 09-16-2013, 09:56 PM   #1851
jamesm
You could use an innovate ot-2. It has an api you can use to listen for what are basically pids from the obd2 over wifi, really fast if necessary. They have examples and docs on their site.
Old 09-16-2013, 10:02 PM   #1852
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Pug View Post
It's doable, if you want to do it. My problem is that sensing RPM on this engine seems to be a major PITA; the only "easy" way to do it that I've found is with an ODB connector.
The way I was originally planning to try was to add a Bluetooth module to my advanced monitor and use that to poll the RPM every 0.5 seconds (practical max) to decide to enable/disable/modulate the throttle switch, however my ELM327 bluetooth ODBII connector can't handle two masters, so that would mean Torque doesn't work. For this reason, I haven't bothered to build that in.
A more complex way is to tap the sensor lines leading to the ECU, like here: http://www.arduinoos.com/2013/08/engine-rpm-part-1/, but that's beyond my comfort level; it'd need a separate Arduino microcontroller just to handle that sensor, and then report back to the "main" microcontroller.
I'm afraid I'm not an EE, just a poor dirty mathematician and computer scientist; I'm having all manner of fun screwing up my monitor circuit each weekend and it isn't working yet
I just want to know how to tell the motor to turn at different speeds in the simplest of terms. What signal is supplied to the controller to tell it to turn at the rpm of choice? I'll worry about a circuit to send that signal: I just need to know what the signal is.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-17-2013, 01:39 AM   #1853
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
@mid_life_crisis: The throttle switch (+5VDC) can be pulse-width modulated with a transistor to vary the compressor motor speed, however I've been repeatably told the current system is not designed for constant operation.
There's no need to 'smooth-out' boost onset at WOT with a ramp-up, the boost addition feels natural there; it would be nice and reasonable to run lower boost when climbing a hill, for example. If we're WOT climbing a hill holding steady at 3.5k RPM for 5 minutes (Colorado?), it would be better to run at lower PSI for the whole climb than to reach the thermal limits and have the controller shut off the system to cool and recover.
Constant operation all the time will cause more drag on the alternator, increased wear of the compressor motor, greatly increased thermal management issues of both the compressor motor and the controller, as well as complicating the tune since it could engage when not the ECU was open loop... and probably other things that Rob has already thought through that I'm not educated enough to realize.
Really, the system feels awesome as-is; now that I have really gotten to play with it, I don't see the need to add much more complexity.
Pug is offline   Reply With Quote
Old 09-17-2013, 09:16 AM   #1854
mid_life_crisis
I'm not looking to have constant operation. With the current state of battery technology that isn't feasible anyway.
I'm looking for a seamless way to limit boost at low rpm when the system is engaged (switch on, pedal to the floor) to protect the engine's bottom end and make it possible to run without a tune.
Old 09-17-2013, 09:31 AM   #1855
rusty959
Drives: DGM BRZ limited
I think this would be useful from what the reviewers have said, and it sounds like you have everything you need to know to do it.
It should be a pretty simple circuit, Id love to see what you come up with :happy0180:
rusty959 is offline   Reply With Quote
Old 09-17-2013, 10:19 AM   #1856
Pug
Atoning Unifex
Pug's Avatar
Here's a picture of the throttle switch from my install; the red wire is carrying +5VDC from a voltage source, and the hidden wire (black) leads to an input on the controller. There's negligible current to worry about. Closing the circuit causes the controller to drive the compressor.
Old 09-17-2013, 10:22 AM   #1857
mid_life_crisis
Yeah, all I need is a sample to experiment with.
I haven't done circuit design in eons. This will be interesting.
I agree that this should be a simple circuit. So I just send a pulsed 5 volt signal. I'm assuming that a continuous 5 volts is "full throttle" and as the pulses get shorter the thing slows down. Is there a particular frequency range it expects?
Old 09-17-2013, 03:24 PM   #1858
Robftss
Drives: VW
Name:  Electric SC DRIFT OFFICE.jpg
Thatruth dyno.
Boost from 1800 rpm.
180 ft-lbs @ 2800 rpm
Similar gains to other dyno runs, best @ 4200 rpm
Wonky boost plot.
Nice AFR's Bob!!
Robftss is offline   Reply With Quote
Old 09-17-2013, 04:10 PM   #1859
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Robftss View Post
Attachment 51579
Thatruth dyno.
Wonky boost plot.
Nice AFR's Bob!!
Wow would you look at that, at a glance looks like about 50 lb-ft gain through the torque dip, and even about 25 lb-ft gain at 7000 rpm! That's a BIG gain for a 2700 lb car. Congrats!
Any theories on the oscillating boost curve in the upper rpms?
Old 09-17-2013, 04:56 PM   #1860
fenton
I see ~70 in the dip at most and ~50 HP at 7400 rpm.
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
Old 09-17-2013, 05:03 PM   #1861
tennisfreak
Drives: 2018 BMW M240i
Im interested but skeptical.
This goes against myth busters and countless other videos that have proven its impossible for an electric motor (in a cars engine bay, running on batteries) to produce boost.
Old 09-17-2013, 05:04 PM   #1862
bfrank1972
Yah I took a look at your last dyno posted in the thread, you are getting a bigger jump during the dip - your 7000 rpm looks to be a just a bit over 25, maybe 30 lb-ft. You and ThatTruth are at roughly the same altitude?
A side thought - would this system partially compensate for altitude? The thing is trying its hardest to force as much air as it can into the engine - if the air is thinner my intuition says it would at least partially make up for the deficit from altitude - in other words I'm wondering if you guys at altitude will see bigger gains than us at sea level? If that's the case, would the dyno's altitude compensation be optomistic? I'll be interested to see some low altitude dynos soon!
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
