Old 09-17-2013, 08:34 AM   #15
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Dipstik-sportech View Post
Yeah I hope you have plans for a surge tank or some major fuel system mods ie return style with -10 feed. Also what's your plans for the differential and axles?
Driveshaftshop has some axles that should work:
http://www.driveshaftshop.com/import...l-axle-hub-kit
Old 09-17-2013, 09:57 AM   #16
Turbowned
Turbowned's Avatar
Originally Posted by SUB-ZERO View Post
I'm just saying I've seen some impressive cars come out of the Emirates, so I don't think this is a joke thread
Old 09-17-2013, 10:07 AM   #17
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
The fact that your engine is built doesnt determine what turbo is " best ". If anything its the other way around.
Decide what you want to do with the car, then see how much power you need, get the most responsive turbo you can to achieve that power and if you need to build the motor, go for it.
Keep in mind if you build the motor and lower the compression, your power curve will change.
If you are dead serious about 650rwhp, im assuming you're going for 1/4 mile and youll probably need a 6766.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-17-2013, 10:09 AM   #18
Dipstik-sportech
Dipstik-sportech's Avatar
Ok so that's the axles, what about diff and fuel?
Old 09-17-2013, 11:49 AM   #19
Ross
Drives: 85 corolla gts
6266can hit 650 all day long. A 6466 will add a little lag and would be recommended before a 6766 unless you were planning to max out the 67 and for the power goal he is not. there are other options as well for the power goal just depends on how he wants to do it.
Ross is offline   Reply With Quote
Old 09-17-2013, 11:51 AM   #20
jonbonazza
Isn't a "big turbo that spools fast" a bit of an oxymoron?
jonbonazza is offline   Reply With Quote
The Following 3 Users Say Thank You to jonbonazza For This Useful Post:
ftc~brz (09-24-2013), Goneau (09-17-2013), infinite012 (09-18-2013)
Old 09-17-2013, 11:59 AM   #21
Tansey86
Tansey86's Avatar
Don has the hook ups for a big fuel system for 650 easy, and ft86speedfactory offers a helical diff made by mfactory to handle 1000hp.
The Following User Says Thank You to Tansey86 For This Useful Post:
Boris_Petrov (05-23-2019)
Old 09-17-2013, 12:00 PM   #22
Tansey86
Tansey86's Avatar
True, smallest turbo to get to his goals is the best and a 6266 with the right housing will hit that.
Old 09-17-2013, 12:02 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yes. I would still go with a Garrett GT35.
Old 09-17-2013, 12:48 PM   #24
SUB-ZERO
Drives: GT86/GTR R35
Wink
Originally Posted by slowmo View Post
What about the fuel system i am pretty sure it would be maxed out at around 490+whp
Dynamics injector 1300cc-2000cc
fuel pump dw
going to run q16 racing fuel
SUB-ZERO is offline   Reply With Quote
Old 09-17-2013, 01:05 PM   #25
SUB-ZERO
my full drivetrain is from par-engineering , tran , axles driveshaft,
Old 09-17-2013, 01:10 PM   #26
SUB-ZERO
Ross I will not have lag bcuz I already getting a vi-pec and using anti-lag and launching at 5k rpm full boost and we a slicks tires
Old 09-17-2013, 01:14 PM   #27
Tansey86
Tansey86's Avatar
Details?
Old 09-17-2013, 01:50 PM   #28
Dipstik-sportech
What trans? A beefed up stocker or a swapped one? Curious cause mine is f-ed up
built motor, turbo
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
Anybody know where the Scion FR-S is built? Fish Eagle Scion FR-S / Toyota 86 GT86 General Forum 24 05-29-2013 11:44 PM
Will FR-S ever have a aftermarket turbo built? docyzx Forced Induction 50 07-19-2012 12:20 AM
