Old 09-16-2013, 03:39 PM   #1835
fenton
Originally Posted by bfrank1972 View Post
It's a bit different than other FI options out there since it's driven by an electric motor. I'm no engineer but here's my attempt (I *think* it works this way):
- When you go WOT, it closes a switch and the electric motor driving the ESC goes wide open. It's an all or nothing type deal, so in an open situation (not forcing air into a motor) it will deliver a fixed CFM.
- The motor, on the other hand, has variable CFM requirement roughly proportional to RPM. In other words a motor may need twice the CFM at 4000 rpm than 2000 rpm (in real world this of course varies but to illustrate a point).
-At high engine RPM, the ESC motor is able to flow a little bit more than the motor does at atmospheric, so you see maybe 1-2 PSI pressure above atmospheric at high revs.
-At low engine RPM, the ESC motor is able to flow MUCH more than the motor at atmospheric, so it is capable of producing much higher PSI.
In other words, the motor will *try* to stuff a fixed amount of air into the motor regardless of RPM. Since there is no 'wastegate' or other limiter, at very low rpm this thing could *potentially* boost to damaging levels. Other FI types don't really have this problem because they're limited by belt speed (RPM dependent) or wastegates (boost dependent).
Experts please excuse if I'm over-simplifying things.
Exactly right. I will simplify it even more.
Max boost at 0 RPM is 5psi
Max boost at 7500 RPM is ~2psi
If you try and stuff 5psi into a engine at 0-1500 rpm it isnt going to be that happy. Then engine isnt very efficient at that range and focing air into it during that time doesn't net you anything except increase load on everything.
If you do go WOT at that low rpm, i have once, the car just kinda bogs and isnt happy. At the same time it goes very rich because it doesnt really know whats going on.
ThaTruths drift office tune starts as low as ~1800rpm(i heard) and it was happy, however; just remember the load your are putting on your poor engine
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
DAEMANO (09-16-2013)
Old 09-16-2013, 03:40 PM   #1836
fenton
Originally Posted by Thatruth2001 View Post
The drift office ecutek option is tuned to go WOT at 1,800 RPM. Talk to Rob, he has seen the AFR reading. I only use the ESC at 2,500 in either 4th or 5th gears so I do not have to downshift to pass on the highway. Puts a big smile on my face!
Thats great to hear. I just feel so bad going WOT that low lol.
Old 09-16-2013, 03:42 PM   #1837
Thatruth2001
Drives: Raven FR-S
Going WOT in 1st took me a couple of weeks to do. I really do not recommend doing it in the rain!
Thatruth2001 is offline   Reply With Quote
Old 09-16-2013, 05:42 PM   #1838
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
My kit arrived today. My batteries should arrive tomorrow. I will be driving an ESC boosted -86 on Wednesday. I need to get with @moto-mike shortly thereafter to have the BRZEdit tune flashed or possibly a custom tune. Don't know about the tune details yet.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
raven1231 (09-16-2013)
Old 09-16-2013, 06:02 PM   #1839
JDMenrique
DEEEERP
JDMenrique's Avatar
i went to their website and didnt see anything. where can i get one of these and how much are they?
JDMenrique is offline   Reply With Quote
Old 09-16-2013, 06:04 PM   #1840
Robftss
Drives: VW
Originally Posted by mid_life_crisis View Post
That assumption is a mistake. This is exactly the kind of system that will appeal to guys who consider tuning as something they don't want to get involved with. Easy bolt in, easy removal, minimal fuss.
If I have to limit the power gain slightly to keep my motor safe without a tune, then I'll do that knowing I won't be getting as much out of it as the guy who does get a tune. It'll still be a nice bang for the buck, just not as big a bang as the next guy.
Presently you can:
Build a connector/box/circuit MAP Vclamp as per PUG's diagram (values not tested yet).
Buy /splice/wire/calibrate an adjustable rpm window switch.
or
BRZlite/Tantrix/Toma file.
Either one has costs, one gives you more, one gives you less.
or
Run stock tune/CEL/ mindful boosting below ~3K.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
Old 09-16-2013, 06:13 PM   #1841
raven1231
You can't
Old 09-16-2013, 06:32 PM   #1842
Robftss
Drives: VW
We are testing production prototypes/tuning options/electronics/Auto-X/durability/drivability/& most important user feedback.
Old 09-16-2013, 06:42 PM   #1843
JDMenrique
DEEEERP
JDMenrique's Avatar
You can't
im sorry guys, i couldve sworn i read someone actually ordered one. thanks for the heads up
Old 09-16-2013, 07:13 PM   #1844
raven1231
Not yet but hopefully soon! There are quite a few testing them though.
Old 09-16-2013, 07:34 PM   #1845
mid_life_crisis
Drives: FR-S 10 #103 AT
Presently you can:
or
or
or
get @Robftss to cough up an explanation on how the controller works so we can build our own rpm sensitive circuit to provide partial boost starting at 1500 rpm building to full on at about 3250 when the pedal is to the metal.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-16-2013, 07:40 PM   #1846
Thatruth2001
Drives: Raven FR-S
or
Here is the funny thing ......Chinesse manufactures are looking at this thread and are attempting to develop a unit... Some have gone as far as contacting some people about testing and tuning.
Knowing how long it took Rob to R&D this unit I have a feeling there will be many knock offs around the corner.
Concerning modulation of the unit's output, I can send you about 20 emails debating it with Rob. At the end of the day is it achievable, yes but it becomes more complicated which leads to driving up costs.
We all want the bells and whistles, but the cost of the feature might become a turn off. Personally, I thnk Toyota should write Rob a fat ass check and incorporate the unit into an hybrid version of the car.
The Following User Says Thank You to Thatruth2001 For This Useful Post:
Old 09-16-2013, 08:00 PM   #1847
Anaxilus
Drives: They have four wheels
Good luck w/ that. I'd rather drive a Geely, that way death will be quick and relatively painless.
Anaxilus is offline   Reply With Quote
The Following User Says Thank You to Anaxilus For This Useful Post:
Old 09-16-2013, 08:27 PM   #1848
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
or
It's doable, if you want to do it. My problem is that sensing RPM on this engine seems to be a major PITA; the only "easy" way to do it that I've found is with an ODB connector.
The way I was originally planning to try was to add a Bluetooth module to my advanced monitor and use that to poll the RPM every 0.5 seconds (practical max) to decide to enable/disable/modulate the throttle switch, however my ELM327 bluetooth ODBII connector can't handle two masters, so that would mean Torque doesn't work. For this reason, I haven't bothered to build that in.
A more complex way is to tap the sensor lines leading to the ECU, like here: http://www.arduinoos.com/2013/08/engine-rpm-part-1/, but that's beyond my comfort level; it'd need a separate Arduino microcontroller just to handle that sensor, and then report back to the "main" microcontroller.
I'm afraid I'm not an EE, just a poor dirty mathematician and computer scientist; I'm having all manner of fun screwing up my monitor circuit each weekend and it isn't working yet
Pug is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
