Old 09-16-2013, 11:57 AM   #1681
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Automatically turn off your traction control...
http://www.ft86club.com/forums/showthread.php?t=10621
Old 09-16-2013, 12:18 PM   #1682
xjohnx
Grip>Slip
xjohnx's Avatar
Which method are you recommending? I know you had some issues with the one in the first post. Someone recommended using a Wolstentech Relay at post 42 which seems to look pretty simple
edit: doh, somehow missed your huge text at the top of the post.
Old 09-16-2013, 12:28 PM   #1683
DarrenDriven
NW Region Moderator
I am still using my original method without any issues since day one. Works perfectly.
The new method is simpler and should work better, so I would try that first.
Old 09-16-2013, 12:40 PM   #1684
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by xjohnx View Post
The Innovate kit doesn't come with injectors, unless your vendor had a package deal where they added them. Are you still on the stock fuel pump or aftermarket?
I did the FA20club kit that came with injectors and pump. I'm still running the stock pump, and I need to get the time to do some logging.
wrxgoose is offline   Reply With Quote
Old 09-16-2013, 04:58 PM   #1685
sw20kosh
Drives: 2013 Black FR-S
I have seen several people complain about this slight hesitation in the 2-3k range. From what I have seen from my logs and several different tunes, the hesitation is caused by timing being pulled and then added back. In your logs go to 2D mode and look for knock correction values of near -5. Wherever you see knock correction you will also see your total timing decrease at the same time in that zone.
This ecu or motor doesn't like boost and timing advance in this rpm zone. I believe I read that cylinder pressures are extremely high here. It is up to your tuner to get the timing right so that the ecu isn't pulling timing.
Keeping an eye on the advance multiplier also can tell you if your motor is often pulling timing due to knock. Ideally you want the advance multiplier at 1. The map I am running now has the AM pegged at 1 all the time which is great.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
tech4pdx (09-16-2013), wrxgoose (09-16-2013)
Old 09-16-2013, 05:05 PM   #1686
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
What are your afr while the happens? Part throttle or full?
448hpsti is offline   Reply With Quote
Old 09-16-2013, 05:13 PM   #1687
wrxgoose
WUB WUB
Its more pronounced at part throttle.
The Following User Says Thank You to wrxgoose For This Useful Post:
Old 09-16-2013, 05:14 PM   #1688
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Got a afr gauge?
Old 09-16-2013, 06:14 PM   #1689
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
I too have experienced this part throttle hesitation from 2k-3k. My tuner can smooth it out though. BrzEdit is the tool.
I think the FA20 motor in general is pretty anemic below 3k, fi or not. You gotta drive it hard.
tech4pdx is offline   Reply With Quote
Old 09-16-2013, 07:04 PM   #1690
Opposed
Drives: 2013 Asphalt FR-S
I don't know. After coming from several Hondas, this thing pulls pretty hard below 3k for an N/A 2.0. The tune helped quite a bit though...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-16-2013, 07:13 PM   #1691
tech4pdx
Make love
tech4pdx's Avatar
@Opposed.. You may be right. I don't claim to be an expert on small displacement high strung motors. I am used to having massive amounts of torque available at low to midrange rpms. There is a reason why the phrase "no replacement for displacement" was coined. Granted, turbos can change that notion to a degree. I do enjoy this car in FI form nonetheless, especially past 4k rpm.
The Following User Says Thank You to tech4pdx For This Useful Post:
448hpsti (09-16-2013)
Old 09-16-2013, 07:35 PM   #1692
sw20kosh
Yes this is where I noticed it too.
Old 09-16-2013, 07:50 PM   #1693
wrxgoose
WUB WUB
Got a afr gauge?
unfortunately no. not yet.
I really need to get @JuniorAWD to check it out. Once i get a new clutch, going to do more logging.
Old 09-16-2013, 08:09 PM   #1694
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Yes you do, i don't rely on just your tuners tune or logs.
I use the innovate mtx and like it, go get one on your car NOW
best price I saw was on amazon...
The Following User Says Thank You to 448hpsti For This Useful Post:
Sportsguy83 (09-17-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
