#15 |
Ted
Drives: Raven FR-S
Big box improvement stores sell one-time-use dehumidifying tubs...you take the lid off, set it in the room and walk away. Park it in the sun, windows closed and set a tub on the floor in front of each seat and you'll be fine.
Personal experience in this...before the FRS, I had a 2nd Gen Tacoma (which were notoriously less waterproof than 1st Gen's). I had anywhere from 1-5 inches of water in the cab several times over the years from creek/water crossings on trails. I pulled the all the interior carpet out a couple times and vac'd and sun dried, but for the effort that it took, it was just as effective and endlessly less time consuming to deploy 4 dehumidifying tubs between the front at back seats. YMMV, but I'd start here. http://www.damprid.com/ |
#16 |
Drives: 13 BRZ WRB
Call your insurance and get the car totalled it willbe better for you in the long run.
#17 |
Drives: Ion Redline
I think the water has to reach the steering wheel in order to total it.
"Bullshit, asshole! No one likes the tuna here!"
#18 |
Drives: car
If you don't have a dehumidifier at home, ask around some detailer shops if they have a dehumidifier, many of them do interior detailing service and use an ionizer - some of them may as well have a dehumidifier.
Also yeah a bunch those 12oz "No Damp" dehumidifier tubs they sell in home improvement store sections work very well. |
| The Following User Says Thank You to radroach For This Useful Post: | Rayme (08-20-2013) |
#19 | |
#20 |
Drives: 13 BRZ WRB
#21 |
Drives: Honda Civic
Thanks for the help guys. I just got the car back after a few weeks in the shop under insurance. They cleaned all of the carpets and seats, and replaced the clutch assembly. I'm going to go ahead and do a precautionary oil change as well, but other than a slight musty smell (which has mostly gone away) it is back to normal!
Here are some before pictures, the drivers seat is pulled out and you can see the whole inside of the car is still wet: After! |
#22 | |
CAMBAM
Drives: '13 Whiteout FRS
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
#23 |
Drives: RV-7
That car should be considered a total loss, no question. Get a lawyer, have them submit a demand letter to the insurance company that appears to be evading responsibility, cc: your state insurance commissioner.
#24 | |
Drives: Honda Civic
I'm a little worried about electrical problems so I'm considering going through the car and putting silicone grease inside the connectors, but otherwise there isn't much to worry about. The car is still under full factory warranty. |
#25 | |
Drives: RV-7
For perspective, my first corporate job for a major auto manufacturer involved the inspection of hundreds of new cars and trucks for possible flood damage. After days of training by the insurance company whose interest was to repair cars, not total them, my staff totaled hundreds of cars over a several week period including some that had been retailed and were in use by customers. One of the main criteria to determine total loss was water entry into the cabin over the level of the seat belt anchor points. It sounds like your car had even more. It may take 5-10 years, but problems will arise. I can't believe your insurance carrier is exposing themselves to this type of potential liability. Did they certify in writing that you won't have a branded title and the full factory warranty will remain in effect? Like I said, consult an attorney and I'd add an independent certified diminished value appraiser licensed in your state and pay the ~$200 for a written report. This isn't legal advice, I'm not an attorney, but was directly involved in a situation like yours. Good luck! |
#26 |
Hail Magnet
Glad you got your car back, dry and driveable!
However, I'm surprised that nobody suggested packing the car in rice for a couple days
#27 | |
Drives: 17 Alfa Romeo 4C
Sounds like good advice. The reality is that your car is working now, but there most likely will be electrical gremlins in the future. Do your research 1st and only consider an attorney as a last resort. Sounds like you may have been better off if they totaled the car. |
#28 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
Im late to the party but here is what i would havevsaid
Disconnect battery ASAP Open air box, spray with mass air sensor cleaner Leave open to air dry Put a rag so no debris or insects crawl into intake Fill two bottles of dry gas (methanol) to our tank, if water got in there you need I drain it, you can get most fuel out by disconnect lines to injectors and run pump, fill full with fresh fuel if needed and repeat till you have old fuel out if it is contaminated If there is water in spark plug holes, let that dry, it's okay to leave a fan on top of motor or a few days running in sun Don't try to start it till pure sure it's dry!!! Patience is your friend Drain and fill with fresh oil too if n doubt. Ensure the o2 sensors are dry Start it and pray? |
| Hail Damage | execoll | BRZ First-Gen (2012+) — General Topics | 61 | 07-21-2014 06:22 PM |
| Toronto Flood July 8th 2013 | nos145 | Issues | Warranty | Recalls / TSB | 2 | 07-10-2013 11:47 AM |
| Damage report | that_one_guy | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 01-02-2013 03:34 PM |
| Fuji 86 Style 2012 JDM @ Fuji Speedway (Photo Flood) | shawrf1 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 59 | 08-19-2012 11:13 PM |
