Old 09-15-2013, 02:52 PM   #43
getbent
Drives: 2013 FR-S Blue MT
From what I have seen in my own car, the oil pump isn't variable speed. Just from memory, I typically see about 1 bar per 1000 psi:
~10psi at idle (600-700 rpm)
~1 bar at 1000 rpm
~2 bar at 2000 rpm
~3 bar at 3000 rpm
I haven't paid too much attention to the oil pressure at higher rpm.
This is using Pennzoil Platinum 0W-20 at ~200f.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 09-15-2013, 03:13 PM   #44
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Whoa nice destroyed engine..but there's no relation to oil pressure and engine damage at this point from that one example.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
Fabron757 (09-23-2013)
Old 09-15-2013, 03:31 PM   #45
lexusb3
Drives: FRS
Originally Posted by Fabron757 View Post
I'm at 470@wheels and I beat the heck out of my car every day. And I drive it every day as my DD to work. Which is about 45 min drive one way. The only problem I have is random people asking how I get my frs to sound mean and wanting more power. I plan on building the motor but this stock motor is taking a beating. So might turn boost up to 500+ and see if she pops lol.
Woooo 470 lol I get the same its so quite when cruzing but wot ppl like WTF lol
lexusb3 is offline   Reply With Quote
Old 09-15-2013, 04:16 PM   #46
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
~1 bar at 1000 rpm
~2 bar at 2000 rpm
~3 bar at 3000 rpm
http://www.ft86club.com/forums/showthread.php?t=28713
Seems like Dave is not losing pressure at the dip either. Although he state that oil pressure start dropping once past 7000rpms according to his post.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Sportsguy83 (09-15-2013)
Old 09-15-2013, 04:55 PM   #47
Frs300
Frs300's Avatar
Drives: Pile of junk
numbers getbent posted are about same as daves. all depends on oil and ambient temp and what not
Frs300 is offline   Reply With Quote
Old 09-15-2013, 05:02 PM   #48
lexusb3
Drives: FRS
TRU I USE 10W-40 NOT that stock water 0-20 lol
Old 09-15-2013, 07:26 PM   #49
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by regal View Post
The oil pump has a variable gear to save gas. In the torque dip its actually designed for lower pressure rate of increase than the typical 10 psi per 1k rpm. So add a bunch of torque in that rpm range with boost ? Weird things like this are just now being uncovered and dealt with.
If you really drive the car (more than a few daily WOT pulls on the highway) follow Dezoris's build videos, it is a very smart approach, I think he is around 220 rwhp.
So I have the Innovate Oil Pressure/ Oil Temperature in one gauge. It has logging capabilities. Went ahead and did several logs from 2K RPMs to 5-7K Rpms.
Including WOT, full boost, partial throttle, very light throttle, cruising.
ALL of the time, the oil pressure graph NEVER drops one PSI while increasing RPM. It looks exactly as expected a line continuously going up. I will post up pics when I trim it as the whole log was 18 minutes.
Again, it might be true its variable drive, BUT it does not appear to be loosing pressure along any RPM range.
EDIT: I'm using Motul 8100 0w-30 Oil.
The Following 5 Users Say Thank You to Sportsguy83 For This Useful Post:
Amadeus (09-16-2013), Calum (09-15-2013), cf6mech (09-16-2013), jamesm (09-16-2013), solidONE (09-15-2013)
Old 09-15-2013, 09:52 PM   #50
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm having a really hard time imagining it being variable drive. Oil pumps are typically the most reliable thing on a car. They are shit simple for a reason, so they don't break.
The Following User Says Thank You to Calum For This Useful Post:
Old 09-15-2013, 09:57 PM   #51
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Yeah I have a hard time believing they'd go through the complexity of putting a variable drive just to slow down oil feeding at higher rpms. If anything they'd want to raise it to push more circulation.
Maybe on a high end (LFA type) car they'd do that sort of thing but lets face it, our FR-S is a budget car and doesn't have very many luxuries.
Nolan
pheoxs is offline   Reply With Quote
The Following 2 Users Say Thank You to pheoxs For This Useful Post:
Calum (09-16-2013), Sportsguy83 (09-15-2013)
Old 09-16-2013, 09:32 AM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by solidONE View Post
I think one of the forum moderators was logging his oil pressures intensively after having installed an oil cooler. Maybe they can chime in and offer some of his findings. @Dave-ROR, care to show us your "log?"
I posted various bits of info over time. I wasn't organized enough to keep a real log
As far as temps, I never saw over ~235 with the cooler at Sebring in hot weather, where others locally without the cooler are hitting 290-300+.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
solidONE (09-16-2013)
Old 09-16-2013, 09:33 AM   #53
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
~1 bar at 1000 rpm
~2 bar at 2000 rpm
~3 bar at 3000 rpm
In my car it stopped DROPPING big time at high RPMs with 0W-20. 0W-30 fixed that though. In theory with less flow.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-16-2013, 12:11 PM   #54
Calum
That Guy
Stopped...? Did you mean started? Do you recall how low the pressure got? Or if there was any corrilation to temperature? What brand of oil were you using?
Thanks Dave.
Old 09-16-2013, 01:30 PM   #55
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks Dave.
Yes started
I don't do high RPMs until it's warm of course, but temps varied a few degrees during that testing which was on the interstate with the cooler installed. It's extremely repeatable though regardless of temp (ie warm or hot).
That was Mobil 1 0w-20 I believe. Currently it has Redline in it. Right after that mobil 1 testing I switched to Xw-30 Royal Purple. Pressure stays good all the way.
20 weight is good for fuel economy though. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Sportsguy83 (09-16-2013)
Old 09-16-2013, 04:37 PM   #56
solidONE
solidONE's Avatar
Yes started
You have not gone FI with your car, correct? Also the pressure dropping with the 0w-20 is under normal driving conditions and temps or were you wringing out the car/motor?
Intent > Content
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 11:35 AM
WTB: Factory Boxer Engine cover Sportsguy83 Engine, Exhaust, Bolt-Ons 28 11-11-2013 01:04 AM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 05:04 PM
aFe Announces the Grand Opening of the aFe Power Factory Store aFePower_indika Announcements, Contests, Giveaways 3 10-22-2012 07:30 PM
