Old 09-15-2013, 01:07 AM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by regal View Post
Interesting... seems like many bad things happen to this engine around 4-5K rpms, including the direct injector seals getting burnt. Is there a photo of diagram of this oil pump available?
Intent > Content
Old 09-15-2013, 05:34 AM   #16
diss7
Drives: AE86, 2x GT86, TE27
Over 9000
diss7 is offline   Reply With Quote
Old 09-15-2013, 08:35 AM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
I just went looking through the service manual to see if the oil pump tear down was in there. It wasn't but after looking through some of the pictures it appears that the main bearings are half groove. Half groove bearings work well at low RPM, but at high rpm will start to pump oil on there own, and force the oil back toward the oil pump. This could be the cause of the weird oil pressure vs. rpm plot. Also makes me wonder if the secret sauce bearings in FRS300's engine build are just two sets of FA20 main bears combined to make full grove bearings.
Old 09-15-2013, 08:49 AM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The oil pump has a variable gear to save gas. In the torque dip its actually designed for lower pressure rate of increase than the typical 10 psi per 1k rpm.
Really? I have never seen my oil pressure gauge drop PSI on the dip range (or any other RPM for that matter) or not increase exactly as is any other RPM....
Old 09-15-2013, 08:50 AM   #19
Frs300
Frs300's Avatar
Drives: Pile of junk
where did you find the half groove info i dont see that anywhere in the pdf manual i have maybe mine is a pos
Frs300 is offline   Reply With Quote
Old 09-15-2013, 08:51 AM   #20
Sportsguy83
Drives: Limited BRZ
You aren't going to test the car fully in florida, its flat with nothing but miles of straight roads. Take her up for a trip to the appalacians and find some backroads, fun stuff.
Yep, you can fully test the car in FL, just run it hard on the track.
Oh and post #3 Looks Legit....
Seriously man, it seems you have 86 Hypochondria.
So you mean to tell me Crawford, FBM, FA20, Don, Treadstone, et. al. have taken the engine apart but none have taken the time to explain this about the FA20 oil pump and how it affects cars, and none have designed an upgrade to make money off of it?? Is it POSSIBLE yes! But I find it hard to believe that not even one of them would capitalize on this and design SUCH a needed upgrade.
But this is America, we are all free to say what we want so go ahead with the FA20 POS campaign
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lexusb3 (09-15-2013)
Old 09-15-2013, 08:57 AM   #21
lexusb3
Drives: FRS
http://www.ae86drivingclub.com.au/fo...OOOOOM!http://
Its post #3
MILES AND STR8 roads are all i need lol if i go on some back roads ill end up drifting and just burning tires lol ill leave that up to someone else. but for now 25,000 turbo miles by december and more daily abuse wil be made by me . I willl keep pushing untill i cant push no more than BUILD and push that as far as i can go then on to the next project !!
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
Sportsguy83 (09-15-2013)
Old 09-15-2013, 09:34 AM   #22
Calum
That Guy
I was just looking at the pcs in the PDF that's on here. It was by no means definitive, but I have seen half groove bearings in the past and they acted in a similar fashion.
Old 09-15-2013, 09:58 AM   #23
lexusb3
Drives: FRS
Its post #3
il will take a look at this myself hook up my computer and see the presure im curious, but untill then i need soild facts numbers vidoes sheet lol sadly thats how society is! that link could have been anything "overboost" , "shit tune", what ever excuse i can think of
solidONE (09-15-2013)
Old 09-15-2013, 12:00 PM   #24
jamesm
as always it depends 100% on how you use the car. you could drive around at 400+whp on a turbo car with absolutely no other mods, and if all you're doing is driving to the local walmart for some hard-parking, it'll probably last forever. if you take a stock car to the track every weekend, it probably won't last very long. extrapolate in between.
The Following User Says Thank You to jamesm For This Useful Post:
Old 09-15-2013, 12:14 PM   #25
dabocx
dabocx's Avatar
Drives: Scion FRS
The transmission is the part that worries me more at this point
dabocx is offline   Reply With Quote
Old 09-15-2013, 12:15 PM   #26
lexusb3
Drives: FRS
agreed! but i WOT to walmart hahahha jk jk.. im still curious to the oil drop thing
jamesm (09-15-2013)
Old 09-15-2013, 12:26 PM   #27
Frs300
Frs300's Avatar
walmart is 1/4 mile away exactly from my house
The Following 2 Users Say Thank You to Frs300 For This Useful Post:
jamesm (09-15-2013), Sportsguy83 (09-15-2013)
Old 09-15-2013, 12:26 PM   #28
regal
Drives: Scion FR-S/Toyota Yaris
You do know that WOT pulls aren't a high stress with this car? WOT is completely open loop and purely dependent on simple dyno tuning.
Its the part throttle on/off mid to high rpm up hills, feathering around sharp turns stuff that stresses this motor.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 11:35 AM
WTB: Factory Boxer Engine cover Sportsguy83 Engine, Exhaust, Bolt-Ons 28 11-11-2013 01:04 AM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 05:04 PM
aFe Announces the Grand Opening of the aFe Power Factory Store aFePower_indika Announcements, Contests, Giveaways 3 10-22-2012 07:30 PM
