Old 09-13-2013, 06:41 PM   #1597
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
What is the highest HP output from the Innovate and at what PSI right now?
I think I'm one of the highest without using E85, 276 rwhp. 70mm pulley is 12 psi I think. I need to get the boost plot from my tuner. Brzedit tuned.
tech4pdx is offline   Reply With Quote
Old 09-13-2013, 06:42 PM   #1598
FA20Club.com
Drives: 2013 White Out FR-S
I would be careful with a gray market upgraded Sprintex supercharger.
LMAO.....
FA20Club.com is offline   Reply With Quote
The Following 3 Users Say Thank You to FA20Club.com For This Useful Post:
1010110 (09-13-2013), Sportsguy83 (09-13-2013), tech4pdx (09-13-2013)
Old 09-13-2013, 06:42 PM   #1599
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
WTQ? Nice that is BRZEdit tuned!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
evo4g63 (09-14-2013)
Old 09-13-2013, 06:44 PM   #1600
tech4pdx
Make love
tech4pdx's Avatar
I'm going to post my dyno sheet in 5-10 min
The Following User Says Thank You to tech4pdx For This Useful Post:
Old 09-13-2013, 06:47 PM   #1601
FA20Club.com
Originally Posted by Dezoris View Post
I agree. the IC is not about the power numbers its about reliability, repeatability and stability of power delivery.
You head the nail on the head. power gains werent our main goal in testing this thing; it was extending the fun factor by eliminating as much heat soak as possible. What i saw was allot more consistent numbers while testing on the dyno and no more 10+whp drop from ignition retard dropping my total power out put. TIP-IN knock even with 130 degree inlets on the maf located sensor didnt create the drastic Knock Retard we saw from our work out in the desert.
1010110 (09-13-2013), Dezoris (09-14-2013), tech4pdx (09-13-2013)
Old 09-13-2013, 06:50 PM   #1602
xjohnx
Grip>Slip
xjohnx's Avatar
can you comment on IAT deltas pre/post IC?
Old 09-13-2013, 06:56 PM   #1603
FA20Club.com
Lets clear up a couple things.
As with all our other products we WILL cover our own warranty on items. You will not be left out to dry because we stand behind all our products. We have always offered not only our own products but done our best to improve our competitions offerings.
As far as packages go we will continue to offer this to those who previously purchased their chargers from either ourselves or another vendor. This kit was developed on a USDM vehicle dont think this is a simple RHD kit we imported. We are using our own improved capacity heat exchanger, larger capacity reservoir and reinforced nylon braided lines. what this equates out to you is a system that holds more fluid for better heat dissipation as well as a fill-able tank that allows you to load ice for those glory runs on the Dyno or on the track. This might be considered gray market but its got our full support as always.
The Following 7 Users Say Thank You to FA20Club.com For This Useful Post:
1010110 (09-13-2013), chadstyle (09-15-2013), Dezoris (09-14-2013), feldy (09-14-2013), lexusb3 (09-14-2013), phloozy (09-13-2013), Sportsguy83 (09-13-2013)
Old 09-13-2013, 06:56 PM   #1604
tech4pdx
Make love
tech4pdx's Avatar
Dyno sheet attached
Dyno sheet, pump/meth/70mm/EL header, full exhaust (with both cats(aftermarket) in place)/bolt-ons.
edit: this is not the final tune either. my tuner is working on another one that should smooth things out further.
The Following 4 Users Say Thank You to tech4pdx For This Useful Post:
448hpsti (09-14-2013), chadstyle (09-15-2013), DarrenDriven (09-15-2013), Sportsguy83 (09-13-2013)
Old 09-13-2013, 07:03 PM   #1605
FA20Club.com
i will have that all posted in our thread tomorrow some time. just have to organize all the information from this past week for you guys.
1010110 (09-13-2013), Dezoris (09-14-2013), xjohnx (09-13-2013)
Old 09-13-2013, 07:19 PM   #1606
Sonolin
Nice that's a good graph. Impressive what that meth tune can do!
I know @moto-mike was up to ~285 with e85; 70mm pulley and with OEM header. I think with nameless header it might push it up to ~300whp?
Sonolin is offline   Reply With Quote
The Following User Says Thank You to Sonolin For This Useful Post:
Old 09-13-2013, 07:21 PM   #1607
tech4pdx
Make love
tech4pdx's Avatar
Nice. I think with E85 I can hit 300.. but I think that is the end of the line (ie pushing it) for this blower (210). 335 is the next step.
edit: with my p&l (which fit like shit btw), I barely gained any peak hp, but midrange felt stronger.
Old 09-13-2013, 07:23 PM   #1608
whataboutbob
AutoX-10/10ths every run
Originally Posted by Draco-REX View Post
You will also likely have to cut the hood.
Make it look like this and it'll be perfect.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 09-13-2013, 07:27 PM   #1609
tech4pdx
Make love
tech4pdx's Avatar
I miss V8 small/big blocks just for stuff like that. I think I will have a 69-ish stingray in my future soon as next project
The Following 2 Users Say Thank You to tech4pdx For This Useful Post:
Sonolin (09-13-2013), whataboutbob (09-13-2013)
Old 09-13-2013, 08:24 PM   #1610
Sportsguy83
Drives: Limited BRZ
Dat Torque Curve....
Love it!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
448hpsti (09-14-2013), tech4pdx (09-13-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
