Old 03-04-2013, 02:28 AM   #29
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
in case you all haven't seen the new LED front running DRL's
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 03-08-2013, 01:11 PM   #30
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Possible to post a picture or discription of which wire you tapped for the DRL replacement? Would like to use the rings instead. You obviously disconnected the drl relay from the high beams as well?
Khyron686 is offline   Reply With Quote
Old 03-08-2013, 03:11 PM   #31
Tylub
Tylub's Avatar
just tapped into the parking lights from the side markers because they don't blink in USDM models. (don't want blinking halos ) Actually, I got it disabled at toyota so I can still have my high beams but they don't turn on during the day
instagram @Tylub
Old 09-06-2013, 01:22 AM   #32
MikePhamm
Drives: Frs
where are the parking lights wiring located?
MikePhamm is offline   Reply With Quote
Old 09-13-2013, 03:11 PM   #33
Tylub
Tylub's Avatar
just pop off the sidemarkers and tap into those wires
instagram @Tylub
Black Housing Tail Lights (FR-S) sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 20 04-13-2016 11:38 PM
Feeler : Flat Black headlight housing with Mormimoto LED Halos MrTranxD Exterior Parts (Aero, Lighting, Etc.) 11 03-13-2013 09:54 PM
black housing blinkers lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 9 09-02-2012 04:07 AM
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 04:41 PM
